There "was" and adf in my plane before I bought it, and received the
adf in a box when I bought it. The tray was still installed in the avionics stack, and I had a kr85 reveiver, KI225 head, and 42 loop antenna in the box. I put the receiver back in, and had my mechanic put the loop antenna back on the plane during annual. I tested out the system last night. It hears AM Radio well... ![]() It idented a beacon fine, but the needle wouldn't swing to it on the ground. I decided to fly and check it out. Sure enough, once I was airborne the needle swung, and that's when I noticed my problem. Isn't the needle supposed to point "toward" the NDB? the head was acting more like a VOR head in the from position. I know an NDB doesn't have radials, so why would my needle be pointing toward the tail of the plane as I approach the beacon, and then swing toward the prop as I pass over? Thanks dp |
| Thread Tools | |
| Display Modes | |
