Dissasemble pa28 wings
Old January 9th 04, 03:31 PM
ec-ill
Default Dissasemble pa28 wings
Hello folks.
I need to dissasemble the wings of a PA28 cherokee for transportation and i
donīt know how. CAn anyone Help me?
Thanks
Old January 9th 04, 04:25 PM
mikem
ec-ill wrote:
Hello folks.
Thanks
Call Spanish Fork Flying Service at 801-798-9888. They do aircraft
recovery for insurance companies, so will know the proceedure. My Cessna
service manuals have the proceedure for Cessnas, but I dont know nutting
about PA28s.
Mike M
Skylane '1mm
Pacer '00z
Old January 9th 04, 05:52 PM
Jay Masino
Hello folks.
You need to disconnect the aileron cables and the mechanism for the flaps.
Then there's 6 upper bolts and 6 lower bolts (on each side) that holds the
main spar in the fuselage spar box. There's also a bolt where the rear
spar attaches to the it's fuselage attach point. I think that's it (it's
been a while). The fuselage should be properly supported, and then you
can slip the main spar out of it's spar box.
--- Jay
__!__
http://www2.ari.net/jmasino/ ! ! !
Checkout http://www.oc-adolfos.com/
for the best Italian food in Ocean City, MD and...
Checkout http://www.brolow.com/ for authentic Blues music on Delmarva
Old January 10th 04, 07:07 PM
res
Thanks for the answers.
Do you have some schema, picture, drawing....?
Thanks
Old January 11th 04, 02:41 AM
Aaron Coolidge
Jay Masino wrote:
: You need to disconnect the aileron cables and the mechanism for the flaps.
: Then there's 6 upper bolts and 6 lower bolts (on each side) that holds the
: main spar in the fuselage spar box. There's also a bolt where the rear
: spar attaches to the it's fuselage attach point. I think that's it (it's
: been a while). The fuselage should be properly supported, and then you
: can slip the main spar out of it's spar box.
There is also a front spar attatch just in front of the front seats inside
the cabin, the fuel, brake, pitot, static, and electric connections.
Aaron Coolidge (N9376J)
Discovery Wings Channel ??? John Clear General Aviation 1 November 9th 04 09:41 PM
VP-II wings available in Oregon, USA (Or, "How I was coconuted...") Roberto Waltman Home Built 2 October 29th 04 05:21 PM
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 09:39 PM
Pitt wings Al MacDonald Aerobatics 2 November 4th 03 07:40 AM
Crooked or Wavy Trailing Edges of Wings and Control Surfaces Larry Smith Home Built 3 October 24th 03 03:31 AM
Copyright Đ2004-2025 AviationBanter.
