Some nice video of Klaus Ohlmann soaring in the I_Care 2 solar glider
near Serres (France) www.youtube.com/watch?v=iO03XNnT84U -- Peter Scholz ASW 24 JE |
Very interesting configuration. The first thing I noticed was the
oversized surfaces in the tail. The second thing I thought was "But there is no motor, why the heck is this thing solar in the first place???". Only then did I notice that the motor was in the tail (I was looking for the standard boom mounted unit). So that has something to do with the overrsized tail surfaces. Aerodynamic or structural or both? But what is the advantage of the motor in the tail? I can think of one disadvantage - you can't retract it. |
At 02:18 20 September 2010, ContestID67 wrote:
But what is the advantage of the motor in the tail? I can think of one disadvantage - you can't retract it. A perfectly sensible configuration for an electric motorglider, saves the weight and complexity of the retraction mechanism, negligible drag with the propeller blades folded back. The only surprise (to me, anyway) is that this setup hasn't shown up on any non-solar electric motorgliders, yet... Marc |
It is a very interesting and elegant design.
However, putting all the weight of the electric motor so far back in the tail must be balanced in the nose - by a longer nose that would otherwise be necessary. Paul Remde "Marc Ramsey" wrote in message ... At 02:18 20 September 2010, ContestID67 wrote: But what is the advantage of the motor in the tail? I can think of one disadvantage - you can't retract it. A perfectly sensible configuration for an electric motorglider, saves the weight and complexity of the retraction mechanism, negligible drag with the propeller blades folded back. The only surprise (to me, anyway) is that this setup hasn't shown up on any non-solar electric motorgliders, yet... Marc |
On Sep 20, 5:01*am, "Paul Remde" wrote:
It is a very interesting and elegant design. However, putting all the weight of the electric motor so far back in the tail must be balanced in the nose - by a longer nose that would otherwise be necessary. Paul Remde .... which dictates a larger vertical stab. |
On Sep 19, 11:39*pm, Marc Ramsey
wrote: At 02:18 20 September 2010, ContestID67 wrote: But what is the advantage of the motor in the tail? * I can think of one disadvantage - you can't retract it. A perfectly sensible configuration for an electric motorglider, saves the weight and complexity of the retraction mechanism, negligible drag with the propeller blades folded back. *The only surprise (to me, anyway) is that this setup hasn't shown up on any non-solar electric motorgliders, yet... Marc See: http://www.lange-aviation.com/htm/en...ntares_h3.html |
On Mon, 20 Sep 2010 03:39:19 +0000, Marc Ramsey
wrote: A perfectly sensible configuration for an electric motorglider, saves the weight and complexity of the retraction mechanism, negligible drag with the propeller blades folded back. The only surprise (to me, anyway) is that this setup hasn't shown up on any non-solar electric motorgliders, somewhere, I've seen a proposal for a motorglider with the prop in the same position, driven by a traditional engine (in the fuselage) via hydraulic transmission (pump, hi-pressure lines all the way to the top of the tail, propeller). Just can't remember anything more. It must have been a long time. Aldo |
On Sep 20, 9:51*am, cernauta wrote:
somewhere, I've seen a proposal for a motorglider with the prop in the same position, driven by a traditional engine (in the fuselage) via hydraulic transmission (pump, hi-pressure lines all the way to the top of the tail, propeller). Just can't remember anything more. It must have been a long time. Aldo The University of Stuttgart has a hydrogen powered experimental ship based on the Pipistrel Taurus that has this same basic configuration. http://www.pipistrel.si/news/hydroge...r-construction |
On Mon, 20 Sep 2010 16:51:22 +0200, cernauta wrote:
On Mon, 20 Sep 2010 03:39:19 +0000, Marc Ramsey wrote: A perfectly sensible configuration for an electric motorglider, saves the weight and complexity of the retraction mechanism, negligible drag with the propeller blades folded back. The only surprise (to me, anyway) is that this setup hasn't shown up on any non-solar electric motorgliders, somewhere, I've seen a proposal for a motorglider with the prop in the same position, driven by a traditional engine (in the fuselage) via hydraulic transmission (pump, hi-pressure lines all the way to the top of the tail, propeller). There's also the Windex 1200 http://www.windex.se It is a motor glider with a conventional motor mounted on front of the fin in a tractor configuration and the same claimed glide performance as a Standard Cirrus. It seems to have become commercial rather than a home build in 1999. Does anybody know why they chose that configuration? The website stopped being updated in 2001. Has anything happened since? Has anybody seen one in the flesh? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
| Thread Tools | |
| Display Modes | |
| New Glider Safety Video | Tom[_9_] | Soaring | 0 | March 27th 10 09:10 PM |
| A well-done Glider video | Michael[_7_] | Soaring | 5 | December 7th 09 06:03 PM |
| Solar Flight Much more interesting than Hilarious Video | Richard[_1_] | Soaring | 0 | December 5th 08 05:07 PM |
| What Kind of Glider in this Video? | ContestID67 | Soaring | 5 | April 16th 08 01:45 AM |
| Very cool glider video! | Nik | Piloting | 2 | November 29th 05 06:44 PM |
