Mike:
If you're going to do the side panels, seriously consider what's between the side panels and the aluminum. If it's anything like my cherokee, it's disintegrating roofing insulation (or something that looks like it). You'll want to remove that stuff too and put better insulation. I'm leaning toward Jim Fix's 1/4 in or 1/2 inch foam (adhesive on one side, then the foam, then foil layer), depending what will fit. And if you've got the insulation and side panels off, may as well check *all* the wiring and stuff in there. There may be wiring you can remove or need to replace. Do it now while you've got convenient access. |
| Thread Tools | |
| Display Modes | |
