Flew to dinner today with an outside temp of 10F. Auto pilot worked OK on the
trip out (plane came out of a 45F hanger). Parked for dinner for about 2 hours. The autopilot didn't work on the way back. You could feel the clutch take hold but no corrective action to follow the bug. Simple roll control didn't respond either. Well, about 20 minutes into the flight home, it started to work. OK all the way home. So, is it on its last leg and I should pull it and see if I can get it fixed? Fixed where? Or is the low temperture (it was outside for 2 hours in 10F) the problem? If it's low temp, I'm tempted to let it go since I don't often fly there. Chuck |
Chuck, this is EXACTLY what mine did -- right before my attitude indicator
went belly up. Then, again, a month later when the DG failed. My advice: wait. It may not be the autopilot itself. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" "PaulaJay1" wrote in message ... Flew to dinner today with an outside temp of 10F. Auto pilot worked OK on the trip out (plane came out of a 45F hanger). Parked for dinner for about 2 hours. The autopilot didn't work on the way back. You could feel the clutch take hold but no corrective action to follow the bug. Simple roll control didn't respond either. Well, about 20 minutes into the flight home, it started to work. OK all the way home. So, is it on its last leg and I should pull it and see if I can get it fixed? Fixed where? Or is the low temperture (it was outside for 2 hours in 10F) the problem? If it's low temp, I'm tempted to let it go since I don't often fly there. Chuck |
In article 3ycMb.23987$8H.56750@attbi_s03, "Jay Honeck"
writes: Chuck, this is EXACTLY what mine did -- right before my attitude indicator went belly up. Then, again, a month later when the DG failed. My advice: wait. It may not be the autopilot itself. -- The AI and DG were overhauled 1250 hours (and 7 years) ago. That just might be the problem. I wait and see what happens mext flight. Chuck Archer 2185B |
If you aren't too far away, the best service is at Century Systems in
Mineral Wells, TX (MWL) pretty close to DFW. We flew down and had them fix our IIIB years ago for a reasonable price and they did a great job. They even hooked up the Nav 2 selector to our M1 Loran. "PaulaJay1" wrote in message ... Flew to dinner today with an outside temp of 10F. Auto pilot worked OK on the trip out (plane came out of a 45F hanger). Parked for dinner for about 2 hours. The autopilot didn't work on the way back. You could feel the clutch take hold but no corrective action to follow the bug. Simple roll control didn't respond either. Well, about 20 minutes into the flight home, it started to work. OK all the way home. So, is it on its last leg and I should pull it and see if I can get it fixed? Fixed where? Or is the low temperture (it was outside for 2 hours in 10F) the problem? If it's low temp, I'm tempted to let it go since I don't often fly there. Chuck |
In article et, "McGregor"
writes: If you aren't too far away, the best service is at Century Systems in Mineral Wells, TX (MWL) pretty close to DFW. We flew down and had them fix our IIIB years ago for a reasonable price and they did a great job. They even hooked up the Nav 2 selector to our M1 Loran. "PaulaJay1" wrote in message ... Flew to dinner today with an outside temp of 10F. Auto pilot worked OK on the trip out (plane came out of a 45F hanger). Parked for dinner for about 2 hours. The autopilot didn't work on the way back. You could feel the clutch take hold but no corrective action to follow the bug. Simple roll control didn't respond either. Well, about 20 minutes into the flight home, it started to work. OK all the way home. So, is it on its last leg and I should pull it and see if I can get it fixed? Fixed where? Or is the low temperture (it was outside for 2 hours in 10F) the problem? If it's low temp, I'm tempted to let it go since I don't often fly there. Chuck It is not very close (I'm in Ohio) but I"ll keep it in my bag of tricks. Might be flying in that area before the winter is over. I went out to the plane yesterday. Hanger temp about 40F. Autopilot worked fine. My electronics guy at KCAK says watchful waiting. May be harbinger of things to come or may have been that way for years and won't get worse. Chuck |
PaulaJay1 wrote:
