Hi All,
Had an incident today where a 2-32 canopy flew open in flight while on tow and hitting some rotor. Long story short, successful landing, but the cromoly tubing frame of the canopy is severely sprung and needs to be repaired or replaced. Would anyone happen to know where abouts of a 2-32 canopy frame? Sheet metal and plexiglass parts not necessarily needed, just the steel frame.... Thanks Steve |
On Mar 5, 8:18*pm, olddogcirrus wrote:
Hi All, Had an incident today where a 2-32 canopy flew open in flight while on tow and hitting some rotor. *Long story short, successful landing, but the cromoly tubing frame of the canopy is severely sprung and needs to be repaired or replaced. *Would anyone happen to know where abouts of a 2-32 canopy frame? *Sheet metal and plexiglass parts not necessarily needed, just the steel frame.... Thanks Steve Same thing happened to us a few years back - the lugs on the cocpit rail get worn, esp if the frame is sprung a little, as most are. Call Les at K&L soaring for parts and dwgs. We had wing and tail damage,as well. Hope that did not happen to you. Glide ratio was severly affected and did not quite make it back to the runway... |
How do we contact you?
Boggs |
Got it.
On Mar 6, 8:08*am, GARY BOGGS wrote: How do we contact you? Boggs |
| Thread Tools | |
| Display Modes | |
| Wanted. ASK-13 sport canopy or frame | Burt Compton - Marfa | Soaring | 0 | February 14th 11 02:13 PM |
| WANTED: 1-26A, B or C Canopy frame | Ted[_2_] | Soaring | 0 | July 12th 08 10:50 AM |
| Cirrus canopy frame repair | Louw Pieters | Soaring | 0 | May 29th 04 07:09 AM |
| Fitting canopy frame to fuselage advice | Deputy Dog | Soaring | 5 | July 27th 03 05:08 AM |
| Need clean 1-26E canopy frame | Robert de León | Soaring | 0 | July 22nd 03 08:16 PM |
