Total Air Temperature question
"Peter" wrote in message
... I fly a TB20 and a friend who has the same one with a Shadin air data computer tells me that he normally gets (say 160 ktas, 10k feet, ISA) a TAT value of about 3 degC higher than that returned by the existing OAT sensor. This raises two questions: 1) Can one really get a 3 degC difference at such a low speed? I recall a long thread here from some years ago where it was suggested the increase is below 1 degC. a) 3 degC is exactly what you'd expect between SAT (the temperature of the air as measured by a thermometer at rest) and Total Air Temperature at 160 KTAS (and it's approximately quadratic in speed) but b) Mike is, of course, quite right in suggesting that the "existing OAT sensor" is not measuring the SAT! It too is affected by the compression heating of the air. 2) What is the use of TAT in the context of icing? Presumably the temp rise will vary over different parts of the aircraft. Neglecting lift for a moment, there are two extremes for the temperature of the aircraft. Where the air is brought completely to rest, the stagnation points, the temperature should be the TAT. The air itself outside the boundary layer is at the SAT. Other parts of the aircraft will have temperatures in between. If the part is a flat wall parallel to the airflow and has no heating or cooling other than from the air, it will be heated above the SAT by about 85% (the recovery factor) of the TAT-SAT. The recovery factor for a thermometer placed elsewhere will depend on its location and geometry, but generally speaking the thermometer will measure an OAT closer to the TAT than the SAT. For a conducting skin, it's a fair approximation that the skin will be at the TAT. Where the pressure is lowered, for example on the upper surface of the wing, the temperature also falls because of that. Thus it is possible for runback to freeze with the TAT above freezing. The cooling effect depends on wing loading: for a typical light aircraft the effect will not exceed 1 degC, while for big jets, you may find a part of the wing 10 degC cooler than the sensed OAT. Julian Scarfe |
Julian, do you know the meaning of "True Air Temperature"? I don't but this
is supposedly what the Shadin ADC outputs. See: http://www.shadin.com/specs/adc_200.htm Mike MU-2 "Julian Scarfe" wrote in message ... "Peter" wrote in message ... I fly a TB20 and a friend who has the same one with a Shadin air data computer tells me that he normally gets (say 160 ktas, 10k feet, ISA) a TAT value of about 3 degC higher than that returned by the existing OAT sensor. This raises two questions: 1) Can one really get a 3 degC difference at such a low speed? I recall a long thread here from some years ago where it was suggested the increase is below 1 degC. a) 3 degC is exactly what you'd expect between SAT (the temperature of the air as measured by a thermometer at rest) and Total Air Temperature at 160 KTAS (and it's approximately quadratic in speed) but b) Mike is, of course, quite right in suggesting that the "existing OAT sensor" is not measuring the SAT! It too is affected by the compression heating of the air. 2) What is the use of TAT in the context of icing? Presumably the temp rise will vary over different parts of the aircraft. Neglecting lift for a moment, there are two extremes for the temperature of the aircraft. Where the air is brought completely to rest, the stagnation points, the temperature should be the TAT. The air itself outside the boundary layer is at the SAT. Other parts of the aircraft will have temperatures in between. If the part is a flat wall parallel to the airflow and has no heating or cooling other than from the air, it will be heated above the SAT by about 85% (the recovery factor) of the TAT-SAT. The recovery factor for a thermometer placed elsewhere will depend on its location and geometry, but generally speaking the thermometer will measure an OAT closer to the TAT than the SAT. For a conducting skin, it's a fair approximation that the skin will be at the TAT. Where the pressure is lowered, for example on the upper surface of the wing, the temperature also falls because of that. Thus it is possible for runback to freeze with the TAT above freezing. The cooling effect depends on wing loading: for a typical light aircraft the effect will not exceed 1 degC, while for big jets, you may find a part of the wing 10 degC cooler than the sensed OAT. Julian Scarfe |
"Mike Rapoport" wrote in message
