Would you do it?
http://tinyurl.com/3dy4ot
As a new turbo owner, I'm leary of fixing what ain't broken. Would you get the timing bumped 3 degrees if it were yours? -- Dan T-182T at BFM |
Would you do it?
Not Timothy...
"leery" |
Would you do it?
On 6/19/2007 6:21:44 PM, "Dan Luke" wrote:
Would you get the timing bumped 3 degrees if it were yours? I am a sucker for the words, "a slight increase in engine performance..." so yes, I would. In the hands of a competent mechanic I don't see the task of changing engine timing as being risky, but then again I could be a fool. -- Peter |
Would you do it?
"Dan Luke" wrote in message ... http://tinyurl.com/3dy4ot As a new turbo owner, I'm leary of fixing what ain't broken. Would you get the timing bumped 3 degrees if it were yours? Is the engine still under warranty? Have you inquired, just for giggles, what Lycoming would have to say? |
Would you do it?
"Matt Barrow" wrote in message
... "Dan Luke" wrote in message ... http://tinyurl.com/3dy4ot As a new turbo owner, I'm leary of fixing what ain't broken. Would you get the timing bumped 3 degrees if it were yours? Is the engine still under warranty? Have you inquired, just for giggles, what Lycoming would have to say? The link points to a Lycoming Service Instruction pdf. |
Would you do it?
"El Maximo" wrote in message ... "Matt Barrow" wrote in message ... "Dan Luke" wrote in message ... http://tinyurl.com/3dy4ot As a new turbo owner, I'm leary of fixing what ain't broken. Would you get the timing bumped 3 degrees if it were yours? Is the engine still under warranty? Have you inquired, just for giggles, what Lycoming would have to say? The link points to a Lycoming Service Instruction pdf. Missed that in all the blue text. Thanks |
Would you do it?
"Dan Luke" wrote in message ... http://tinyurl.com/3dy4ot As a new turbo owner, I'm leary of fixing what ain't broken. Would you get the timing bumped 3 degrees if it were yours? -- Dan T-182T at BFM Yes...did you check the data plate, maybe already done? |
Would you do it?
"Blueskies" wrote: Yes...did you check the data plate, maybe already done? Nope. Will do Saturday. -- Dan T-182T at BFM |
