Sunlit images of Silentflight Glide Computer next to IPAQ3850
Old May 20th 10, 09:59 PM posted to rec.aviation.soaring
Default Sunlit images of Silentflight Glide Computer next to IPAQ3850
http://silentflight.com/index.php?op...mid=8&Itemid=8
Neither has a mat anti glare covering on the screens which would help
both with definition.
Cheers
Al
Old May 23rd 10, 05:18 AM posted to rec.aviation.soaring
Mike[_8_]
On May 20, 1:59*pm, "
http://silentflight.com/index.php?op...view=photos&us....
Cheers
Al
Looks decent, thanks
Old May 23rd 10, 03:13 PM posted to rec.aviation.soaring
Andy[_1_]
On May 20, 12:59*pm, "
Cheers
Al
What is a "Silentflight Glide Computer" The image looks like that
generated by LK8000 but what is the hardware?
Andy
Old May 23rd 10, 11:39 PM posted to rec.aviation.soaring
Cheers
Al
What is a "Silentflight Glide Computer" *The image looks like that
Andy
Go to Silentflight.com to find out.
Old May 24th 10, 12:34 AM posted to rec.aviation.soaring
Andy[_1_]
On May 23, 2:39*pm, "
No answers there, but it appears to be the same as this hardware.
http://cgi.ebay.co.uk/GPS-Navigator-...-/250632038247
Old May 24th 10, 01:25 AM posted to rec.aviation.soaring
http://cgi.ebay.co.uk/GPS-Navigator-...een-Direct-WIN...
Not that one, that one does not have the COM port.
Old May 24th 10, 03:37 AM posted to rec.aviation.soaring
mike
On May 23, 5:25*pm, "
Al,
Is it possible to connect a Cambridge 302A to this without a DB9? You
mentioned a power/data cable for external NMEA.
Old May 24th 10, 06:43 AM posted to rec.aviation.soaring
ContestID67[_2_]
The Silentflight has the same ports as the eBay system mentioned
above. USB in both cases with is a "COM" port.
Old May 24th 10, 03:19 PM posted to rec.aviation.soaring
Andy[_1_]
above. *USB in both cases with is a "COM" port.
The issue with connecting to a 302 may be baud rate. I am
experimenting with an HP310 PNA. It does not support the default 302
baud rate, and LK8000 does not (yet) provide the capability to switch
the 302 to a compatible baud rate.
The next question would be - how does the GPS engine if the
Silentflight PNA perform in steeply banked thermal flight. The HP 310
is worthless although it works fine in cruise.
Andy (GY)
Old May 25th 10, 01:44 AM posted to rec.aviation.soaring
Mike[_8_]
The issue with connecting to a 302 may be baud rate. *I am
Silentflight PNA perform in steeply banked thermal flight. *The HP 310
Andy (GY)
Andy, if the PNA's baud rate can be set by XCSoar it should work?
With my IPAQs there has never been a problem connecting the 302A with
XCSoar, which I would use. Seems if Al can connect to other
Cambridges, the 302A should, just wondering how the cable works.
Glide computer review Itsaplane[_2_] Soaring 24 December 11th 09 06:43 PM
Cheap Glide Computer Uncle Fuzzy Soaring 18 November 9th 09 10:24 PM
iPhone Glide Computer Kloudy via AviationKB.com Soaring 13 September 13th 07 04:41 AM
Glide computer Mark Siegelberg Soaring 1 January 13th 07 02:08 PM
Best Glide computer and why Roger Soaring 10 October 24th 06 09:28 PM