ink.net... Julian, do you know the meaning of "True Air Temperature"? I don't but this is supposedly what the Shadin ADC outputs. See: http://www.shadin.com/specs/adc_200.htm I don't, I'm afraid. Like you, I've not come across True Air Temperature before. I looked briefly at a couple of the brochures on the Shadin site after you posted, and saw mention of True Air Temperature in one, Total Air Temperature in another. Maybe Peter knows which model the ADC was? Julian |
"Peter" wrote in message ... "Julian Scarfe" wrote I looked briefly at a couple of the brochures on the Shadin site after you posted, and saw mention of True Air Temperature in one, Total Air Temperature in another. Maybe Peter knows which model the ADC was? I am no nearer to the truth... The owner of the Shadin ADC doesn't know which model he has. In the KLN94B manual, page 5-39, which describes the page which becomes operational when an ADC is connected, it says SAT Static air temperature (the actual temperature of the surrounding air mass). TAT Total air temperature (the air temperature including heat rise due to compressibility. This is the temperature measured directly by the outside air temperature (OAT) probe. Prs Pressure altitude (to nearest 100 feet or 10 meters). Den Density altitude (to nearest 100 feet 10 meters). which doesn't make a lot of sense because when the ADC is fitted, there is a 2nd OAT probe. Either way, the Shadin should be reading the same or lower than the OEM OAT guage. I am flying on Wednesday and if the opportunity presents itself (VFR here in the PNW) I will try leveling off recording the spread between the OAT guage and the temp displayed by the Shadin at two different speeds to verify that the spread widens as speed increases. Mike MU-2 |
"Peter" wrote in message news "Mike Rapoport" wrote: Either way, the Shadin should be reading the same or lower than the OEM OAT guage. I am sorry but I still don't get that. Total Air Temp should be SAT, adjusted UPwards for the airflow heating. But different parts of the aircraft will have different mach numbers. Which bit is TAT supposed to represent? Exactly, TAT represents SAT adjusted upwards for Mach. The problem with your senario (160ktas, 10K', ISA and Shadin reads 3C higher) ) is that the difference in readings is the same as the *total* calculated difference between SAT and TAT. The OAT guage would need to have a local flow of *zero* and the Shadin would need to have a local flow equal to the freestream Mach number. Think about it this way: Possibility #1 Both OEM OAT and Shadin displaying TAT and Shadin reads 3C higher (stated condition) Since total difference between SAT and TAT is 3C (calculated by Julian earlier in thread) and the Shadin reads 3C higher, for the OEM guage to be reading correctly the mach number at its location would have to be 0. To be exact, the difference in Mach number has to be exactly the same as the speed of the airplane, pretty unlikely. Possibility #2 The OEM OAT is displaying TAT and the Shadin is displaying SAT. SAT is always lower than TAT so the Shadin should show a lower temp. You could be right, which would presumably mean the stock OAT probe has a higher mach number than anything else. Two possibilities, either the airflow over the OEM OAT probe is zero or one (or both) temperature readings are inaccurate, a much more likely senario. Mike MU-2 |
"Peter" wrote in message ... I need to wait for a reply from Shadin as to what their "True Air Temp" is supposed to mean. Lets us know what they say. Mike MU-2 |
Thanks. This is consistant with what I observe in my airplane. It is
unfortunate that they chose to name things differently from everyone else, and particularly inappropriate to use TAT to mean SAT when there is a "TAT" in common use. Mike MU-2 "Peter" wrote in message ... "Mike Rapoport" wrote I need to wait for a reply from Shadin as to what their "True Air Temp" is supposed to mean. Lets us know what they say. Shadin's reply: Shadin's OAT = = Other's TAT (Total Air Temp) Shadin's TAT (True Air Temp) = = Other's SAT (Static Air Temp) They also sent me the installation manuals for models 200 and 2000. Peter. -- Return address is invalid to help stop junk mail. E-mail replies to but remove the X and the Y. Please do NOT copy usenet posts to email - it is NOT necessary. |
Similar Threads | ||||
Total Air Temperature question | Mike Rapoport | Instrument Flight Rules | 12 | December 14th 04 06:20 PM |
Total Air Temperature question | Mike Rapoport | General Aviation | 5 | December 11th 04 09:30 PM |
Oil Temperature sending unit | Corky Scott | Home Built | 2 | October 19th 04 12:58 AM |
'Room Temperature' | Anthony | Home Built | 11 | August 23rd 04 07:36 PM |
