We finally foiund a source for the Grob 103 Twin II Acro Canopy Seals
Talk to Helmut at http://www.ltb-lindner.com/kontakt.112.html Language is not a problem. On Aug 17, 10:45*am, Grider Pirate wrote: On Aug 17, 6:59*am, AGL wrote: X-No-Archive: The seals on our clubGrob103 Twin II Acro are getting a bit tattered so we're looking for a replacement. *Here's what the existingseal looks like: *http://skillsapplied.com/Uploads/Grob/Original.jpg So far, going through a dozen aftermarket catalogs at auto part wholesalers, hot rod shops, and gasket companies, has not been successful. *Rumors had it that the seals are VW, but the VW dealer partsman said that this was not the case. The best option appears to be trusty McMaster-Carr, that offers a selection athttp://www.mcmaster.com/#edge-grip-protective-edging/=8fy1tc andhttp://www.mcmaster.com/#edge-grip-protective-edging/=8fyako None are of the exact dimensions, and I would be taking a guess at hardness. *On a 6" length it wouldn't matter, but when there is 16 feet ofsealper canopy, very slightly oversize or slightly too stiff can make it impossible to close the latch. *Undersize isn't any better. So, does anyone have a part number that they have used successfully? If not, it's trial and error with some McMaster-Carr samples. Thanks!! I can't help, but I'm going to be watching this thread. *Our non-acro 103 also needs new seals. |
On Sep 2, 6:14*am, AGL wrote:
We finally foiund a source for the Grob 103 Twin IIAcroCanopy Seals Talk to Helmut athttp://www.ltb-lindner.com/kontakt.112.html Language is not a problem. On Aug 17, 10:45*am, Grider Pirate wrote: On Aug 17, 6:59*am, AGL wrote: X-No-Archive: The seals on our clubGrob103 Twin IIAcroare getting a bit tattered so we're looking for a replacement. *Here's what the existingseal looks like: *http://skillsapplied.com/Uploads/Grob/Original.jpg So far, going through a dozen aftermarket catalogs at auto part wholesalers, hot rod shops, and gasket companies, has not been successful. *Rumors had it that the seals are VW, but the VW dealer partsman said that this was not the case. The best option appears to be trusty McMaster-Carr, that offers a selection athttp://www.mcmaster.com/#edge-grip-protective-edging/=8fy1tc andhttp://www.mcmaster.com/#edge-grip-protective-edging/=8fyako None are of the exact dimensions, and I would be taking a guess at hardness. *On a 6" length it wouldn't matter, but when there is 16 feet ofsealper canopy, very slightly oversize or slightly too stiff can make it impossible to close the latch. *Undersize isn't any better. So, does anyone have a part number that they have used successfully? If not, it's trial and error with some McMaster-Carr samples. Thanks!! I can't help, but I'm going to be watching this thread. *Our non-acro 103 also needs new seals.- Hide quoted text - - Show quoted text - Some follow-up. I had to order some other stuff from McMaster-Carr, so I ordered a foot of each of the closest two types of edge trim they carry. I'll post up the part number when I can get out to the field to see which is right. |
On Sep 22, 8:49*pm, Grider Pirate wrote:
On Sep 2, 6:14*am, AGL wrote: We finally foiund a source for the Grob 103 Twin IIAcroCanopy Seals Talk to Helmut athttp://www.ltb-lindner.com/kontakt.112.html Language is not a problem. On Aug 17, 10:45*am, Grider Pirate wrote: On Aug 17, 6:59*am, AGL wrote: X-No-Archive: The seals on our clubGrob103 Twin IIAcroare getting a bit tattered so we're looking for a replacement. *Here's what the existingseal looks like: *http://skillsapplied.com/Uploads/Grob/Original.jpg So far, going through a dozen aftermarket catalogs at auto part wholesalers, hot rod shops, and gasket companies, has not been successful. *Rumors had it that the seals are VW, but the VW dealer partsman said that this was not the case. The best option appears to be trusty McMaster-Carr, that offers a selection athttp://www.mcmaster.com/#edge-grip-protective-edging/=8fy1tc andhttp://www.mcmaster.com/#edge-grip-protective-edging/=8fyako None are of the exact dimensions, and I would be taking a guess at hardness. *On a 6" length it wouldn't matter, but when there is 16 feet ofsealper canopy, very slightly oversize or slightly too stiff can make it impossible to close the latch. *Undersize isn't any better. So, does anyone have a part number that they have used successfully? If not, it's trial and error with some McMaster-Carr samples. Thanks!! I can't help, but I'm going to be watching this thread. *Our non-acro 103 also needs new seals.- Hide quoted text - - Show quoted text - Some follow-up. *I had to order some other stuff from McMaster-Carr, so I ordered a foot of each of the closest two types of edge trim they carry. *I'll post up the part number when I can get out to the field to see which is right. The ones purchased from http://www.ltb-lindner.com/kontakt.112.html were perfect. I look forward to hearing about the samples. |
| Thread Tools | |
| Display Modes | |
| G103a Twin II Acro | bds | Soaring | 2 | August 24th 10 05:54 AM |
| Grob 103 Twin II (non acro) manual | YFCpilots | Soaring | 1 | August 27th 08 08:40 PM |
| Twin Acro inflight failure | 2cernauta2 | Soaring | 3 | December 22nd 06 05:39 PM |
| PIK 20B Flaps and Canopy Seals | Mike Leach | Soaring | 4 | October 17th 05 04:39 PM |
| 3-VIEW DRAWINGS GROB III ACRO | bambi | Soaring | 1 | September 28th 04 03:27 AM |