It is not very close (I'm in Ohio) but I"ll keep it in my bag of tricks. Might be flying in that area before the winter is over. I went out to the plane yesterday. Hanger temp about 40F. Autopilot worked fine. My electronics guy at KCAK says watchful waiting. May be harbinger of things to come or may have been that way for years and won't get worse. Unfortunately, the situation is not unlike one I faced a few years ago. The inescapable fact is, these autopilots are getting old. They're tired, and they start acting up. Doing their job gets harder and harder for them to do properly. The factory is the court of last resort, obviously, but when I approached them for service on my autopilot, I was told they were no longer able to get parts, and servicing my autopilot was no longer an option. They offered to sell me a used control unit, but I declined, based on the fact that I'd still be flying around with an autopilot that no one could service when it needed it. Ultimately, I had an Stec System 55 installed. |
century (mineral wells) doesn't work on the old ones anymore
(unless they have started back up.) be sure to call & check before you go. however, "autopilots central" in tulsa still works on them (last time i checked.) they are very knowledgeable about the century's, probably the best in the business as century won't do them anymore. http://www.sparksaviationcenter.com/ an intermittent like you have frequently is just a bad connection in one or both of the connectors that go from the gyros to the "computer". these are small round connectors with some odd number (5? 7?) of pins. the male pins are very small diameter, and the female receptacles for them are sort of a split socket (envision the petals of a tulip bloom). these "petals" get spread out and don't make good contact. if you have real steady hands, you can disconnect the cable, and with a needle _gently_ bend the petals back together to make good contact. if i remember correctly, the male pins are on the back of the gyro, and the female pins are in the cable, so after disconnecting the cable hangs down a little to give you more room to work. i used to do this fairly frequently (every 6-8 months or so). then i replaced the century with an stec-30, do i don't have to do it any more. :-) hth, g_a (PaulaJay1) wrote in message ... In article et, "McGregor" writes: If you aren't too far away, the best service is at Century Systems in Mineral Wells, TX (MWL) pretty close to DFW. We flew down and had them fix our IIIB years ago for a reasonable price and they did a great job. They even hooked up the Nav 2 selector to our M1 Loran. "PaulaJay1" wrote in message ... Flew to dinner today with an outside temp of 10F. Auto pilot worked OK on the trip out (plane came out of a 45F hanger). Parked for dinner for about 2 hours. The autopilot didn't work on the way back. You could feel the clutch take hold but no corrective action to follow the bug. Simple roll control didn't respond either. Well, about 20 minutes into the flight home, it started to work. OK all the way home. So, is it on its last leg and I should pull it and see if I can get it fixed? Fixed where? Or is the low temperture (it was outside for 2 hours in 10F) the problem? If it's low temp, I'm tempted to let it go since I don't often fly there. Chuck It is not very close (I'm in Ohio) but I"ll keep it in my bag of tricks. Might be flying in that area before the winter is over. I went out to the plane yesterday. Hanger temp about 40F. Autopilot worked fine. My electronics guy at KCAK says watchful waiting. May be harbinger of things to come or may have been that way for years and won't get worse. Chuck |
How often do you fly in weather this cold? I would believe that the clutch disk is just cold and did not have the friction required to follow the commands. I had this happend in my 180 but not due to cold but due to dust/dirt. Sometimes the clutch just loses its capability to turn the thing. I sent it back to Stec and they fixed it. Sandy Mustard PaulaJay1 wrote: Flew to dinner today with an outside temp of 10F. Auto pilot worked OK on the trip out (plane came out of a 45F hanger). Parked for dinner for about 2 hours. The autopilot didn't work on the way back. You could feel the clutch take hold but no corrective action to follow the bug. Simple roll control didn't respond either. Well, about 20 minutes into the flight home, it started to work. OK all the way home. So, is it on its last leg and I should pull it and see if I can get it fixed? Fixed where? Or is the low temperture (it was outside for 2 hours in 10F) the problem? If it's low temp, I'm tempted to let it go since I don't often fly there. Chuck |
| Thread Tools | |
| Display Modes | |
| FA: Piper J3 Cub Parts | BFC | Aviation Marketplace | 0 | September 24th 04 04:20 PM |
| Piper 6.00x6 Nose Wheel and Fork? | mikem | General Aviation | 5 | March 6th 04 12:34 AM |
| Piper Cub: "A Reflection in Time"... fine art print | highdesertexplorer | Aviation Marketplace | 0 | January 13th 04 04:47 AM |
| Autocontrol IIIB | PaulaJay1 | Owning | 13 | October 24th 03 03:39 PM |
| The Piper Cubs That Weren't | Veeduber | Home Built | 5 | August 28th 03 05:38 AM |
