The Melting Deck Plates Muddle - V-22 on LHD deck....
Old December 11th 09, 06:42 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Timur
Default The Melting Deck Plates Muddle - V-22 on LHD deck....
http://china-arsenal.blogspot.com/20...-in-space.html
  #52
Old December 11th 09, 07:09 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Ken S. Tucker
On Dec 11, 8:35 am, "Ken S. Tucker" wrote:
On Dec 10, 4:09 pm, frank wrote:
On Dec 10, 1:00 pm, "Ken S. Tucker" wrote:
On Dec 10, 7:24 am, Jack Linthicum
On Dec 10, 8:53 am, "Roger Conroy"
"Bill Kambic" wrote in message
On Thu, 10 Dec 2009 02:57:36 -0800 (PST), Jack Linthicum
snipped for brevity
Or use the rocket launch technique and spray water across the take-off
area.
Probably less than optimal. Large clouds of hot, salt water steam
would be an annoyance (at a minimum) to the deck crew. It would also
be a highly corrosive material that could serious complicate
maintenance of both ship and aircraft.
Use of fresh water would likely be an excessive demand on the
evaporators.
The piping of cooling water suggested earlier would be a better idea.
It would likely be cheaper that major modifications such as a "ski
jump" and permit the continued use of the vertical capability of the
aircraft.
A water cooled heatsink built into a part of the deck designated for "hot"
aircraft makes a lot of sense.
You could have a place underneath to stash beer, like the old sub-
mariners did.
In electronics, we have similiar problems, we usually solve using Al
heat sinks, fan air cooled, as the cheapest. Screw a few Al heat sinks
to the bottom of the locations of the deck permited to take the heat
and engage any fluid to cool it, even water if space is tight, yawn.
Ken
Pray tell, young Skywalker, what type of electronics have you designed
that has a few thousands pounds of metal land on it, controlled by a
navel aviatrix, blasting used JP4 and other noxious and profane gasses
as high speeds and easily a thousand degrees of the Farenheits? I'm
getting a case of beer and a lot of popcorn, this is going to be a
good one.
Note to Wiki: another cite for the 'Why do EE degrees have a BS in
front of them....'
Frank, note you've replied to me 3 times, somewhat sarcastically
on a topic that is borderline boring for most, but I own a patent on
a 'new and improved' woodstove, so I have an extra interest and
specialized knowledge on the subject, so I find the problem
intriguing,
About "degrees", and "diploma's" mine are buried somewhere in
archives, rusting away.
Ken
Too add, 'refractory concrete' is a material we've considered
to form super high quality woodstoves, I suppose I could sell
the USN some to drowel over their selected deck portions.
Ken
  #53
Old December 11th 09, 09:05 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Malcom \Mal\ Reynolds
In article
318346c5-4734-47d5-9883-9ee8872cc6a7@c3
g2000yqd.googlegroups.com,
frank
On Dec 10, 11:58*pm, "Malcom \"Mal\" Reynolds" atlas-
In article
93ee764a-0400-499b-b519-37e47ef04416@v2
5g2000yqk.googlegroups.com,
*Richard wrote:
On Dec 9, 11:23*pm, "Malcom \"Mal\" Reynolds" atlas-
In article
3f72b032-2be2-4377-a180-01d7a81404fe@d2
1g2000yqn.googlegroups.com,
*Mike wrote:
StrategyPage.com
December 2, 2009
by James Dunnigan
Earlier this year, the U.S. Navy discovered that the heat from the
MV-22's gas turbine engines, which blow their exhaust right on to the
deck of the LHD while waiting to take off, caused high enough
temperatures to the steel under the deck plates, to possibly warp the
understructure. This was already a known potential problem with the
new F-35B vertical takeoff jet fighter.
So now the Navy has two hot new aircraft that require an innovative
solution to the melting deck problem. The Navy also discovered that
the exhaust heat problem varied in intensity between different classes
of helicopter carriers (each with a different deck design.)
The Navy is looking for a solution that will not require extensive
modification of current carrier decks. This includes a lot of decks,
both the eleven large carriers, and the ten smaller LHAs and LHDs.
