Can vacuum AI be removed if a certified electric one is installed??
Old January 12th 04, 05:48 AM
Bill
First off, you're getting a lot of bad info here. There is NO
requirement for redundancy for IFR under Part 91. It's perfectly
legal (though not too smart) to have all three required gyros powered
from the same non-redundant source. In fact, it used to be pretty
common to have airplanes that were IFR certified equipped with all
three gyros driven by vacuum. The TriPacers with the advanced panel
actually came that way from the factory.
Don't forget that there are operational FARs like you quote and
airworthiness FARs. For example, if the instruments are converted to all
electric, then look at 23.1331 Instruments Using A Power Source - For each
instrument that uses a power source, the following apply: (c) There must be
at least two independent sources of power ... and a manual or automatic
means to select each power source.
The original poster's airplane is certificated under CAR3 and not FAR23 and
so 21.101 could be applicable if this modification was performed by STC.
Old January 12th 04, 06:08 PM
Michael
However, no STC is required to perform the modification, so 21.101 is
inapplicable. 23.1331 is also inapplicable, and you will note that
most airplanes currently in service do not meet it.
In other words, none of this means anything.
Michael
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Newbie Question - Vacuum vs Electric Bill Denton Aerobatics 1 April 15th 04 11:30 PM
