I just received a booklet from TCM called "Tips on Engine Care" (a very
good book...available from TCM's website...http://www.tcmlink.com/). On page 12 it says "Never but never attempt to "burn out" a magneto drop with ground run-up. This 'time-honored' procedure succeeds only at the expense of the engine's mechanical health." Well, I was taught this time-honored way. What the book does not say is what you are supposed to do when you get roughness in one magento. Ideas? -Sami N2057M, Piper Turbo Arrow III |
"O. Sami Saydjari" wrote in message ... I just received a booklet from TCM called "Tips on Engine Care" (a very good book...available from TCM's website...http://www.tcmlink.com/). On page 12 it says "Never but never attempt to "burn out" a magneto drop with ground run-up. This 'time-honored' procedure succeeds only at the expense of the engine's mechanical health." Well, I was taught this time-honored way. What the book does not say is what you are supposed to do when you get roughness in one magento. Ideas? Really? Does the book say how this will hurt the engine's mechanical health? To be honest, this "time-honored procedure" seems to have no effect whatsoever on whether engines make it to TBO or beyond. |
The implication in the book is that it will overheat the engine because
it will cause one to run the engine at high RPM on the ground where airflow is not as good as in the air. They want you to minimize high-RPM ground operations. _sami C J Campbell wrote: "O. Sami Saydjari" wrote in message ... I just received a booklet from TCM called "Tips on Engine Care" (a very good book...available from TCM's website...http://www.tcmlink.com/). On page 12 it says "Never but never attempt to "burn out" a magneto drop with ground run-up. This 'time-honored' procedure succeeds only at the expense of the engine's mechanical health." Well, I was taught this time-honored way. What the book does not say is what you are supposed to do when you get roughness in one magento. Ideas? Really? Does the book say how this will hurt the engine's mechanical health? To be honest, this "time-honored procedure" seems to have no effect whatsoever on whether engines make it to TBO or beyond. |
You can burn off a mag with as little as 1700 rpm for just a couple
minutes.. surely this isn't hurting anything, at least not during the cooler months. O. Sami Saydjari wrote: The implication in the book is that it will overheat the engine because it will cause one to run the engine at high RPM on the ground where airflow is not as good as in the air. They want you to minimize high-RPM ground operations. _sami C J Campbell wrote: "O. Sami Saydjari" wrote in message ... I just received a booklet from TCM called "Tips on Engine Care" (a very good book...available from TCM's website...http://www.tcmlink.com/). On page 12 it says "Never but never attempt to "burn out" a magneto drop with ground run-up. This 'time-honored' procedure succeeds only at the expense of the engine's mechanical health." Well, I was taught this time-honored way. What the book does not say is what you are supposed to do when you get roughness in one magento. Ideas? Really? Does the book say how this will hurt the engine's mechanical health? To be honest, this "time-honored procedure" seems to have no effect whatsoever on whether engines make it to TBO or beyond. |
"O. Sami Saydjari" wrote in message ... I just received a booklet from TCM called "Tips on Engine Care" (a very good book...available from TCM's website...http://www.tcmlink.com/). On page 12 it says "Never but never attempt to "burn out" a magneto drop with ground run-up. This 'time-honored' procedure succeeds only at the expense of the engine's mechanical health." Well, I was taught this time-honored way. What the book does not say is what you are supposed to do when you get roughness in one magento. Ideas? -Sami N2057M, Piper Turbo Arrow III When you lean your engine and rev it up on the ground you are super-heating the heads, the sparkplugs, the pistons, the valves, seats, and guides --- just to clean a fouled plug or two by burning the lead or carbon fouling off the electrode. It's best to clean the fouled plug. Of course, the problem is NOT with the mag. My instructor (who was not at all a gearhead) once did that burn-it-off thing in a 152's O-235 Lycoming, and it wasn't long before that engine was in the shop for new cylinders. I remember well the heat. We could feel it and smell it coming through the firewall, and being a gearhead I knew that THAT was not good for that engine. Besides, an aircraft revved up on the ground can hardly cool itself, irrespective of the fact you have leaned the **** out of it. I haven't seen it but have heard of burning holes in pistons by overleaning. By the mag drop you already know which set of plugs, upper or lower, and then all you have to do is find the misfiring cold cylinder. That's easy enough and what if the problem is a sparkplug wire or injector? You've just managed to fry your cylinders in the hopes of getting one out of four or six to fire. Leaning an engine takes a little finesse. It shouldn't be done on the ground unless you're in Denver or on a high-altitude ramp. A small fraction of that fuel charge is cooling your heads as it evaporates and flows through the combustion chamber and out the exhaust port. Ideally it is rich enough to give you a perfect stoichiometric charge plus just a little for cooling. If you burn it all by leaning you have lost your mixture's ability to dissipate heat. In addition, some of a lean charge is burning as it departs the combustion chamber because a lean mixture burns more slowly than a rich one. Damned if I want my exhaust valve to glow just to clean a sparkplug. |
