iPaq screen viewability
Old July 14th 03, 08:33 PM
Raphael Warshaw
"Eric" wrote in message
m...
Yesterday was my first flight with my new iPaq 3955 with WinPilot --
the screen viewability was not what I'd hoped.
At first, I positioned the iPaq on the instrument panel, near vertical
but tilting up slightly to directly face me. But, with the sun
directly overhead, I could hardly see the display. Glare wasn't the
problem, the display just seemed dark (like looking at an LCD off
angle). Note that I'm powering the iPaq externally with its backlight
set to maximum.
Later, I pulled the iPaq down and put it on my leg, near horizontal
but tilting up slightly so and looking at the display at somewhat less
than a straight on, 90 degree angle. With the sun shining down on the
screen, it was MUCH better, almost as if the sun's light and the
screen's reflectivity were working together.
Still, I'd rather have the iPaq attached to the instrument panel
rather than another thing attached to my body in the cockpit (O2,
water tube, etc.). Any ideas?
Old July 14th 03, 08:37 PM
Raphael Warshaw
I've got mine mounted to the cockpit rail with a ball-joint mount. This
places the screen just under my right hand at a good viewing angle. The
downside is that I have to remove the cradle to get in or out without
turning the cradle on it's mount, which destroys the ball after a few
entries/exits. It poses no impedement to rapid egress, just tears up the
ball & socket.
Ray Warshaw
m...
set to maximum.
Old July 14th 03, 08:39 PM
Eric
Default iPaq screen viewability
set to maximum.
Old July 15th 03, 06:13 AM
Ian Fevrier
In addition to mounting the IPAQ about mid distance along the canopy rail,
I find that using the plain white background instead of the terrain map
really helps.
"Raphael Warshaw" wrote in message ...
m...
set to maximum.
Old July 15th 03, 03:35 PM
rhpf
For a similar product ClearTouch in the US see the link on the bottom of
Craggy Aero's Homepage. www.craggyaero.com. I have tried these protectors
and the screen visibility is significantly better.
Richard
www.craggyaero.com
"ch" wrote in message
I use a very good product for my iPaq3970 in my glider
You can see the product on the web page
http://shop.brando.com.hk/screenprotector.php
in Australia it is sold through
Mr. Simon
I have no reflections at all anymore and screen visibility
is good also watching slightly from the side.
Chris
m...
set to maximum.
Old July 16th 03, 04:22 PM
rhpf
Today when I turned on my Ipaq the screen was really dark, after fusting
around for several minutes I found on the Start - Settings - System -
Backlight - Brightness page (the automatic box was checked) I unchecked and
the screen brightened up.
Richard
www.craggyaero.com
m...
set to maximum.
Old July 27th 03, 06:02 PM
JohnD
I also had problems seeing my Ipaq and had to keep it on my lap much
of the time. The ClearTouch worked great (Thanks Richard@CraggyAero)
along with removing the terrrain from the display, I can SEE the
terrain outside the cockpit & don't need it on Winpilot. One point
however, with terrain off it seems the AGL altitude in the NAV BOX no
longer works.
But I have to say I could not believe the $12.95 package only included
ONE screen saver. What are these things made of?
Thanks for the sloutions, they solved the problem.
Go
"Jim Kelly" wrote in message . au...
Hi Richard,
Same page . . every now and again . . I have seen those sliders right
on the bottom, hence no backlight! Worth remembering.
Cheers,
Jim Kelly.
"rhpf" wrote in message
fusting
System -
unchecked and
| Richard
| www.craggyaero.com
| m...
WinPilot --
vertical
backlight
| set to maximum.
horizontal
less
HELP !!..."full Screen View" in FS9 ? Cant get it ? Derek Simulators 3 October 26th 08 01:35 AM
painted airtight window screen as a "surface" Allan Morrison Home Built 3 February 19th 05 03:40 AM
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). Phillip Rhodes Military Aviation 0 September 7th 04 01:30 PM
Garmin 195 screen problem BPattonsoa Home Built 30 December 3rd 03 02:14 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
