ILS critical area when the tower is closed?
Old November 27th 05, 02:06 AM posted to rec.aviation.ifr
Default ILS critical area when the tower is closed?
"Steven P. McNicoll" wrote in
ink.net:
"Jose" wrote in message
Should those mistakes happen at an airport with an operating control
tower, the tower controller would catch the error and "nudge the
airplane back where it belongs".
Only if he can see the airplane. That's frequently not possible in
reduced visibility situations, such as those that would necessitate an
ILS approach in the first place.
Is the control tower at your field 800'AGL?
  #112
Old November 27th 05, 02:08 AM posted to rec.aviation.ifr
ink.net:
"Judah" wrote in message
1) Self-Serve fuel. Many airports have it. They even take credit
cards.
Yes, but most airports do not have self-serve fuel. At most airports
with fuel service the fuel vendor is a person.
At most of these airports, the fuel vendor person arrives before the Tower
opens, specifically to service the planes that will be taking off first.
It's pretty much the sensible thing to do. If they show up at the same time
that the tower opens, they won't be able to get the planes ready until
later.
  #113
Old November 27th 05, 02:11 AM posted to rec.aviation.ifr
Nope.
  #114
Old November 27th 05, 02:13 AM posted to rec.aviation.ifr
time
later.
How many of those airports park the aircraft to be fueled within the ILS
critical areas?
  #115
Old November 27th 05, 03:08 AM posted to rec.aviation.ifr
In article et,
"Steven P. McNicoll" wrote:
"john smith" wrote in message
I can fly all day in 800/2 in my Champ.
All I need is 1 sm and clear of clouds.
At 70 mph, it takes a while to get anywhere.
Perhaps all night, but probably not all day. The operating hours of
part-time towers tend to be the daytime hours, so the hours that you can fly
with only one mile visibility while remaining clear of clouds tend to be
just the nighttime hours. Your Champ' will be limited to operating in an
airport traffic pattern within 1/2 mile of the runway, assuming it has the
required lighting.
For CB/CC/CDAS, yes.
Some CDAS will give you a Special if you ask for it.
  #116
Old November 27th 05, 03:15 AM posted to rec.aviation.ifr
No, for Class G airspace.
Class D airspace when the tower is closed? Special VFR is available only in
a surface area, but SVFR also requires separation from IFR aircraft.
  #117
Old November 27th 05, 01:58 PM posted to rec.aviation.ifr
ink.net:
Tower opens, specifically to service the planes that will be taking
off first. It's pretty much the sensible thing to do. If they show up
at the same time
until later.
ILS critical areas?
The OP did not suggest that planes parked in the ILS Critical areas.
Here's the original quote:
People may be taxiing around the airport with no intention of taking off,
for example, to fuel up, to do maintanance, or to more the aircraft.
Come on now, Steven. Either I'm getting better at this, or you're pulling a
me.
  #118
Old December 1st 05, 02:52 AM posted to rec.aviation.ifr
the weather is below 800/2, in which case only IFR departures
will be of concern
off, for example, to fuel up, to do maintanance, or to more the aircraft.
I suppose such an aircraft could call departure first, to ensure that
such operation will not interfere with anybody on approach.
Jose
I still would like someone to explain how this does not reinforce the
original poster's question.. Suppose someone just needs to taxi around near
the approach end of the rwy. they can, yes? nobody to stop them?
Mike Teague - Vancouver WA, USA
-- Opie and Anthony - XM202 - O&A Party Rock!
-- Phil Hendrie = Radio Genius
comment period reopened on DC area "ADIZ" Bob Noel Piloting 3 November 15th 05 04:39 PM
Los Angeles radio tower crash kills 2 Paul Hirose Piloting 178 August 6th 05 03:46 PM
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
ILS Critical Area signage: Localizer or Glideslope? Adam K. Instrument Flight Rules 4 October 30th 03 10:09 PM
Patrick AFB Area Log, Monday 30 June 2003 AllanStern Military Aviation 0 July 1st 03 06:37 AM
