Varyag aircraft carrier
Old January 6th 10, 04:43 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval,us.military.navy
Chris
Default Varyag aircraft carrier
On Jan 6, 7:43*am, jkochko68 wrote:
There was a requirement that
it had to have about 200 miles of cross range min. so it could make
use of different fields not directly along its glidepath.
This might be true (I've never heard of a AOA abort site in Alaska,
but I wouldn't be surprised if there was one) but it was not the main
imposition on cross range that the USAF put in. The USAF demanded over
a thousand miles of cross range for Reference Mission 3A and 3B. Those
two missions were for a spacecraft to take off from VAFB, going south,
either release or recover a satellite, and land back at VAFB after a
single orbit.
The 200 mile cross range was b/c thats roughly how far away one pt. on
Earth would be after a 90 minute orbit.
You can see just from first principles that this must be wrong. The
earth takes 24 hours to rotate all the way around. So 90 minutes would
be 1/16th of the total rotation. The earth's mean circumference is
40,041 KM. 1/16th of that is 2,502 KM, or 1,555 miles. That is
roughly how far away one point on earth would be after a 90 minute
orbit. The farther away from the equator you go, the smaller the
number, until you get to the Pole (best case) where it's 0, but that's
the worst case; average case would be half that, or 777 miles.
Perhaps 200 miles of cross range would be enough for an abort to
Alaska- but Reference Mission 3A and 3B required landing at VAFB, from
whence the Shuttle had come. That was because there simply wasn't
enough time to release a sat (or recover one) if you were going to
make a landing in Alaska.[1] And at VAFB's latitude, one needs about
1200 miles of cross range to account for the rotation of the earth and
have a bit of a safety factor. So that was a major design constraint
on the space shuttle.
Yeah but dodging multiple sats.,,, and I seriously doubt
Is not that hard.
For the infamous NORPAC '82 exercise, the USS Midway and USS
Enterprise operated for 4-5 days about 200 nm off Petropavlovsk,
launching alpha strikes each day (but on the reciprocal heading to the
Soviet naval base) without being detected by airplanes, sats, or subs
(as best we can tell by Soviet reaction). And that was against the
Soviet ship detection capabilities: they invested a heck of a lot more
in that than we did, because they were far more threatened by the USN
than we were by the fUSSR Navy. They had a great number of Bears,
launched quite a few satellites (both RADSATs and Ferrets), etc. So it
is surely not impossible.
Its
likely the task force would not be using the shipping lanes so they
would further stand out.
Why do you think that? If the enemy knows that avoiding shipping lanes
makes you stand out, why wouldn't they use shipping lanes? It's not
that hard to be on a shipping lane but not seen by any green ships if
you have a 10+ knot speed advantage over them and can run your civ nav
radars. Also, bad weather and night are quite handy for hiding in.
[1]: RM-3 was built around the concern that multiple orbits by the
big huge shuttle would make it easy for the Soviets to figure out the
exact orbit of the spy sat, so we wouldn't give them much time to get
their tracking perfect by simply doing it so quickly: one pass over
the USSR and back down. Now, by 1977 the USAF/NRO seems to have
decided that RM-3 wasn't important any more, and focused more on RM-4
(a bit more payload, but not the tight single orbit requirements)
after they thought more about how to use spy sats, but the shuttle
design was already finalized at that point. Faget's original design
track, which would have provided much less cross range (on the order
of a few hundred miles) had been binned, in favor of the big heavy
delta wings necessary to provide enough lift in the hypersonic region
of the flight to get 1500 miles of cross range that the military
demanded for RM-3.
Chris Manteuffel
  #32
Old January 6th 10, 06:44 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval,us.military.navy
Jack Linthicum
single orbit.
40,041 KM. *1/16th of that is 2,502 KM, or 1,555 miles. That is
Is not that hard.
*Its
[1]: *RM-3 was built around the concern that multiple orbits by the
demanded for RM-3.
Chris Manteuffel
Smaller distance at higher latitudes. One source gives 9,905.2 miles,
ie your 1/16th would be 619 miles. If you are only going the distance
from Vandenberg to Alaska the distance is something like 1500 miles.
The speed of an orbital launch is about 26000 feet per second,
traveling that 1500 miles in about 5 minutes. Your precession is then
in the 165 mile region, fudging makes it 2000 miles.
  #33
Old January 7th 10, 05:25 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval,us.military.navy
tankfixer
In article 01fc4d1c-6a6e-4840-b78a-f85f58d971a7
@j19g2000yqk.googlegroups.com, says...
On Jan 5, 9:04*pm, "David E. Powell" wrote:
On Jan 5, 8:14*pm, Dan wrote:
Chris wrote:
On Jan 5, 6:15 pm, frank wrote:
SOSUS was retired and shut down. Little thing with Walker giving away
the candy store to the SU on how we tracked subs.
Completely wrong. SOSUS is still operational, though there are fewer
NAVFAC's operating and now SURTASS is generally preferred: both
because of the operational flexibility that the T-AGOS have and the
vastly easier maintenance (and upgrade) opportunities that they
provide.
And Walker doesn't really match the timelines for when the IUSS (the
acronym for the combination of the two) started to decline: the fall
of the USSR and the dramatic drop in the number of submarines we
needed to track in the open ocean does (the drawdown seems to start in
the mid 1990's).
Chris Manteuffel
* *Back during the depths of the Cold War I thought it would have been
fun to tweak the Soviet's version of SOSUS by deliberately sinking a
retired U.S. submarine in such a way the Soviets would detect it. It
would have been a gas to sit back and watch the Soviets going nuts
trying to figure out what happened.
Dan, U.S. Air Force, retired
Like a retired GUPPY (Or pre Guppy) sunk in a deep spot right near
their cable?
And reveal that we knew where their cable was, what it was used for
and perhaps that we were running submarines they couldn't detect into
their defense zone?
Not that we would EVER do such things.. ;')
  #34
Old January 7th 10, 02:51 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval,us.military.navy
Mark Test[_3_]
"tankfixer" wrote in message
On Jan 5, 9:04 pm, "David E. Powell" wrote:
away
fewer
provide.
Really? Then how come the SURTASS fleet has been retired? We once had
over 24 ships, now there are 4.
(the
fall
in
the mid 1990's).
Chris Manteuffel
been
their cable?
their defense zone?
SOSUS has been integrated into IUSS (Integrated Undersea Surveillance
System),
a small part of a larger network. So, SOSUS is still alive, but much
smaller due to
a much smaller ASW threat. Also, newer systems had to be developed to
counter
quieter submarines.
http://www.fas.org/irp/program/collect/iuss.htm
Mark
  #35
Old January 8th 10, 02:26 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval,us.military.navy
tankfixer
says...
says...
away
fewer
provide.
Mark, please check your attributions..
I didn't write the bit above.
(the
fall
in
the mid 1990's).
Chris Manteuffel
been
their cable?
their defense zone?
System),
smaller due to
counter
quieter submarines.
Mark
I was reffering to Ivy Bells..
  #36
Old January 9th 10, 07:29 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval,us.military.navy
Timur
future 5th gen fighter concept images:
http://groups.google.com/group/rec.a...8ab06e7daf4fe7
GA on Aircraft Carrier??? Cockpit Colin Piloting 12 January 21st 05 03:17 PM
Newest Aircraft Carrier Evan Williams Naval Aviation 2 June 5th 04 01:00 PM
British carrier aircraft R4tm4ster Naval Aviation 2 May 1st 04 08:17 AM
launching V-1s from an aircraft carrier Gordon Military Aviation 34 July 29th 03 11:14 PM
