Future of Electronics In Aviation
Old June 26th 08, 05:19 PM posted to rec.aviation.piloting,rec.aviation.student
Dylan Smith
Default Future of Electronics In Aviation
On 2008-06-26, Le Chaud Lapin wrote:
74HC138? You EE too?
No, nothing so grand - merely a hobbyist, although I do some fairly
advanced hobbyist stuff (the current hardware project is an ethernet
card for one of my old 8 bit computers, the hardware is done and works -
all fine pitch SMD on a 4 layer PCB. But the real engineers did all the
hard work packaging a MAC and PHY in a chip, I just had to lay out the
PCB well enough, along with some glue logic and memory).
From the sunny Isle of Man.
Yes, the Reply-To email address is valid.
  #222
Old June 26th 08, 05:54 PM posted to rec.aviation.piloting,rec.aviation.student
Le Chaud Lapin
Hah...what a coincindence. I have been reading the 802.11-2007 spec
for past few nights.
I am about to buy this:
http://us.zyxel.com/web/product_fami...No=PDCA2007080
Turns a PC into instant access point, which I will need to recreate a
DHCP-like server for new type of addressing scheme that is different
from IPv4 and IPv6 using a standard PC. Otherwise, would have to hack
WRT54G from Linksys and port my software to Linux or run two Wi-Fi
adapters in ad-hoc mode, which would have worked, but since would have
had to buy an adapter in addition to the one I already have...
Your computer sounds very compact. What are the specs? Which chip?
Zydas? Prism? OS? I am always interesed to see how spartan
requirements get for such devices.
I am particularly interested in knowing the delays for association and
reasociation. I read yesterday:
http://www.smallbusinesscomputing.co...le.php/3600486
...that re-association from one acess point to another by a moving
node can be as low as 68 milliseconds, which is not bad, but
obviously, the lower the better. [This is for MAC/PHY only, not higher
layers like DHCP] I need ultra-low-handover-delay to help solve the
mobility problem in computer networking. I will probably buy 5 of
these dongles, and set them up in a line spaced 100 meters apart, then
walk with laptop in hand and check that a streaming-video session from
hard disk of one of the computers is not broken as laptop moves 500
meters as it associates and reassociates with the 5 pseudo-access-
points.
-Le Chaud Lapin-
  #223
Old June 26th 08, 06:42 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Stewart
He also showed me a miniature camera with 700+x400+ (forget exact
resolution). Cost was about $100. I asked him if such a device could
be mounted on GA aircraft
If it's small duct tape will do as a mounting :-) I've used a similar
camera (it's about the size of a large thing of lipstick, hence is
called a 'lipstick camera') on planes and racing motorcycles.
Some examples (although the quality will be somewhat degraded by
youtube):
http://www.youtube.com/user/74HC138
I also now have a completely self contained camera which cost (in US
money) about $70. Records to an SD card. It's not as good quality as the
lipstick camera, but it weighs only 35 grams and fits on a radio
controlled helicopter.
Could you post a link? One of those would
probably fit inside the wing tiedown eyebolt
on my plane.
  #224
Old June 26th 08, 06:54 PM posted to rec.aviation.piloting,rec.aviation.student
Dylan Smith
on my plane.
It's called the FlyCamOne - you can probably get one at your nearest
hobby store that deals in RC. Google will find you a supplier on your
side of the world if you want to do it online; all my links for it are
European (I got it from http://www.heliguy.com)
  #225
Old June 27th 08, 11:10 AM posted to rec.aviation.piloting,rec.aviation.student
Dylan Smith
It's wired ethernet (100baseTX and 10baseT autonegotiation) rather than
wireless. The chip is the Wiznet W5100 which is aimed at 8 bit/embedded
applications. It includes a TCP/IP offload engine too - it's a pretty
flexible chip - it gives you the option of using as much of its inbuilt
stuff as you want - you can write your own stack and talk straight to
the MAC, or you can just use its IP layer, or use the whole thing.
The old 8 bit machine it's for is one of these, which were enormously
popular over he
http://en.wikipedia.org/wiki/Zx_spectrum
Quite a lot of the work is software. It's different to write a DHCP
client in Z80 assembler :-)
FA: 1-Day-Left: 3 Advanced AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation Mel[_2_] Aviation Marketplace 0 September 8th 07 01:37 PM
FA: 3 Advanced AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation Derek Aviation Marketplace 0 September 3rd 07 02:17 AM
FA: 1-Day-Left: 3 AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation Jeff[_5_] Aviation Marketplace 0 September 1st 07 12:45 PM
FA: 3 AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation Jon[_4_] Aviation Marketplace 0 August 24th 07 01:13 AM
FA: 3 ADVANCED AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation Larry[_3_] Aviation Marketplace 0 August 6th 07 02:23 AM
