The "offical" LXNAV V7 thread
Old November 2nd 12, 01:56 PM posted to rec.aviation.soaring
Steve Koerner
Default The "offical" LXNAV V7 thread
Waremark:
It's now sold. I'll trust that it's new owner will value that "other stuff" more than I did. Actually though, the ClearNav vario offers quit a bit of useful other stuff too.
Old November 3rd 12, 05:24 AM
dbrunone dbrunone is offline
Member
First recorded activity by AviationBanter: Oct 2011
Does anyone have an in-flight video of the V7 in action?
Old November 26th 12, 02:10 AM posted to rec.aviation.soaring
Dan[_13_]
I'm flying with a V7/Nano/Oudie combination, I was wondering if anyone else
had problems with this setup making Igc files when the set up is turned on
and then off with out moving the plane.
Dan
Old November 26th 12, 07:55 AM posted to rec.aviation.soaring
Naviter Info
Did Nano create an IGC file or did Oudie create one? please send such file to support at naviter dot com - it must be an easy settings fix. Or even just a matter of a firmware upgrade on any or all devices.
Regards,
Andrej Kolar
glider pilots use
http://www.Naviter.com
Dan
Old November 27th 12, 03:52 AM posted to rec.aviation.soaring
Dan[_13_]
On Sunday, November 25, 2012 11:55:17 PM UTC-8, Naviter Info wrote:
Did Nano create an IGC file or did Oudie create one? please send such file to support at naviter dot com - it must be an easy settings fix. Or even just a matter of a firmware upgrade on any or all devices. Regards, Andrej Kolar -- glider pilots use http://www.Naviter.com On Monday, November 26, 2012 3:10:58 AM UTC+1, Dan wrote: I'm flying with a V7/Nano/Oudie combination, I was wondering if anyone else had problems with this setup making Igc files when the set up is turned on and then off with out moving the plane. Dan
Andrej,
It was the Oudie that created the file. All devices are running the latest firmware.
If you don't recall I sent you a file back in March of this year, to which
you responded "this will take some time". I waited 3 months, and sent a follow
up email to check on progress, to which you responded," please send me a file"
which I did. Then I was told this would not be addressed until sometime next year.
(I'm not holding my breath)
Regards,Dan
Old November 27th 12, 04:20 AM posted to rec.aviation.soaring
Tim Taylor
Looking for a wiring diagram for the LXNAV V7 to Oudie cable. I tried following the diagrams in the V7 manual but did not have success even using a proto board to try different configurations.. The offical cable I have has five wires rather than the four that the diagrams show. I would like to build cables for a pass through connection in the panel.
Old November 27th 12, 01:26 PM posted to rec.aviation.soaring
Richard[_9_]
Check your email for the cable drawing.
Don't get dyslexia you may brick the stuff.
Richard
www.craggyaero.com
Old June 3rd 14, 07:10 AM posted to rec.aviation.soaring
Can someone post the wiring diagram to connect the Vertica V2 / Avier to the V7?
Thank you,
Nick
Old February 27th 14, 02:03 AM posted to rec.aviation.soaring
ES
Has anyone had luck uploading tasks from Oudie to V7? This topic isn't discussed in the user guide, and I'm not having any luck repeating the settings in the youtube video on the subject (device = "LXNAV - Nano", interface = "COM4:", speed = "4800bps".
In the video, there is very quick connection and transfer.
When I try it (using the latest V7 firmware and Oudie version), I get "Connecting" on the Oudie, and the communication icon on the V7, but nothing else.
thanks
ted/ES
Old February 27th 14, 09:25 PM
Eurofighter Eurofighter is offline
Junior Member
Try a higher baud rate
thanks
ted/ES
LXNAV V7 - Reviews? David Reitter Soaring 10 October 21st 14 12:41 AM
New LXNAV LX9000 Overview Video Paul Remde Soaring 0 April 21st 12 01:33 AM
LXNAV V7 Paul Remde Soaring 2 November 2nd 11 12:31 AM
LXNAV Nano and LX 9000 Overview Videos Available Paul Remde Soaring 3 February 28th 11 01:58 PM
HELP! Need offical Blanik L-13 Canopy Strap John Scott Soaring 4 March 3rd 08 05:03 AM
