barnyard, its on your head....
Old April 1st 10, 11:17 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
Default barnyard, its on your head....
On Wed, 31 Mar 2010 08:02:16 -0500, Barnyard BOb
The flight of N863WL from Seattle to Kansas City was a flight of 2
until overnighting in Salt Lake City with Ric and Shari Lee. From
there, it seemed like just a short hop the next day to KCMO at 200+
mph ground speed. At 75% power, the fuel burn was near 9 gph with the
airspeed hovering in the neighborhood at a tad over 185 mph on the
trusty 150 hp Lycoming 0-320.
in my language that would be 161 knots burning 34 litres per hour.
for the distance travelled the Tailwind would burn about 32.5 litres.
(120 knots at 24 litres per hour)
so it is a pretty damn efficient aeroplane.
The RV3 is without a doubt the most 'nimble' of all the RV models.
With nearly 10 years under my belt with N863WL the honeymoon is still
far from over, and I bore easily given my 56 years of licensed flight
and 8000 hours of tailwheel time.. mostly acquired while crop dusting.
P.S.
If Yawn Jimenez, is reading this...
eat your heart out, you Zoom ass kisssing BD-5 dip****!!!
~Barnyard BOb~
The more people I meet,
the more I like my dog.
Bob
when you say "nimble" I'm not sure what you mean. it has a few
meanings.
is it really sensitive on the controls to fly or is it sprightly (high
performance) to fly?
does it fly like a Tailwind or more like an RV6 ?
what are the landings like?
squirrilly or docile?
Stealth Pilot
Old April 1st 10, 01:01 PM posted to rec.aviation.homebuilt
Barnyard BOb
On Thu, 01 Apr 2010 10:17:57 GMT, Stealth Pilot
FWIW: General pulic MPG claims are higher than mine.
I don't lean until at least one valve burns...
or fly so slow as to get 28 mpg. It's a fast
machine so I fly it that way.
meanings.
BOTH.
If you see the stick move...
you may well may be over controlling.
Roll and pitch rates ares not as high as purebred acrobatic ships,
but those use to such responses will feel right at home in an RV3.
Never been in a Tailwind.
RV3 stability is NEUTRAL.
Turn it lose, and it eventually will go someplace else.
An RV6 flies like a truck compared to an RV3.
Stealth Pilot
I hear the RV3 lands slower and therefore, shorter than a Tailwind.
Stall is a tad over 50 mph. Stall is gentle and very predictable.
Many RV fliers prefer wheel landings. It is NOT my technique of
choice. I go with the FAA position that the slowest landing is the
safest landing, therefore FULL STALL is my preference. However,
the RV3 has a quirk. IMO, the main landing gear is a couple of inches
too short. This means at full stall, you land tailwheel first. So, I
land just shy of full stall. Here's why....
Given that the main gear is stiff tubing, it is a bit jarring and not
good for the weldments where the landing gear tubing is welded within
the engine motor mount. This is a definite weak link for RV3's and
RV4's and cracks develop in this area more often than not for us
owners. It then follows the engine must be removed for most repairs
that generally are not permanent. This gear design, the implementation
and tubing thickness of my engine mount truly SUCKS BIGTIME!!!!! If
there is a practical and guaranteed way to fix this gear problem once
and for all, short of starting from scratch, I sure want to know about
it. I repaired my mount a couple of hundred hours ago and fly into
mostly rough grass strips. So far, so good. Could be my mods are
better than most through nothing more than dumb luck practiced via
shadetree eyeball engineering!
The squirreliest plane I've ever flown was a Piper Pacer that was
suffering tailwheel and main gear alignment problems. Beyond that,
I've not experienced any mechanically sound plane that I would label
as squirrelly.
WARNING: Given my years and hours, my opinion may not be of much use
to lower time pilots or zero time tailwheel guys. With this in mind,
I think the RV3 has mild ground and air manners and is less squirrelly
than most with one caveat for newbies.... the RV3 corrections need to
be made faster than say... an Aeronca Champ. Get behind on corrections
with any tailwheel craft and you could be in deep doo-doo.
I've heard of low time Champ pilots transitioning to tailwheel RV's
with no problems, but I recommend dual in any tailwheel RV just to be
on the safe side. With little mass in the ass end of an RV3... it
responds quickly and predictably and is easier to land than the other
RV's, IMO.
