Plane for Short Field, Grass Strip, Beginner?
Old March 12th 11, 01:56 AM posted to rec.aviation.owning
Default Plane for Short Field, Grass Strip, Beginner?
On Mar 10, 10:27*am, Dave wrote:
OKaaaaaaaaaaaaaaay.....
Check out the Cherokees...
Parts cheaper than Cessnas, and slipping with full flaps (no
restrictions) *will bring it down like a cinder block safely.
Find one with *Art Mattisons gap seals and VG's and the short runway
would be no issue.. *(or add them later... *easy.....)
We have these mods on our Warrior, and the low speed, takeoff/landing
performance is stunning.... *
Plus, two more seats and FAR more comfortable (and suitable) for cross
country flights..
Late 60's and early 70's *140's with a mid time engine/ light panels
should be on $$$ reach..
Good Luck!
Dave
*On Thu, 10 Mar 2011 12:19:42 +0000, MBDiagMan
Bug Dout;765065 Wrote:
MBDiagMan writes:
I am currently looking at a C140A with 100HP and a climb prop.-
Excellent. That should do the job on takeoff and climb out. I forget,
does that have flaps? Is some small amount of flaps recommended for
soft-field takeoff?
Check its ability to slip (for landing), as well as any restrictions on
slipping with flaps.
What is either a picture or a novel that is not character?
- Henry James
Thanks Bug, that is some great information to have and good questions
about the plane.
I do know that the C120's had no flaps while the C140 and C140A did. *I
have read that the 140 flaps are only marginally effective and the 140A
flaps are only slightly more effective than that.
Investigating it's slipping capabilities is something I had not thought
about, so thanks for pointing this out. *I will also investigate flap
usage for soft field take off.
I will be able to go fly it next week if we get the weather for it.
Thanks again,
Neither the Cessna 150 or the Cherokee 140 are known for their short-
field performance. We used to run a couple of 150s in the school, and
on warm days the 3000' paved runway, at 3000' altitude, was getting
marginal. Grass would be way worse; the drag of grass or stubble
mustn't be underestimated. I've seen the Cherokees eat a lot of
runway, too. The best bet for a cheaper airplane for this field would
be a Champ 7EC. We had a 7EC that had been converted from the 90 hp to
100, and it outran those Cessna 150s every which way. The later
American Champion airplanes are much heavier and have less useful load
and use a LOT more runway than the old Champs.
Shoot, even an Ercoupe can make a 150 look sick. I flew a 90-hp Alon
Aircoupe, the last iteration of the Ercoupe series, and it took off
shorter, climbed faster, and cruised faster than the 150s. I have no
idea what the 150 is doing with its 100 hp.
Dan
Old March 12th 11, 06:27 PM posted to rec.aviation.owning
Bug Dout
writes:
Dan
I agree. You'd have to do a lot of mods to a Cherokee 140 to be safe on
a grass field. I have an Alon Aircoupe, and it comes close in cruise and
climb to a run-out C-172. If the OP had a paved field, I'd recommend an
Alon for his needs (200-300 mile trip, ~$20K as I recall). But not from
a short grass strip. The plane he's going to look at, a 100hp C-140,
should be fine.
And the users exclaimed with a laugh and a taunt: "It's just what we
asked for but not what we want."
Old March 13th 11, 04:45 PM posted to rec.aviation.owning
Brian Whatcott
On 3/9/2011 8:03 AM, MBDiagMan wrote:
First of all, thanks for the replies.
As further information on my proposed field. It would have two strips,
one about 15/33, 1,200 feet or a little more with short fences at either
end. The other would be about a 3/21, same length with 100' tall trees
on the South end. The prevailing winds would make the 21 the most
common, meaning taking off over the trees.
I am currently looking at a C140A with 100HP and a climb prop. It is
for sale near by and I should get a demo flight as soon as the weather
cooperates.
Thanks for any further comments and advice.
C-150 rated climb at gross is 1385 ft to a 50 foot obstacle still air.
That makes your rwy 21 iffy, though the C140 has better performance.
Brian W
Old March 31st 11, 02:32 AM posted to rec.aviation.owning
Dave[_1_]
You might find this interesting...
http://www.youtube.com/watch?v=1Od9s_VEXS8
I am the pilot, 150 hp Warrior, temp is 7 deg C. Fuel is at tabs, 70
lbs in baggage, I am alone (160 lbs)
Camera is 600 ft down the rny..
Mattisons mods (seals and VG's) and his takeoff technique...
Good luck with your search!
Cheers!
Dave
On Thu, 10 Mar 2011 20:18:18 +0000, MBDiagMan
'Dave[_1_ Wrote:
;765111']OKaaaaaaaaaaaaaaay.....
restrictions) will bring it down like a cinder block safely.
Find one with Art Mattisons gap seals and VG's and the short runway
would be no issue.. (or add them later... easy.....)
country flights..
Late 60's and early 70's 140's with a mid time engine/ light panels
Good Luck!
Dave
Bug Dout;765065 Wrote: -
MBDiagMan
writes:
soft-field takeoff?
on
- Henry James-
about the plane.
I do know that the C120's had no flaps while the C140 and C140A did. I
about, so thanks for pointing this out. I will also investigate flap
Thanks again,-
Thanks very much for the reply Dave!
I have always been a fan of the Cherokee, but several folks elsewhere
have said that it wouldn't be a good choice for my proposed field. They
might have said that before I realized the field will be closer to 1,300
feet than my originally estimated 1,100 feet.
That said, the forward slip is fine for getting in, but I don't think
that getting in will be a problem. Getting out over those trees will be
the problem. If there's an economy nose wheel, four place plane that
can do it, I'm all ears.
Thanks again for all the comments.
Old April 5th 11, 07:17 PM
MBDiagMan MBDiagMan is offline
Junior Member
First recorded activity by AviationBanter: Mar 2011
Dave,
Thanks very much for the link to your Youtube! It was very impressive.
My question now is.... would the same modifications do the same thing for a Hershey Bar Cherokee?
Thanks again,
Doc
Historic Bombers B-25 Mitchell Bomber Taking off from Grass Field.jpg (1/1) J.F. Aviation Photos 0 October 26th 07 01:17 AM
A warm evening, a grass strip, and thou.... Jay Honeck Piloting 29 August 27th 07 11:14 PM
Looking for cheap power 4 short strip. On-Condition Home Built 7 September 11th 05 08:18 AM
What is a "short field" for a PA28-181 Roy Page Owning 79 November 24th 04 12:11 PM
Now THIS is a short field landing John Harlow Piloting 8 March 16th 04 10:42 PM
