Intake plenum
Old April 11th 10, 02:26 AM posted to rec.aviation.homebuilt
Ron Wanttaja[_2_]
Default Intake plenum
Peter Dohm wrote:
"cavelamb" ""cavelamb\"@ X earthlink.net" wrote in message
Come on, guys!
How hot do you think the intake air can be and still have the motor run???
I was really wondering about that as well--and also doubting the required
strength...
The air doesn't stick around long enough to GET hot...it's moving past
in a hurry. However, the plenum is in direct mechanical contact with
the hot parts of the engine. The airflow will help cool it, but
there're still parts in direct contact.
Old April 11th 10, 03:40 PM posted to rec.aviation.homebuilt
et
On Apr 10, 6:26*pm, Ron Wanttaja wrote:
Come on, guys!
strength...
in a hurry. *However, the plenum is in direct mechanical contact with
the hot parts of the engine. *The airflow will help cool it, but
We're not talking about a composite heat muff? Are we? Surely,
we're talking about the part that directs air into the carb?
Ed
Old April 12th 10, 05:21 PM posted to rec.aviation.homebuilt
Neal Fulco
Come on, guys!
strength...
We're not talking about a composite heat muff? * Are we? * Surely,
Ed
Right, we're talking about the plenum itself, not the muff. The only
part that will contact anything on the engine will be the flange that
attaches to the carb. It will be a few inches away from the exhaust
manifold so that is a concern also. I even thought of making the
basic structure out of thin aluminum, wrapping that with fiberfrax,
(the thin stuff you usually sandwich between the stainless and plywood
on a composite construction) and then glassing over that. Sounds
labor intensive, but seeing the work needed for fitting, riveting, etc
that is needed for an all aluminum structure, it's really not that
more involved.
Neal
Old April 12th 10, 07:59 PM posted to rec.aviation.homebuilt
et
Come on, guys!
strength...
Ed
Right, we're talking about the plenum itself, not the muff. *The only
attaches to the carb. *It will be a few inches away from the exhaust
manifold so that is a concern also. *I even thought of making the
on a composite construction) and then glassing over that. * Sounds
more involved.
Neal- Hide quoted text -
- Show quoted text -
Neal
If you have room, you might consider a heat shield attached to the
exhaust pipe. I ran the exhaust out the side with the coolant air,
so my lower cowl is relatively cool. No exhaust pipes to heat things
up.
Ed
Old April 17th 10, 06:59 AM posted to rec.aviation.homebuilt
Ernest Christley
Neal Fulco wrote:
On Apr 11, 9:40 am, et wrote:
On Apr 10, 6:26 pm, Ron Wanttaja wrote:
Come on, guys!
strength...
Ed
more involved.
Neal
The most severe temperature will be right after shutdown, when the
engine is still hot but there is no longer any cooling air flowing.
intake air filter choices Dick Home Built 8 January 19th 07 03:06 PM
Flexible air intake hose abripl Home Built 10 July 21st 06 04:11 AM
Blackbird intake Speed Piloting 5 May 25th 05 07:52 PM
Q. about Eurofighter intake Alistair Gunn Military Aviation 1 August 20th 04 06:58 AM
Lycoming intake preheater Dale Larsen Home Built 5 June 6th 04 10:32 PM
