PA-12 Super Cruiser - Speed on Final
Old January 24th 04, 08:53 PM
Thomas Ploch
Default PA-12 Super Cruiser - Speed on Final
Hi
I am hoping there are some PA-12 pilots out there. I was wondering what
speed you use on final. I did all of my private in the PA-12 and was
taught to be at 75 mph on final but I can't find any specific reference
to the speed.
Thanks.
Tom
Old January 24th 04, 09:07 PM
Newps
That's way too fast. Try 50 mph for a normal landing, 40-45 for wedging
it in short.
Thomas Ploch wrote:
Hi
to the speed.
Thanks.
Tom
Old January 24th 04, 11:09 PM
Thomas Ploch
That seems a bit slow given my published stall speed of 48!
In article XfAQb.12908$U%5.79751@attbi_s03,
says...
it in short.
Old January 24th 04, 11:41 PM
Newps
Buddy of mine has a pa-12, it doesn't stall at 48 mph. And even if it
did stall at 48 mph, 75 mph final is still way to fast. With a 48 mph
stall I'd use 55-58 mph. Go out and see what your plane actually stalls
at. If your owners manual is like mine the stall speed is listed as a
calibrated airspeed. You're not reading CAS on your airspeed indicator.
says...
it in short.
Old January 24th 04, 11:48 PM
Skyking
Thomas Ploch wrote in message t...
Hi
to the speed.
Thanks.
Tom
Well, I got my PPL in a 'Cruiser' but I don't remember the exact speeds
from forty years ago. It does seem that 75 MPH is mighty fast on final
for a plane that stalls at 49 MPH. I think that 65 would be good.
Skyking
Old January 25th 04, 12:28 AM
atis118
Vapr or Vref whatever you prefer is typically 1.3*Vso.
That means on your PA-12 your Vso is around 58 if you were told Vref was 75.
I don't fly a PA-12, but this is the formula for most small aircraft.
Then remember that Vref goes down 5% for every 10% decrease in gross weight.
Hi
to the speed.
Thanks.
Tom
Old January 27th 04, 01:19 AM
Nathan Young
Lacking any published data, 1.3Vso works well, so 62mph .
-Nathan
On Sat, 24 Jan 2004 22:09:36 GMT, Thomas Ploch
says...
it in short.
Old January 28th 04, 05:01 AM
Jack Bunce
In article , Thomas
Ploch wrote:
SNIP
to the speed.
SNIP
From my syllabus here are the recommended numbers:
Vx=65 mph
Vy=75 mph
V glide = 60 mph
Economy cruise 2200 rpm = 90-95 mph
Normal cruise 2400 rpm = 105 mph
Final 1.3 Vso = 65 mph
Final 1.2 Vso (short field) 60 mph
Trim - Note when flying solo from the front seat there is not enough
aft trim to hold a 60-65 mph altitude while in the landing pattern.
Engine failu Slow to 55 mph on final.
75 is way way too fast especially if you are the only occupant. For me,
solo, 60 mph seemed to work well for full stall landings. For wheel
landings solo add 5 mph.
cheers.... jack, Colchester, Connecticut, U.S.A.
AND THE KIS CRUISER ROUNDS THE PYLON... Paul Folbrecht Home Built 38 January 18th 05 05:29 AM
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 01:18 PM
Va and turbulent air penetration speed. Doug Instrument Flight Rules 70 January 11th 04 09:35 PM
Va and turbulent air penetration speed. Doug Owning 69 January 11th 04 09:35 PM
New Film: The Need For Speed - Going to war on drugs Phil Carpenter Military Aviation 0 July 23rd 03 08:43 AM
