On Thu, 8 Jul 2004 02:21:38 -0400, "Morgans"
wrote: Correct me if I'm wrong, but haven't some people put a Buick V- 8 in Tailwinds? That would weigh more than a 470, wouldn't it? Don't think so Jim. I had an 0-470 sitting in my shop and can testify that it was a LOT more difficult to lift using my block and tackle than the two Ford V6's I offloaded. The block and tackle almost couldn't lift the 0-470 but easily hoisted the V6's. I know it's anecdotal, but this was with a stripped block to boot. The 0-470 did not have the starter attached, nor did it have the two mags or generator or the pressure regulator for the prop. It was just very very heavy even without all those things. Corky Scott |
wrote in message ... On Thu, 8 Jul 2004 02:21:38 -0400, "Morgans" wrote: Correct me if I'm wrong, but haven't some people put a Buick V- 8 in Tailwinds? That would weigh more than a 470, wouldn't it? Don't think so Jim. I had an 0-470 sitting in my shop and can testify that it was a LOT more difficult to lift using my block and tackle than the two Ford V6's I offloaded. The block and tackle almost couldn't lift the 0-470 but easily hoisted the V6's. I know it's anecdotal, but this was with a stripped block to boot. The 0-470 did not have the starter attached, nor did it have the two mags or generator or the pressure regulator for the prop. It was just very very heavy even without all those things. Corky Scott Corky, that heavy O-470 engine is the powerplant originally used by Steve Wittman in the O-O Special. Weight is much of the reason why Crosslin went to a TCM IO-360, which is lighter and a much more efficient engine with fuel injection and a constant speed prop. |
"Richard Riley" wrote in message :What I'd like to ask is how the price of an O-470 Conintental would :compare to an O-320 Lycoming. I suspect the RV demand for the O-320 :has kept the price up. But there aren't that many planes that use an O-470. I thought it might even be less expensive as a result of lower :demand? You might be able to get one of these cheap How many Cessna 180's and 182's were built? All of the older ones use this engine. Good luck, Skyking |
Skyking wrote:
"Richard Riley" wrote in message :What I'd like to ask is how the price of an O-470 Conintental would :compare to an O-320 Lycoming. I suspect the RV demand for the O-320 :has kept the price up. But there aren't that many planes that use an O-470. I thought it might even be less expensive as a result of lower :demand? You might be able to get one of these cheap How many Cessna 180's and 182's were built? All of the older ones use this engine. Good luck, Skyking Sorry, your Highness, I should have said 'homebuilt' plans... mia cuppa. Richard |
On Thu, 08 Jul 2004 13:22:55 GMT, Richard Lamb
wrote: Not to labor the obvious, but there IS a little size difference between 4.6 liter and 470 cubic inches... Richard (no substitute for cubes) Lamb If we are talking about the same engine, the Buick/Olds aluminum V8, it's lots worse than that. The original engine was 215 cubic inches in displacement. That's 3.5 Liters. By the way, the 3.8L Ford V6 engined Pawnee being used in Australia as a glider tug is spinning the prop (via Blanton type PSRU) originally used by the Pawnee when it had it's original engine which I believe was an 0-470. It's spinning it at **exactly** the same prop rpm the 0-470 spun it. What does that tell you about power? But it uses way less gas doing it. Before BOb steps in and makes a comment, let me add that most of the reason for the reduction in fuel burn is due to the method of flying and the fuel mixture. The tug hauls the glider up to it's drop point, then closes the throttle to idle and returns to the field with the engine staying at idle the whole way. When the 0-470 was used, the throttle was never closed for descent (shock cooling doncha know) and who knows if the mixture was leaned during the return. In addition, it's possible that the carburator mixture runs normally more lean than the carburator mixture at full rich with the 0-470. This is possible with the Ford because variable automatic timing can still be used. Magneto timing must be preset at around 26 degrees before top dead center and does not move. In order to get the Peak Pressure Point of the combustion process to occur at 16 degrees past top dead center (rather than closer to top dead center which increases pressure and heat) the combustion process must be slowed somehow. Engineers achieved this by making the mixture overrich for takeoff and climb. But since the Ford engine can vary the timing automatically (if the builder uses a distributer or electronic ignition that allows this), the timing is always where it needs to be to have the PPP occur where it needs to for proper engine power. An overly rich mixture is not necessary to achieve this. Corky Scott |
On Thu, 08 Jul 2004 13:28:07 GMT, Richard Lamb
wrote: Sorry, your Highness, I should have said 'homebuilt' plans... mia cuppa. Richard +++++++++++++++++++++++++++++++++++ Is that the same as 'mea culpa'... with a Texass accent? g Barnyard BOb - the Show Me State |
Barnyard BOb - wrote:
On Thu, 08 Jul 2004 13:28:07 GMT, Richard Lamb wrote: Sorry, your Highness, I should have said 'homebuilt' plans... mia cuppa. Richard +++++++++++++++++++++++++++++++++++ Is that the same as 'mea culpa'... with a Texass accent? g Barnyard BOb - the Show Me State Might have been that liddle lady in the movies... I know she's guilty of _something_! |
Similar Threads | ||||
Dennis Fetters Mini 500 | EmailMe | Home Built | 70 | June 21st 04 09:36 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 04:46 AM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
Gasflow of VW engine | Veeduber | Home Built | 4 | July 14th 03 08:06 AM |
