You always learn something when you fly with another pilot.
I've researched the aggressive leaning procedures that keep the O-320 in our 172 N clean running and posted them for our club members. If anyone wants to take pot shots at them, they are at: http://www.baldeagleflyingclub.org/members/Leaning.htm I was flying with a member who hasn't flown the plane in quite a while the other day. We leveled at 4000 feet and he asked me to show him the leaning procedure. To my surprise, nothing I did with the mixture moved the EGT either way. I fiddled for a while without result because it seemed as if the EGT might have frozen. I then looked over and saw that the RPM's were around 2450, about 150 higher than I usually set them at that altitude. I had him back off 100 and the EGT immediately began to respond to the mixture as I am used to. This isn't what I would have expected and seems to me like it might be an indication that we were drawing too much power for the altitude. Another theory, the WOT extra fuel flow is kicking in at a lower throttle setting than I expected, maybe lower than it should due to adjustment creep of the mixture control cable. Anybody want to pontificate? -- Roger Long |
"Roger Long" om wrote in message news ![]() You always learn something when you fly with another pilot. I've researched the aggressive leaning procedures that keep the O-320 in our 172 N clean running and posted them for our club members. If anyone wants to take pot shots at them, they are at: http://www.baldeagleflyingclub.org/members/Leaning.htm I was flying with a member who hasn't flown the plane in quite a while the other day. We leveled at 4000 feet and he asked me to show him the leaning procedure. To my surprise, nothing I did with the mixture moved the EGT either way. I fiddled for a while without result because it seemed as if the EGT might have frozen. I then looked over and saw that the RPM's were around 2450, about 150 higher than I usually set them at that altitude. I had him back off 100 and the EGT immediately began to respond to the mixture as I am used to. This isn't what I would have expected and seems to me like it might be an indication that we were drawing too much power for the altitude. Another theory, the WOT extra fuel flow is kicking in at a lower throttle setting than I expected, maybe lower than it should due to adjustment creep of the mixture control cable. Anybody want to pontificate? Some carburetors have a system, that automatically richens the mixture beyond a certain point on the throttle, to prevent 'high power/lean' settings. If this existed on your unit, and was set too aggressively, it could give the behaviour you saw. Best Wishes |
Roger,
According to the POH, what is 2450 rpm at that altitude and temperature in terms of % power? It seems as if it's a pretty low power setting. You should not have been anywhere near wide open throttle, so I'd have someone take a peek at the EGT as well as the mixture control. You should lean the mixture any time you are flying level. I don't know what you mean by "aggressive" leaning, just lean to avoid the areas where the temperatures and pressures are highest, so either operate at peak EGT or lean of peak if your engine will do it, or about 100 degrees rich of peak. If you are running at 65% power or less, you can't hurt the engine no matter how you lean it, the temperatures and pressures aren't high enough to induce detonation (see www.gami.com for a detailed discussion of what's going on inside the cylinders). Once you get near peak EGT the cylinder head temps start dropping very nicely, so you burn less fuel and keep things cooler, both of which will make your engine happy. Your EGT may just need adjustment or your mixture control may need a tweak. You didn't say whether you leaned to the point of roughness without getting a rise out of the EGT, something that might indicate a problem with the gauge. All the best, Rick "Roger Long" om wrote in message .. . You always learn something when you fly with another pilot. I've researched the aggressive leaning procedures that keep the O-320 in our 172 N clean running and posted them for our club members. If anyone wants to take pot shots at them, they are at: http://www.baldeagleflyingclub.org/members/Leaning.htm I was flying with a member who hasn't flown the plane in quite a while the other day. We leveled at 4000 feet and he asked me to show him the leaning procedure. To my surprise, nothing I did with the mixture moved the EGT either way. I fiddled for a while without result because it seemed as if the EGT might have frozen. I then looked over and saw that the RPM's were around 2450, about 150 higher than I usually set them at that altitude. I had him back off 100 and the EGT immediately began to respond to the mixture as I am used to. This isn't what I would have expected and seems to me like it might be an indication that we were drawing too much power for the altitude. Another theory, the WOT extra fuel flow is kicking in at a lower throttle setting than I expected, maybe lower than it should due to adjustment creep of the mixture control cable. Anybody want to pontificate? |
Thanks for the very complete reply.
That's the way I operate the engine. By "Aggressive" leaning, I mean doing just what you describe as opposed to just leaning enough to see an uptick on the EGT or start of RPM rise. I can't go LOP with my carburated O-320 without it getting rough. I know "Aggressive" means something more with Gami injectors, engine monitor, etc. I do "Unaggressive" leaning when I'm busy, climbing above 2000 feet, etc., and just want to take the edge off the Lycoming's tendency to foul plugs. I did lean enough for the engine to get rough. Walter Atkinson said over in the CPA forum that there is no physical way what I observed could have happened unless the gauge stuck. Why it came unstuck as soon as we reduced power a bit is just one of those mysteries. I'll have to keep an eye on it. -- Roger Long |
*****Walter Atkinson said over in the CPA forum*****
Walter Atkinson should stick to dentistry. He once told me that my IO-520-D was more like a Wright R-3350 Cyclone than an IO-470-D. I would take anything he says with one of those 50 pound sacks of salt they sell for water softeners. Karl "curator" N185KG |
Pontificate? Yupporamma! Fuel cools which is why you did not see the the high EGT which you were expecting. Have a great one! Bush On Fri, 07 Nov 2003 13:57:40 GMT, "Roger Long" om wrote: You always learn something when you fly with another pilot. I've researched the aggressive leaning procedures that keep the O-320 in our 172 N clean running and posted them for our club members. If anyone wants to take pot shots at them, they are at: http://www.baldeagleflyingclub.org/members/Leaning.htm I was flying with a member who hasn't flown the plane in quite a while the other day. We leveled at 4000 feet and he asked me to show him the leaning procedure. To my surprise, nothing I did with the mixture moved the EGT either way. I fiddled for a while without result because it seemed as if the EGT might have frozen. I then looked over and saw that the RPM's were around 2450, about 150 higher than I usually set them at that altitude. I had him back off 100 and the EGT immediately began to respond to the mixture as I am used to. This isn't what I would have expected and seems to me like it might be an indication that we were drawing too much power for the altitude. Another theory, the WOT extra fuel flow is kicking in at a lower throttle setting than I expected, maybe lower than it should due to adjustment creep of the mixture control cable. Anybody want to pontificate? |
| Thread Tools | |
| Display Modes | |
| Burning out a Magneto Drop | O. Sami Saydjari | Owning | 23 | March 2nd 04 10:42 PM |
| Piper Commanche vs Money 201 | O. Sami Saydjari | Owning | 64 | December 2nd 03 04:57 AM |
| Leaning / step climbing? | aaronw | Piloting | 30 | November 17th 03 06:44 PM |
| Leaning with EGT? | Chris W | Home Built | 3 | September 18th 03 08:28 PM |
| More About Leaning During Climb | Dan Luke | Owning | 13 | July 11th 03 03:36 PM |
