#21
Typical glider service lives?
On Friday, November 23, 2018 at 7:53:22 AM UTC-8, Boise Pilot wrote:
The three Blanik L-13's that just returned to service after having the world fleet grounding AD repaired now have 6,000 hour service life. Boise Pilot Is that 6,000 hours from the date of the recent factory rebuild or 6,000 total time from when they were first manufactured? I've been seriously considering getting back into an L-13 in the future. The AD&C mod has been accepted in Canada for quite a while but as far as I could tell it only allowed 5,000 hours total time from date of initial manufacture so the cost would have been hard to sustain unless I could have found an L-13 with under 2,000 hours total time. The factory rebuild and mod seems much more promising, so long as I can find a decent L-13 when the time comes. As long as I have a better flying year in 2019 I should be looking into doing the 3,000 hour inspection on my ASW-15B fairly soon. |
From Grob Astir CS Maint Manual.
Inspection Procedures for Increase of Service Time 1. General The results of fatigue tests of wing spar sections have demonstrated recently that the service time of GRP gliders and motor gliders may be extended to 6000 hours, if for each individual glider (in addition to the obligatory annual inspections) the airworthiness is demonstrated according to a special multi-step inspection program particularly with regard to the service life. 2. Time limits When the glider has reached a service time of 3000 hours, an inspection must be done in accordance with the inspection program mentioned under point 3. If the results of this inspection are positive or if any defects found have been duly repaired, the service time of the glider is extended by another 3000 hours to a total of 6000 hours (first step). The above inspection program must be repeated when the glider has reached a service time of 6000 hours. If the results of this inspection are positive or if any defects found have been duly repaired, the service time of the glider is extended to 7000 hours (second step). When the glider has reached a service time of 7000 hours, the above inspection program again must be repeated. If the results of the inspection are still positive or if any defects found have been duly repaired, the service time may be extended to a total of 8000 hours (third step). The gradual extension of service life will be performed by steps of 1000 flight hours up to maximum 12 000 flight hours at this time (4th – 7th stage). Additionally at 9500, 10500, 11500 operating hours, inspection of the wing connection bolts and main spars spigots must be performed accordance to Service Bulletin TM 306-30, latest edition, action 7. And the multi step inspection is straight forward, simple. Just need form from type holder. |
Similar Threads | ||||
Glider hauling service | Retting | Soaring | 1 | October 15th 17 10:27 PM |
Typical glider depreciation? | David Reitter | Soaring | 14 | September 16th 11 12:34 AM |
Typical glider & trailer total weight? | Roger Worden[_2_] | Soaring | 9 | February 8th 10 02:24 AM |
SPOT messenger free for Glider Pilots w/ service purchase | [email protected] | Soaring | 0 | August 12th 08 11:28 PM |
Jews kill secret service workers for saving lives . . . | Jean-Paul Roy | Restoration | 0 | July 12th 03 12:55 PM |