Quite unlike a Piper Pacer with 140? lbs on the tailwheel. :-)
~ Barnyard BOb ~
Old April 1st 10, 03:35 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Thu, 01 Apr 2010 07:01:47 -0500, Barnyard BOb
BOTH.
Stealth Pilot
as squirrelly.
RV's, IMO.
~ Barnyard BOb ~
sounds to me that it flies just like the W8 Tailwind ...something that
I'm quite happy with.
your main gear legs are solid Wittman style tempered 6150 tapered rods
if they are built according to the plans. they arent tubes.
relating Tailwind experiences here on the same sort of undercarriage
setup...
the thin 5.00x5 tyres that were originally on my aeroplane had to be
pumped to exactly 25psi or the aeroplane was a ******* to land.
I noticed a counter display showing a 5.00x5 tyre with almost twice
the tread thickness of the normal tyre. I swapped to using those just
to get longer times between replacements. they work well, really well.
I can now have tyre pressures anywhere between 22 and 30psi and I dont
notice any difference. the tendency for landing bounce is gone as
well.
if you get any shimmy in the main gear on landing the cause is
brinelling of the single bolt at the top of the leg causing it to
become a loose fit. sure sign of this is the shimmy vanishing on the
application of light braking. replace the bolt and it should be sweet
again.
the ground handling is interesting. I will not be using the tailwheel
chain arrangement on the plans. mine will be a solid rod as per my
Tailwind. Originally the Tailwind had the Wittman plans tailwheel
arrangement and was rated as a good flying aircraft but a nightmare in
the ground handling. When I first taxyied the aircraft I recognised a
problem with overgearing of the tailwheel immediately. I made a simple
change that halved the tailwheel movement and the aircraft has been a
pussycat in the ground handling ever since. the plans indicate the
same gearing problem on the RV3 but it is probably masked by the
sloppiness in the chain and spring arrangement.
I had an 18 year break in my flying so I'm not a high time pilot. I'm
still under 600 hours in the last 10 years but 450 of those are solo
W8 Tailwind time so I should have no problems with the RV3.
I'm half way through making the first part. (tailwheel spring)
Stealth Pilot
Old April 2nd 10, 06:43 PM posted to rec.aviation.homebuilt
Morgans[_2_]
"Stealth Pilot" wrote
I really do have a Tailwind. it is 25 years old. wouldnt sell it for
quids. I think I told the last offer that I wouldnt trade it for 10
spitfires.
faster is the reason, and my long term goal was to build in each
style for the experience except that I may forgoe compost on the basis
of not wanting the allergies.
the need for speed is because of the remoteness of where I end up at
the end of the first day in the Tailwind. 8,000ft and the top cruise
speed of the RV3 (or for that matter a sunderland T18) would see me in
civilisation at the end of the day. that is what is driving the issue.
the fastest I can get my O-200 tailwind to cruise at is 124 knots and
that is with a freshly painted and balanced prop. I rather like the
old girl and really dont want to flog her to death trying to get a
faster cruise. I'd like to be flying the Tailwind at age 99 so I need
to nurse her along for the next 42 years. Time to build something I
can flog along in. The Auster isnt capable. The Turbulent isnt being
built for speed. An RV3 fits the bill and I dont think it would take
forever to build.
does that make sense?
Sorry for the delay. I have been having computer problems on this end, but
the second formatting seems to be taking. My advise to all with an older
machine is to stay away from Microsoft XP SP3 and IE 8. Especially if you
use AVG antivirus. You don't have to ask me how I know this! ;-)
It does make sense. I am surprised at your Tailwind speed, though. I had
always though they were quite a bit faster than that.
I too yearn for speed in this big country. There are a lot of things to
see, and to re-see. If I could get life to slow down so I could get started
on it!
I have had two back surgeries, and my wife has had one. The most recent
development is that my wife's newest problems she has been having with her
back haves not responded to any of the things they have tried, and it is now
time for surgery. They scheduled it for Monday. Wow. I hope it will be
more successful than other attempts in this family, but since it is in her
neck, my observation is that these type of surgeries are usually more
successful than lower back surgeries. I can only hope.
Good luck with your RV plans. Everyone I know with one gets the RV grin,
for sure!
