IFR with a VFR GPS
Old November 9th 05, 01:51 AM
Wizard of Draws
Default IFR with a VFR GPS
OK, I broke down and sprung for the Lowrance Airmap 2000c instead of the
1000. Wow.
Normally I rent a plane that has a panel-mounted IFR certified Garmin 430,
but that may change due to circumstances beyond my control in a few months.
Obviously I can't file /G IFR without a proper IFR GPS, but this one will be
used as a backup and for cross-reference at the very least.
So...do I tell a briefer to note that I have a VFR GPS and will the
controllers take note, sending me direct, off airways? Will it make any
difference to them at all? Given the fact that nearly everyone has one
nowadays, will they assume I have a GPS even if I don't indicate it?
Jeff 'The Wizard of Draws' Bucchino
Cartoons with a Touch of Magic
http://www.wizardofdraws.com
More Cartoons with a Touch of Magic
http://www.cartoonclipart.com
Old November 9th 05, 02:11 AM
Bob Gardner
Tell them. Just as is the case with icing certification, the controllers are
not into law enforcement. Tell them you have a GPS and you will get all of
the benefits.
Bob Gardner
"Wizard of Draws" wrote in message
news:BF96C057.43EB4%jeffbREMOVE@REMOVEwizardofdraw s.com...
1000. Wow.
months.
be
Old November 9th 05, 02:32 AM
A Lieberman
the benefits.
Wouldn't it look odd if you file /a and request Direct?
Doesn't the GPS have to be en route certified? Heck the Garmin 296 has all
the approaches, but does not have the victor highways that I could see.
What would happen if your clearance got changed en route?
Or does that not happen when you file direct and fly off the airways?
Allen
Old November 9th 05, 03:14 AM
Dan Luke
controllers are
all of
the benefits.
Nope.
has all
see.
I'd put the NAVAIDS and intersections in the 296 and use it as an "aid
to situational awareness" as I flew the clearance.
It happens often, especially when you fly into big city airspace. I
always get cleared direct from Mobile to Houston or Dallas, but then
Center always amends my clearance before I get to the Bravo airspace.
Dan
C172RG at BFM
Old November 9th 05, 03:39 AM
A Lieberman
On Tue, 8 Nov 2005 21:14:11 -0600, Dan Luke wrote:
Hey Dan,
Thanks for responding.
Can I assume that the amendment would be vectors to an approach or an
arrival procedure where ATC will vector you?
Or is it assumed you will know how to get on the airway from a non standard
"entry" from a direct routing you are on?
I ask this as I am planning a trip up to Ohio which would take me through
Cincinnati Bravo from Owensboro KY to Stuebenville Ohio.
I would assume, that I get my clearance direct from OWB to 2G2, but expect
vectors in and around Cincy Bravo "for traffic". Would this be the
amendment you would be talking about?
Allen
Old November 9th 05, 04:20 AM
Dan Luke
Yes. Going into HOU or DAL it's usually a STAR.
standard
Well, I've never been directed to join an airway without being given a
heading to fly to do it. If ATC has a route change for you, it will
usually begin with a fix, such as "direct Gregg County (VOR), DUMPY2
arrival, direct."
through
expect
Well, vectors for traffic can happen any time in busy airspace, but
usually don't involve route waypoint changes. Once the traffic is no
factor, they'll tell you to resume own navigation, IOW, head for the
next fix or get back on the airway, if that was your clearance.
However, the TRACON might have regular routes for transients to fly
through parts of its airspace. If that's the case, you'll probably be
given the change before you get there. That will give you a little time
to set up your NAV gear.
If you're not landing there or busting through one of their approach or
departure corridors, you may not get any change at all.
Dan
C172RG at BFM
Old November 9th 05, 03:41 AM
Steven P. McNicoll
"A Lieberman" wrote in message
It's done regularly and has been for years.
Nope.
The same thing that happens without GPS. You fly a new clearance.
Old November 18th 05, 11:27 PM posted to rec.aviation.ifr
On Tue, 8 Nov 2005 20:32:01 -0600, A Lieberman
the benefits.
I always file /I
www.rogerhalstead.com
Allen
Old November 19th 05, 06:16 AM posted to rec.aviation.ifr
"Roger" wrote in message
I always file /I
For GPS?
Old November 19th 05, 11:36 PM posted to rec.aviation.ifr
On Sat, 19 Nov 2005 06:16:22 GMT, "Steven P. McNicoll"
I always file /I
For GPS?
Well, I do fly by my hand held, but the airplane has RNAV.
