Android XC Soar
Old May 3rd 11, 04:16 AM posted to rec.aviation.soaring
Paul Besing
Default Android XC Soar
Hey guys, I have an HTC thunderbolt that I have XC Soar on....went for
a 5 hour flight yesterday and the phone arbitrarily reset after about
5 hours. I had external power hooked up to it and the battery was
fine. I'm not sure I want to replace my trusty IPAQ 310 for this
phone as a logger/computer as of yet. Anyone else seen this or having
good luck using an android version of XC Soar?
Old May 3rd 11, 08:03 AM posted to rec.aviation.soaring
Max Kellermann
What exactly do you mean by "phone reset"?
Do you really mean "reset", i.e. it rebooted? Then it's an Android
bug, and you should contact the phone vendor for an Android update.
Do you mean it returned to the home screen, i.e. XCSoar crashed? Then
please submit a bug report:
http://www.xcsoar.org/trac/newticket
It is very important that you attach the "logcat" file. You can
extract that from your phone with the Android SDK.
Without the logcat, I cannot analyze what caused the problem. And
without your bug report, the problem will unlikely to be fixed soon.
We address crash bugs very quickly, but we need your help.
Max
(XCSoar/Android developer)
Old May 3rd 11, 03:11 PM posted to rec.aviation.soaring
Paul Besing
5 hours. *I had external power hooked up to it and the battery was
fine. *I'm not sure I want to replace my trusty IPAQ 310 for this
phone as a logger/computer as of yet. *Anyone else seen this or having
Do you really mean "reset", i.e. it rebooted? *Then it's an Android
Do you mean it returned to the home screen, i.e. XCSoar crashed? *Then
*http://www.xcsoar.org/trac/newticket
It is very important that you attach the "logcat" file. *You can
Without the logcat, I cannot analyze what caused the problem. *And
Max
Thanks for the quick reply Max! Sorry I was not more clear. The
phone just rebooted it self as if you removed the battery and it went
through the entire boot sequence. I will contact android for an
update. While I'm here, I get this error on startup of XCSoar
though...Parse Error at Line: 1224 "DP 25:25:51 N 108.30:"
Any ideas?
Paul
Old May 3rd 11, 10:39 PM posted to rec.aviation.soaring
Max Kellermann
Any ideas?
This is an incomplete position, your airspace file is malformed. Two
digits must follow the trailing colon.
XCSoar for Android Max Kellermann Soaring 1 April 21st 11 07:39 PM
Possible Android Tablet? Sean Fidler Soaring 4 February 8th 11 10:30 PM
Possible Android Tablet? Sean Fidler Soaring 1 February 8th 11 03:12 PM
Possible Android Tablet? jsbrake[_2_] Soaring 5 February 5th 11 08:57 PM
Android App Mike[_36_] Soaring 8 July 14th 10 11:53 AM
