The logic behind fishmouth vice 30* ?
Old August 8th 09, 04:39 PM posted to rec.aviation.homebuilt
Michael Horowitz
Default The logic behind fishmouth vice 30* ?
Looking thru 43.13, I see splices that use fishmouths and I see others
where the outer sleeve is simply cut at a 30* angle.
Can someone discuss the logic of why they use one cut over the other?
- Mike
Old August 8th 09, 05:04 PM posted to rec.aviation.homebuilt
jerry wass
- Mike
fishmouth takes up less linear space on the tube---(fits in a smaller
space) 30° is easier to weld.
Old August 8th 09, 06:21 PM posted to rec.aviation.homebuilt
Michael Horowitz
On Sat, 08 Aug 2009 16:04:45 GMT, Jerry Wass
- Mike
No mechanical considerations then? just two way of doing the same
thing? - Mike
Old August 8th 09, 11:11 PM posted to rec.aviation.homebuilt
canuck_bob
I read somewhere, maybe Bingelis, that the fishmouth makes it easier
to weld if the tubing splice isn't a tight fit. Sorry no reference
for that, I just filed it away after reading.
Bob
Old August 10th 09, 11:39 AM posted to rec.aviation.homebuilt
Michael Horowitz
On Sat, 08 Aug 2009 11:39:47 -0400, Michael Horowitz
- Mike
I got a good answer from an instructor who teaches A&P candidates.
Use either one. The fishmouth is for when you don't have enough room.
- Mike
Bucking bar and vice mhorowit Home Built 7 September 6th 08 08:27 PM
PLEASE SIGN THE MITT ROMNEY FOR VICE PRESIDENT PETITION! Publius1787 Naval Aviation 0 April 8th 08 05:01 PM
Boeing Vice President To Speak (Available On-line) Larry Dighera Piloting 0 March 13th 08 08:46 PM
Air Vice Marshal Tony Dudgeon Keith Willshaw Military Aviation 0 January 9th 04 12:43 PM
What is the reasoning behind the smaller radius vice presidential TFR? Larry Dighera Piloting 38 November 19th 03 04:04 PM