" jls" wrote in message ... Leaning an engine takes a little finesse. It shouldn't be done on the ground unless you're in Denver or on a high-altitude ramp. A small fraction of that fuel charge is cooling your heads as it evaporates and flows through the combustion chamber and out the exhaust port. Ideally it is rich enough to give you a perfect stoichiometric charge plus just a little for cooling. If you burn it all by leaning you have lost your mixture's ability to dissipate heat. In addition, some of a lean charge is burning as it departs the combustion chamber because a lean mixture burns more slowly than a rich one. Damned if I want my exhaust valve to glow just to clean a sparkplug. I think you are exaggerating. More than a little bit. I guarantee that even at sea level you are going to get spark plug fouling if you do not lean your engine somewhat during taxi -- especially when taxiing in. You just completed a descent with the mixture full rich and the engine idling -- lots of cooling and plenty of opportunity for spark plug buildup. I suspect that the detonation and premature ignition that result from your recommendations are even harder on an engine than occasionally clearing a spark plug. |
"C J Campbell" wrote in message ... " jls" wrote in message ... Leaning an engine takes a little finesse. It shouldn't be done on the ground unless you're in Denver or on a high-altitude ramp. A small fraction of that fuel charge is cooling your heads as it evaporates and flows through the combustion chamber and out the exhaust port. Ideally it is rich enough to give you a perfect stoichiometric charge plus just a little for cooling. If you burn it all by leaning you have lost your mixture's ability to dissipate heat. In addition, some of a lean charge is burning as it departs the combustion chamber because a lean mixture burns more slowly than a rich one. Damned if I want my exhaust valve to glow just to clean a sparkplug. I think you are exaggerating. Yeah, I don't know if the exhaust valve glows or not but I know when one gets too hot and don't plan to let it happen to my engine. More than a little bit. I guarantee that even at sea level you are going to get spark plug fouling if you do not lean your engine somewhat during taxi -- especially when taxiing in. You just completed a descent with the mixture full rich and the engine idling -- lots of cooling and plenty of opportunity for spark plug buildup. I don't see any big problem with leaning as you taxi. We lean sometimes on descent and will often lean if an engine tends to miss or surge. It depends on the engine and airplane too. Leaning at idle, or close to it, as in when you are taxiing, won't fry your cylinders. But leaning at high static rpm's will, sooner or later. Thus the reason for TCM's advice not to do it. I suspect that the detonation and premature ignition that result from your recommendations are even harder on an engine than occasionally clearing a spark plug. Explain what recommendations I have given which will cause detonation and premature ignition. Fuel of the improper octane, engine hot spots, improper leaning and engine conditions I am generally opposed to cause detonation and preignition. See, e. g., http://www.sacskyranch.com/eng180.htm |
On Sat, 28 Feb 2004 08:11:03 -0800, C J Campbell wrote:
I think you are exaggerating. More than a little bit. I guarantee that even at sea level you are going to get spark plug fouling if you do not lean your engine somewhat during taxi -- especially when taxiing in. You just Very true, and it sounds like the 152 he's talking about got cooked, not leaned to burn off plug fouling which doesn't take that long. |
"C J Campbell" wrote in message ... [...] I suspect that the detonation and premature ignition that result from your recommendations are even harder on an engine than occasionally clearing a spark plug. Here's an even better link to clear up the confusion: http://www.sacskyranch.com/deton.htm And I always wondered why combustion chambers in angle-valve engines were so clean. I just learned some of the reasons why. They burn cleaner. |
"C J Campbell" wrote in message ... " jls" wrote in message You just completed a descent with the mixture full rich and the engine idling -- lots of cooling and plenty of opportunity for spark plug buildup. A good reason to to enrichen the mixture on descent and landing. I always go as lean as I can. I suspect that the detonation and premature ignition that result from your recommendations are even harder on an engine than occasionally clearing a spark plug. No doubt! |
| Thread Tools | |
| Display Modes | |
| Burning out the pitot heat? | Mitty | Instrument Flight Rules | 3 | December 30th 04 06:04 AM |
| Drop in and say hello | Gilan | Home Built | 0 | June 4th 04 06:12 PM |
| Economist: Let the dollar drop | Luca Morandini | Military Aviation | 5 | February 14th 04 06:58 PM |
| :-) let enola gay drop one more :-) | old hoodoo | Military Aviation | 3 | December 28th 03 06:39 PM |
| Ellery Queen and the Case of the Missing Magneto Gear Teeth | MikeremlaP | Owning | 3 | July 26th 03 04:01 AM |