Old April 2nd 10, 09:35 PM posted to rec.aviation.homebuilt
Barnyard BOb
On Thu, 01 Apr 2010 14:35:19 GMT, Stealth Pilot
ARRGH!!!!
OLD AGE BRAIN FART!
Sorry.
You are 100% correct.
Van stole the whole setup from Wittman. :-)
setup...
well.
The McCreary tires [tyres] furnished by Van's are NOT the way to go.
Remember the name... CONDOR.
They are priced about the same, but are twice the tire [tyre].
I'm told these are made by Michelin. No idea if specs are are same or
not. Cheap tires have weak walls, track poorly and wear fast. Not
Condors.
I use lower 22 lbs pressure... for better shock absorbtion.
again.
Thanks for the advice.
I'll definitely try that.
pussycat in the ground handling ever since. the plans indicate the the
From past experiences....
a bit of slop has normally produced best results for me.
However:
With my RV3, no slop has proven best. The springs tho, are anythiing
but stiff and stretch with little force/effort.
What I've been told that makes for a pussycat is TOW OUT.
With TOW IN... you have one mean TIGER.
ZERO would be best, if you can achieve it.
I don't mean to start a war with the above tidbit...
I mean it as a fact of life for taildraggers. g
Stealth Pilot
Sounds like you would be right at home in an RV of any flavor.
~ Barnyard BOb ~
Old April 2nd 10, 11:01 PM posted to rec.aviation.homebuilt
cavelamb[_2_]
setup...
well.
again.
Related to Tailwind gear, my W-10 main legs were 3" longer than the W8 specs.
I think Van lengthened the legs on the 4 and 6 as well.
That makes everything come together smoothly.
And the current way to build the W-10 adds a stout clamp to the mount where the
leg exits the engine mount tube. That helps keep the leg from twisting and
causing a loose fit at the retention bolt (top).
The Tailwind design has come a long way since the early days.
Jim Clement's hot rod W-10...
http://www.airport-data.com/aircraft/N169WH.html
Tricycle...
http://www.airport-data.com/aircraft/photo/379578.html
A metal wing tricycle!
http://www.eaa9.org/Members/Butts.htm
Old April 4th 10, 09:50 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Fri, 02 Apr 2010 15:35:51 -0500, Barnyard BOb
Condors.
Condor. yep they're the ones I was referring to.
again.
However:
tailwheel gearing and toe out come into play at different times.
I think both are important.
directional control is definately made easier if the tailwheel
"ruddering" is made just right. on the tailwind the link rod sat
parallel to the tailspring and was overgeared to blazes.
I halved the distance out on the rudder arm which effectively reduced
the throw by half. I wouldnt use anything but a solid link rod because
it allows for such positive correction between the time that the
tailwheel is on the ground and the time that the mains touch.
you can completely straighten a gusted landing before the mains touch
and have a totally uneventful roll out.
toe out works.
if the aircraft is in a swerve to the right (as sensed by the pilot)
inertia will have the left side tyre pressed hard on the ground and
often the right side tyre will be almost off the ground. the right
side tyre could be pointing anywhere because it isnt contributing
much. if the left side tyre in this swerve is toed out then it will be
pointing almost in the direction of movement and it wont contribute
much adverse input.
if it was toed in it would be adding to the forces trying to roll the
aircraft over. ...not what you want.
swerve the other way and the situation is mirror imaged.
I once bent an undercarriage leg with the effect that the right leg
had something like 15 to 20 degrees of toe out. the left leg was
undamaged. on takeoff as you lifted the tail the aircraft would yaw
slightly until the drag off each wheel equalised and in this condition
would quite happily complete the takeoff. I flew back across australia
with the gear like that. it demonstrated to me that an aircraft can
have quite large amounts of toe out with no detriment to the ground
handling.
Stealth Pilot
whoelsale bose head phones,wireless head phones,wireless headphone,3.5mm earphone,earphone Alex[_4_] Aerobatics 0 April 21st 08 03:35 PM
Head on Maple1 Aviation Photos 1 August 3rd 07 06:02 AM
head set [email protected] Home Built 1 September 19th 06 02:27 PM
DOT head has got to go JJ Piloting 17 July 22nd 04 05:53 PM
Barnyard--- Auto engines Jerry Springer Home Built 10 August 8th 03 06:38 PM
