Limitations of Lemon Pledge
Old April 30th 04, 08:45 PM
Jay Honeck
Default Limitations of Lemon Pledge
As many of you know, I am a big proponent of using Lemon Pledge to clean an
airplane. It can be used on the Plexiglas safely, and if you spray the
leading edges of the wings with it after each flight, the bugs just swish
right off with little effort.
In fact, that's ALL we have ever washed the plane with -- Lemon Pledge. No
soap and water has ever touched our plane.
When we were at Sun N Fun a couple of weeks ago, however, I saw a most
peculiar speckle and stripe pattern on our wings and fuselage that was only
visible in the direct sunlight. There were obviously cleaner spots and
stripes, and Pledge would not touch them. You could spray, wipe and buff
till your heart's content, but all you were doing was buffing the surface --
this dirt was much deeper than that.
When we got home I hit a spot with some Castrol Super Clean, and *voila!* --
the whole spot became a much whiter, gleaming white. Apparently two years
of Lemon Pledging has actually sealed some dirt in, under a layer of Pledge
wax that the Pledge itself couldn't dissolve.
So, last night my son and I started the arduous task of washing every square
inch with Super Clean and diapers, followed immediately by a coat of
spray-on Turtle wax (to neutralize the caustic Super Clean).
He finished the under-side, while I did the top of both wings -- wow, what a
difference! What looked "clean and white" before is now almost blindingly
white. The dullness had crept up so slowly that we simply did not notice.
So, while we'll still hit the windshield, leading edges, and nose with
Pledge after each flight, our days of using it as an "overall" cleaner are
over -- although I'd like to find something less harsh than Super Clean.
Any suggestions?
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old April 30th 04, 10:40 PM
Henry Kisor
Jay, have you ever tried Wash Wax All? That's what I use and it seems to
work very well. It's made for airplanes, while Lemon Pledge, let's face it,
is made for furniture.
I've used Lemon Pledge on the windows but wonder if it might also seal dirt
in as it apparently did with your airplane fuselage. My old instructor
recommended Novus for the windows. I've used that for two years and it also
seems to do the job fine.
Henry
P.S. How much would your son charge to do the underwings and
undertailfeathers of a 150? That wrecks my back. Might be worth a trip out
to Iowa City.
Old May 1st 04, 01:21 AM
Aaron Coolidge
Henry Kisor wrote:
: Jay, have you ever tried Wash Wax All? That's what I use and it seems to
: work very well. It's made for airplanes, while Lemon Pledge, let's face it,
: is made for furniture.
I also use wash-all wax-all (or whatever it's called). It comes in a 1-gal
jug, dilute 50/50 with water, and it does a spectacular job. It doesn't
leave that slight stickiness that pledge seems to leave, which is important
if your plane is outside! Get the "red label" super concentrated stuff.
I have been using Plexus window cleaner on the windows. It also works
quite well.
Aaron Coolidge
Old May 1st 04, 07:50 PM
Thomas Borchert
Aaron,
quite well.
We use that, too, but I've read and been told numerous times that
Plexus is just the aviation-priced version of Lemon Pledge. No
difference at all, it seems.
Thomas Borchert (EDDH)
Old May 2nd 04, 10:24 PM
Aaron Coolidge
Thomas Borchert wrote:
: Aaron,
: We use that, too, but I've read and been told numerous times that
: Plexus is just the aviation-priced version of Lemon Pledge. No
: difference at all, it seems.
Aha, you caught me in a mistake. I actually use a cleaner made by "Prist"
for lexan windows. I tried the Plexus but I wasn't happy with it, for the
same reasons that I didn't like pledge: it seems to leave a slight sticky
film. The "Prist" does not leave such a film.
I don't know exactly what part number the "Prist" cleaner is. It is not
the de-icing additive used in jet fuel that is also marketed by "Prist"!
Aaron Coolidge
Old May 3rd 04, 06:07 PM
Otis Winslow
I second the Wash Wax All recommendation. Have used it for
years and it works great.
"Henry Kisor" wrote in message
it,
dirt
also
Henry
out
to Iowa City.
Old May 4th 04, 02:09 AM
Stu Gotts
On Mon, 03 May 2004 16:07:52 GMT, "Otis Winslow"
Streaks for me. I've tried cutting it in various ratios with
distilled water, but still no dice.
it,
dirt
also
Henry
out
to Iowa City.
Old April 30th 04, 11:01 PM
Jay Masino
Although I've used pledge on the windshields for 17 years, you should note
that some of the new plexiglass cleaners, like the product made by
Aeroshell, work SIGNIFICANTLY better than pledge.
I've never understood your obsession on this. Wash your damn plane once
in a while. Soap and water gets places, and disolves dirt, that you
can't get to with your obsessive use of pledge.
I've also seen this over the years. You really have not choice but to
strip off the wax every so often. I've always been uncomfortable with
using things that are too caustic. Sometimes, just a high concentration
of dish washing liquid works. You can also get some mild polishes that
will strip away the old wax.
--- Jay
__!__
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old April 30th 04, 11:18 PM
Jay Honeck
The main reason is that Spam Cans aren't very waterproof.
After our plane was parked in Tennessee for three days in a steady rain, the
carpet by the door was wet, and our nice, new interior smelled dank. Excess
moisture was evident even after we got home, despite "air drying" for three
or four days -- and about ten hours in the air. This despite the fact that
the plane is air-tight in flight.
Cleaning my motorcycles with Pledge -- not water -- has meant that I have a
1988 Gold Wing that looks like it just rolled off the assembly line. No
moisture gets into the cracks and crevices, meaning that everything stays
fresh and clean longer. (Water works itself into areas that cannot be
dried, then attracts dirt and slowly gums up the works or corrodes whatever
it's sitting on. In fact, my hangar neighbor with a mid-50s Bonanza just
had to replace a chunk of skin metal on the bottom, due to corrosion. The
diagnosis: Water got into the area and could not drain. Over the years, it
literally ate a hole in the bottom of the plane!)
Pledge is still the best day-to-day cleaner polish for the money -- but it's
evident that a stronger detergent-type cleaner is needed every so often.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old May 1st 04, 02:30 AM
Jay Masino
All you have to do is whip it around the pattern a couple of times after
you wash it. It'll be fine. My plane sat outside for years before I
finally got my hangar. It was no big deal. You're being overly
obsessive.
__!__
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 04:41 PM
I PLEDGE ALLEGIANCE..... ArtKramr Military Aviation 19 October 24th 03 08:51 PM