This is shaping up as another multi-billion dollar "oops" moment, as
the melting deck problem was never brought up during the long
development of either aircraft.
Previously, the Harrier was the only aircraft to put serious amounts
of heat on the carrier deck, but not enough to do damage. But when you
compare the Harrier engine with those on the V-22 and F-35B, you can
easily see that there is a lot more heat coming out of the two more
recent aircraft. Someone should have done the math before it became a
real problem.
Use what NASA uses for the shuttle?
Wouldn't cost that much at all
Yeah except for not walking, parking, raining, hailing or dropping a
wrench on the coating it would be great.
Actually I was thinking of what they do
at the launch pad during launch, not the
tiles on the shuttle
Ever see photos of the pad, there is a large water tower near it. I
think 3 seconds before launch, when engines start up, there is a water
infusion into the bucket that thrust goes into. Think multiple streams
of water. Sucker lights up, hits the water, massive steam and thrust
go out the channels away from the launch pad. That's the big clouds
that occur. Makes pad much more reusable.
I think Shuttle was first system to use that, could be wrong. Makes
entire complex much more reusable.
If you can get some old Shuttle launch footage, that's one of the
standard shots from NASA and main engine start.
Awesome. Lots of plumbing though.
That's why I suggested it. Of course the
massive steam wasn't in my thinking when
I did. I suppose the idea of running
cold water under the deck to absorb the
heat would be best, might even be able
to use the heat for something
(pre-heating the water to be
desalinated?)
  #54
Old December 11th 09, 09:45 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Mr.Smartypants[_4_]
On Dec 10, 2:21*pm, Jack Linthicum
On Dec 10, 3:44*pm, "Mr.Smartypants"
On Dec 9, 9:22*pm, Mike wrote:
StrategyPage.com
December 2, 2009
by James Dunnigan
real problem.
Distortion or warping of steel plating due to expansion from high
temperatures is a far cry from "melting".
1700 degrees was mentioned in one article.-
That would still be "distortion" not "melting".
  #55
Old December 11th 09, 10:06 PM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Jack Linthicum
On Dec 11, 4:45*pm, "Mr.Smartypants"
StrategyPage.com
December 2, 2009
by James Dunnigan
real problem.
Here are some numbers some from an amendment
BAA 09-031 Amendment 0001
Side note:
[Iron, out of the ground, melts at around 1510 degrees C (2750°F).
Steel often melts at around 1370 degrees C (2500°F).]
ONR is looking for thermal management technologies that can keep the
deck surface temperature below 300ºF when exposed to MV-22 exhaust
plumes for 90 minutes before takeoff, and F-35B exhaust plumes for 2
minutes when landing. And cooling the deck is not enough - any
solution has to be compatible with the deck's non-skid coating. It
also has to be affordable and capable of being installed below deck or
retrofitted above deck. Tall order.
“Structural Evaluation of an LHD-Class Amphibious
Ship Flight Deck Subjected to Exhaust Gas Heat from a MV-22 Osprey
Aircraft,” they note that deck buckling occurs at a temperature of
160oF to 170oF. Where does the 300oF limit originate?
Response: The 300 degree F is derived from the temperature limit of
the tires on aircraft.
How concentrated is the heat flux, how large an area is involved in
the 24,000BTU/min heating? I have had difficulty getting any numbers
and the information heat flux given in the BAA did not include an area
component.
Response: A range of 3-foot to 10-foot diameter is suggested.
Max exhaust temperature anticipated?
Response: This is tightly controlled. A range of max temperatures
could be 1000– 1700 deg. F.
http://www.onr.navy.mil/~/media/File...amend0001.ashx
  #56
Old December 12th 09, 12:43 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
David V. Loewe, Jr
On Fri, 11 Dec 2009 04:30:02 -0800 (PST), Jack Linthicum
*Mike wrote:
StrategyPage.com
December 2, 2009
by James Dunnigan
real problem.
One of the professed goals of the system is sound suppression. That's
one of the events the crowds come to the launches for---that
magnificent roar like the end of the world.
