Transponder check
Old September 2nd 09, 09:26 PM posted to rec.aviation.homebuilt
Neal Fulco
Default Transponder check
If my last transponder check was on 9/12/07, am I good until 9/12/09
or am I good until the end of the month? The FAR states 2 "calendar
years." Thanks. This is for VFR by the way.
Neal
Old September 3rd 09, 12:53 AM posted to rec.aviation.homebuilt
Ron
On Sep 2, 3:26*pm, Neal Fulco wrote:
If my last transponder check was on 9/12/07, *am I good until 9/12/09
or am I good until the end of the month? *The FAR states 2 "calendar
years." *Thanks. *This is for VFR by the way.
Neal
The FAR does NOT state that. It says 24 calendar months. You're
good
to the end of the month and it makes no difference if you don't intend
to
fly IFR.
Old September 3rd 09, 01:08 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Neal
good
to
fly IFR.
"Intend to", or bust VFR minimums?
Old September 4th 09, 10:58 AM posted to rec.aviation.homebuilt
Ron
Neal
The FAR does NOT state that. *It says 24 calendar months. * You're
good
to
fly IFR.
Sorry I was not clear....It doesn't matter if you are VFR or IFR.
You need a transponder check in all circumstances.
Old September 5th 09, 03:40 PM posted to rec.aviation.homebuilt
150flivver
Neal
good
to
fly IFR.
There are two different checks involving the transponder. The
correspondence check for IFR is significantly more costly than a
simple VFR transponder check. If all you do is fly VFR, get a VFR
check and save some money or spend more and add the IFR compliant
checks--it's your dime.
Old September 3rd 09, 12:29 PM posted to rec.aviation.homebuilt
Neal Fulco
Neal
good
to
fly IFR.
Sorry about that. I meant to say "calendar months." Thanks for the
info.
Neal
Transponder vs. Portable Transponder Detectors John Murphy Soaring 16 December 20th 08 08:25 AM
check this... billybeer Owning 0 December 1st 04 02:28 AM
Check this out! [email protected] Aerobatics 0 November 30th 04 01:58 AM
Transponder check-How much? mike regish Piloting 15 December 2nd 03 01:00 AM
transponder check? Russell Duffy Home Built 10 August 15th 03 12:36 AM
