I have a question about hooking up the Oudie to my LX 5000.
When I was using my IPAQ the serial port from my IPAQ is a female plug. On the Oudie, it is a male serial plug. Is there another option about hooking this up with a LX 5000? Is anyone using the Oudie with a LX 5000? Thanks for your time. Randy http://talihinasoaring.com/ |
Hi Randy,
The pin connections are not compatible. The Oudie's cable is setup for use with a Cambridge GPS-NAV or 302 - not an LX product. The Goddard PXF-0.5 cable would be the perfect adapter cable. http://www.cumulus-soaring.com/goddard.htm#PXF-0.5 Best Regards, Paul Remde Cumulus Soaring, Inc. "Randy" wrote in message ... I have a question about hooking up the Oudie to my LX 5000. When I was using my IPAQ the serial port from my IPAQ is a female plug. On the Oudie, it is a male serial plug. Is there another option about hooking this up with a LX 5000? Is anyone using the Oudie with a LX 5000? Thanks for your time. Randy http://talihinasoaring.com/ |
A null-modem cable with female/female connectors or the standard
serial cable from LX 5000 with binder connector will also do the trick. The pinout on the Oudie connector is exactly the same as the standard RS-232 pinout with 2=Receive to Oudie, 3=Transmit from Oudie, 5=Ground. Regards, Andrej Kolar On 21 maj, 21:27, "Paul Remde" wrote: Hi Randy, The pin connections are not compatible. *The Oudie's cable is setup for use with a Cambridge GPS-NAV or 302 - not an LX product. * The Goddard PXF-0.5 cable would be the perfect adapter cable. http://www.cumulus-soaring.com/goddard.htm#PXF-0.5 Best Regards, Paul Remde Cumulus Soaring, Inc. "Randy" wrote in message ... I have a question about hooking up the Oudie to my LX 5000. When I was using my IPAQ *the serial port from my IPAQ is a female plug. On the Oudie, it is a male serial plug. Is there another option about hooking this up with a LX 5000? Is anyone using the Oudie with a LX 5000? Thanks for your time. Randy http://talihinasoaring.com/ |
| Thread Tools | |
| Display Modes | |
| New Oudie Photos | Paul Remde | Soaring | 3 | April 30th 10 05:17 PM |
| Naviter Oudie Units Shipping Soon | Paul Remde | Soaring | 5 | April 7th 10 03:05 PM |
| Naviter Oudie Should be Available in April 2010 | Richard[_9_] | Soaring | 15 | February 6th 10 11:40 PM |
| FS: LX-5000 FAI v. 11 | Greg Arnold | Soaring | 0 | January 8th 05 02:18 AM |