Well you could hear the damned things 60 miles away at the site of the
old NNPS.
Dave --- who watched STS-2 take off while on "cigarette break" during
Pre NPS.
Everyone was out there. The break was supposed to end about a minute or
two before launch. The instructors actually tried to get us to go
inside. It didn't work.
"...you know, it seems to me you suffer from the problem of
wanting a tailored fit in an off the rack world."
Dennis Juds
  #57
Old December 12th 09, 01:08 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Dan[_12_]
snipped for brevity
area.
evaporators.
aircraft.
mariners did.
Ken
good one.
front of them....'
intriguing,
Ken
Great, now post a link to that patent.
Dan, U.S. Air Force, retired
  #58
Old December 12th 09, 01:10 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Strobe
On Thu, 10 Dec 2009 15:59:24 -0800 (PST), frank
On Dec 10, 2:41Â*pm, "Ken S. Tucker" wrote:
On Dec 10, 11:04 am, Jack Linthicum
snipped for brevity
area.
Probably less than optimal. Â*Large clouds of hot, salt water steam
would be an annoyance (at a minimum) to the deck crew. Â*It would also
evaporators.
aircraft.
mariners did.
Ken
Troll them in the water, saves having all those pipes.
In conventional PC's like you prolly have, is a small fan sitting
on the CPU Al heat sink.
In the high watt stuff, oil circulation is used to cool the active
components I've used.
I'm not keen on oil, a friend of mine had a damn transformer
explode on him and was showered with burning oil, it was not
pretty, and is very painful.
Also in my experience, I had a wood stove that started glowing
low red (over heated, but it was cast iron) so I sprayed it with
water to cool it, and that worked good.
A good cast iron is pretty tough stuff, better than malleable at
high temps I'm told.
Learn that steam burns, did you? Let me guess, you're an engineer.
Reminds me of our last night in boot camp.
We had our coke stove glowing a nice comfortable red as we packed to ship out,
when our friends from the next hut poured a bucket of water down the chimney.
The cast iron lid went airborne and dense clouds of steam and cinders shot out,
obscuring the electric lights. A mini Krakatoa.
Well, I guess it's tradition that you never leave a perfectly shined floor for
the next intake. . .
  #59
Old December 12th 09, 01:13 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Dan[_12_]
snipped for brevity
area.
evaporators.
aircraft.
mariners did.
Ken
good one.
front of them....'
intriguing,
Ken
Ken
Tucker, have you considered the differences in application? I didn't
think so. Let me help. A wood stove is hot, yes, but there's no high
velocity jet of extremely hot gases, is there? You would have to
"drowel" more on after almost every mission.
  #60
Old December 12th 09, 01:21 AM posted to rec.aviation.military,sci.military.naval,rec.aviation.military.naval
Strobe
On Thu, 10 Dec 2009 23:42:41 -0800 (PST), frank
On Dec 10, 11:58Â*pm, "Malcom \"Mal\" Reynolds" atlas-
In article
Â*Richard wrote:
On Dec 9, 11:23Â*pm, "Malcom \"Mal\" Reynolds" atlas-
In article
Â*Mike wrote:
StrategyPage.com
December 2, 2009
by James Dunnigan
real problem.
Imagine being the pilot taking off through all that steam.
Or landing, when visibility suddenly drops to zero as you come over the pad.
Now imagine again, this time remembering that there's solid lumps of ship
only a few yards from your rotors. . .
A strong refractory coating seems much more attractive.
Flight deck queens Michael Huber[_2_] Aviation Photos 2 January 19th 08 06:38 AM
Kiev's deck - with Yak-36s and Ka-25s Dave Kearton Aviation Photos 0 March 2nd 07 06:12 AM
Ka-25s on Kiev's deck Dave Kearton Aviation Photos 0 March 2nd 07 06:09 AM
Straight deck ops Greasy Rider Naval Aviation 18 January 10th 07 01:35 AM
Deck height Sean Trost Home Built 5 July 16th 04 03:46 AM
