what is that noise?
Old July 22nd 19, 06:38 PM posted to rec.aviation.soaring
Mike C
Default what is that noise?
On Monday, July 22, 2019 at 4:39:11 AM UTC-6, gregv wrote:
Hello, I fly a 1979 Nimbus 2 carbon, and since a few years I hear a cracking noise behind me. That noise occurs more often after a few hours of flight, maybe related to temperature change with altitude. You can hear the cracking noise in this video:
https://www.youtube.com/watch?v=pke-...ature=youtu.be
Did you already hear that noise? how do you think I can fix this ? do you think it is dangerous?
Thank you for help and advice
Sounds like the rain I was thermalling in on Saturday. ;^)
Old July 22nd 19, 06:39 PM posted to rec.aviation.soaring
Glidingstuff[_2_]
Check the incidence pins and bearings on the wings and fuse. They may have worn and are allowing the wing to move fore and aft as well as slightly up and down. We had the same issue with an ASH 25. Sounded exactly the same. After replacing worn pins on inner panel noise disappeared.
Paul
Old July 22nd 19, 09:46 PM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
What a bunch of hypochondriacs it's the gear door slapping . Change the damn bungees .
Old July 23rd 19, 12:16 AM posted to rec.aviation.soaring
Craig Funston[_3_]
On Monday, July 22, 2019 at 7:29:40 AM UTC-7, son_of_flubber wrote:
Count your blessings. I have a howling banshee in my tail boom.
Flub, what are you flying. I removed the V seals in my Nimbus 3 rudder one year and the banshee took up residence at speeds over 90 kts. Once they were replaced, the banshee was banished.
Cheers,
Craig JN
Old July 23rd 19, 03:32 AM posted to rec.aviation.soaring
They usually change sound if you "rudder it a bit" in straight flight. More often than not, one bungee fails/weakens before the other. A yaw will tend to suck a door open if the bungee is weak.
Sorta like figuring out a failing wheel bearing in a car. Wide open road, do big S turns to load each side.....the loud side has the bad bearing.....
Old July 23rd 19, 08:07 PM posted to rec.aviation.soaring
I would agree to take that noise off your hands if you can give me those views along with it. :-)
Gary Osoba
Old July 24th 19, 05:31 AM posted to rec.aviation.soaring
ian
I used to fly a Nimbus, original II (without b or c). It was noticeably
noisy but maybe not the same sounds as yours. I would start by looking
for the obvious, check every piece of tape on the glider, over joints,
control surface hings and U/C doors etc.
Old July 24th 19, 11:38 PM posted to rec.aviation.soaring
Bob Kuykendall
One thing to try is applying rudder each way during straight and level flight, and see if that causes the noise. If so, the noise might be caused by the lift pins working in their sockets.
There is also remote chance chance that it might be a loose joint between the steel mid-fuselage cage and where it attaches to the composite fuselage shell. It's unlikely unless the ship has a damage history involving a very hard landing or a ground loop. But you might have your mechanic or tech take a good look at it during the next condition inspection.
--Bob K.
Old July 25th 19, 02:51 PM posted to rec.aviation.soaring
Vaughn Simon[_2_]
I always that that one of the advantages of airplanes over gliders is
that an airplane engine masks those potentially-concerning noises that
virtually all airframes make as they deal with normal flight loads.
Vaughn
This email has been checked for viruses by AVG.
https://www.avg.com
Old July 25th 19, 04:03 PM posted to rec.aviation.soaring
The sound does not seem to me to be the usual lift pin type noise. I could not associate with apparent changes in loading of the ship.
For the heck of it I'd look for something in the ventilation system.
UH
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Piloting 26 January 13th 07 12:06 AM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Instrument Flight Rules 15 January 13th 07 12:06 AM
Prop noise vs. engine noise Morgans Piloting 8 December 24th 03 03:24 AM
noise G.A. Seguin Soaring 2 August 27th 03 01:57 AM
Com noise Hankal Piloting 0 July 21st 03 12:54 AM
