Battery explosion?
Old January 11th 04, 03:00 PM
Roger Long
Default Battery explosion?
Has anyone heard or experienced this?
On changing the battery in our plane the other day, the A&P said, "You had a
battery explosion." On looking closely, I could see that the box was bowed
out and rounded as if someone had tried to inflate it with air. I'd
noticed that it wasn't exactly square and the cover didn't fit very well but
thought it was just poor workmanship.
He said it probably happened during starting from hydrogen build up that the
propwash hadn't had a chance to blow away yet and the pilot thought it was a
backfire. No harm done except we'll need a new box because of corrosion.
It could have happened years ago.
Roger Long
Old January 11th 04, 05:13 PM
Peter Duniho
"Roger Long" om wrote in
message ...
Nope, but I guess it seems plausible. On my airplane, both batteries have
vents overboard to allow any gases out. I would hope that, even if gas
accumulated in the battery box, an ignition source wouldn't be forthcoming,
but I guess I can't rule that out.
Maybe as part of the repairs, you should add vents to the battery box or
batteries (my batteries each have a vent built in, to which a hose leading
outside is connected).
Pete
Old January 11th 04, 05:43 PM
Ron Natalie
"Peter Duniho" wrote in message ...
message ...
I had it happen in my truck. Battery exploded but evidently kept working but
was leaking acid slowly all over the battery holder and into the cables. Had to
get them all replaced.
Old January 11th 04, 07:21 PM
Roger Long
It actually wasn't the battery which exploded in this case (unless it was
long ago and didn't make it into the logs). It was the gas around the
battery. The battery was fine.
Roger Long
Ron Natalie wrote in message
m...
in
message ...
have
forthcoming,
but
Had to
Old January 11th 04, 10:16 PM
G.R. Patterson III
It's not uncommon for batteries to explode during charging if they've been deeply
discharged. It's a good idea to remove the caps on batteries that have them when
charging one.
Your mechanic is correct. What probably happened is that the battery was deeply
discharged starting the plane on an occasion on which it was hard to start. The
gasses were produced as the alternator charged the battery and something set it
off.
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Old January 11th 04, 07:30 PM
Jim Weir
"something" = master relay contacts (generally bolted to the back or side of the
battery box), alternator slip rings, starter commutator/brushes, generator
commutator/brushes...
"G.R. Patterson III"
-gasses were produced as the alternator charged the battery and something set
it
-off.
http://www.rst-engr.com
Old January 11th 04, 08:44 PM
Franklin Newton
Experienced; In a U6-A, had a battery explosion.
Heard of; In an O1-A, A classmate had a battery explosion.
message ...
a
bowed
but
a
Roger Long
Old January 12th 04, 07:18 AM
Morgans
message ...
a
bowed
but
a
Roger Long
Funny that this should come up. I had my first experience with battery
explosions, this past Friday.
An associate was charging a tractor battery with a large automotive charger
at a high rate, and asked me to come over to see if I thought it was
charging well. I went to see, and it was bubbling away to beat the band.
He then reached down to check the tightness of the charger on the terminal.
All this happened so fast, and I was not able to prevent what you all know
happen next. It sparked, and let out a very surprisingly loud, BAM!!!. A
little acid splashed about, but fortunately, I wear glasses, so no great
harm was done, other than seriously ringing eardrums.
If that large of an explosion went off in a battery box, it is lucky that it
didn't completely split it open.
Sh*t. More hearing shot to hell, that I don't have to give!
Old January 12th 04, 05:29 AM
Mark Mallory
Reminds me of my high-school days when two friends were doing some welding with
a oxy-acetylene torch. During a break, they decided to capture a small amount
of near-stoichiometric gas mixture in a sandwich-sized plastic bag, tie off the
end, and put a match to it ('just to see what would happen'.) I entered the
garage just as my friend was bringing the match next to the bag.
The bag instantly exploded with absolutely no smoke or residue, but with the
loudest BANG I had ever heard. All three of us walked out of the garage with
our ears ringing, temporarily unable to hear normal conversation. Nobody hurt,
and hearing came back after a few minutes, but ears still ringing even after a
half hour or so.
Old January 12th 04, 03:30 PM
James M. Knox
Mark Mallory wrote in
welding with a oxy-acetylene torch. During a break, they decided to
capture a small amount of near-stoichiometric gas mixture in a
sandwich-sized plastic bag, tie off the end, and put a match to it
Wimps... we used to use those plastic clothes bags (which tend to leak
badly, by the way). [Of course, we also melted a small aluminum TV antenna
this way one day... ]
Thinking back on it all, it's very surprising that we survived to what now
passes for adulthood.
James M. Knox
TriSoft ph 512-385-0316
1109-A Shady Lane fax 512-366-4331
Austin, Tx 78721
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 05:30 PM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 03:38 PM
Battery storage? Roger Long Owning 10 January 14th 04 03:35 PM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 02:29 PM
ICom A-5 Question - Battery Level Indicator Harry Gordon Piloting 22 December 5th 03 01:07 AM
