VFR Practise Approaches
Old September 22nd 10, 12:16 PM
ChristianFro ChristianFro is offline
Junior Member
First recorded activity by AviationBanter: Sep 2010
Default VFR Practise Approaches
If an approach says DME required but I dont have DME, can I still execute a VFR practise approach?
On GPS (RNAV) approaches, can I deviate from the published procedures with permission from the Tower or controlling agency if I am doing a VFR practise approach? I.E. Altitude deviation for a fix.
If so, what is the reference?
Thanks in advance.
Old September 22nd 10, 09:51 PM posted to rec.aviation.ifr
Mike Adams[_2_]
Are you asking can you do it legally, or are you just asking if it's possible? Legally, remember you're
VFR, so the IFR procedure rules don't really apply. If you are following the approach procedure (3D path
over the ground) and not causing a problem for ATC, they can't see what's on your panel.
OTOH, if you need DME distance to identify a step-down fix or missed approach point, it may be difficult
to fly the procedure correctly without it.
Also bear in mind you can use GPS in lieu of DME in most cases.
If you have permission from ATC, and aren't causing a safety problem (terrain or traffic separation), I
don't see an issue. Remember, you are VFR.
Not sure.
Mike
Old September 23rd 10, 12:22 AM posted to rec.aviation.ifr
Mxsmanic
As long as you are under VFR in VMC, you can do what you want, provided that
it does not conflict with ATC instructions (if you are in airspace where ATC
instructions take priority). You need not say anything to ATC about it, since
you are still legally VFR. Just take care that it does not conflict with other
traffic--in busy airspace you may have to obtain ATC's approval and
cooperation to allow this.
For example, if you are told to make straight in to the airport and you wish
to capture and follow the ILS for your approach, nothing prevents you from
doing so, and it's legal as long as the primary means of navigation remains
VFR. If you are told to enter the pattern but you wish to practice with the
ILS, you'll have to request and coordinate that with ATC.
Note that ATC may not provide separation services to VFR aircraft practicing
instrument approaches, and approval for a practice instrument approach does
not include approval for the missed-approach procedure unless this is
explicitly requested from and approved by ATC. Your VFR responsibility to see
and avoid is not suspended by approval for a practice IFR approach.
Old September 26th 10, 05:33 PM posted to rec.aviation.ifr
VFR.
NOT ALWAYS......
Old September 27th 10, 03:53 PM posted to rec.aviation.ifr
On Sep 26, 4:58*pm, Mxsmanic wrote:
writes:
VFR.
NOT ALWAYS......
Describe the exceptions, then.
NO
Old October 2nd 10, 01:07 AM posted to rec.aviation.ifr
Brian Whatcott
Thanks in advance.
In VMC, there are VFR approaches, and practice IFR approaches.
In IMC there are IFR approaches. Full stop.
Required equipment for VFR approaches are one pair regulation eye-balls,
an ASI, altimeter and compass. A radio is helpful.
Brian W
Old October 2nd 10, 02:46 AM posted to rec.aviation.ifr
Brian,
I think it's ATC facility dependent for IFR approaches and full stops.
I get touch and goes on IFR approaches on IFR clearances routinely my
neck of the woods.
Touch and goes also can be done on IFR XC round robins. Just file to
a fix at the destination airport, pick up the approach clearance and
fly back home after the touch and go.
Old October 2nd 10, 02:48 PM posted to rec.aviation.ifr
Brian,
neck of the woods.
Touch and goes also can be done on IFR XC round robins. *Just file to
"Full stop" is British for "Period."
Don Poitras
Ahh, thanks! Never knew :-)
LAS approaches Ron Garret Instrument Flight Rules 10 March 28th 09 06:46 AM
My First GPS Approaches john smith Instrument Flight Rules 10 November 9th 04 09:14 PM
ILS PRM approaches Riddler Instrument Flight Rules 2 October 28th 04 12:37 PM
Channel News Asia: Taiwan Jets Practise Emergency Landings on Freeway Amid Tensions with China Dionaea muscipula Military Aviation 0 July 21st 04 08:18 AM
NDB approaches -- what are they good for? Dylan Smith Instrument Flight Rules 15 July 10th 03 09:15 PM
