I am confused with the wiring diagram of the manual. Can anyone help
clear up some confusion on the placement of the PTT wires? Where do wires 17 & 25 go in conjunction with the two wires that come from the PTT on the control stick? |
Pins 13 and 25 are ground. Pin 17 is PTT, grounding it switches to
tramsmit. So one wire from the PTT switch (doesn't matter which one) goes to pin 25 (or 13, or ground bus bar or anything else connected to radio ground) and the other wire to pin 17. However, I ask, if you can't follow the diagram in the manual, should you be wiring up your own radio instead of getting somebody who knows what they are doing to do it for you? 8-) , Peter At 13:53 18 October 2012, Scott Alexander wrote: I am confused with the wiring diagram of the manual. Can anyone help clear up some confusion on the placement of the PTT wires? Where do wires 17 & 25 go in conjunction with the two wires that come from the PTT on the control stick? |
On Thursday, October 18, 2012 6:53:59 AM UTC-7, Scott Alexander wrote:
I am confused with the wiring diagram of the manual. Can anyone help clear up some confusion on the placement of the PTT wires? Where do wires 17 & 25 go in conjunction with the two wires that come from the PTT on the control stick? Scott, You might find the answer in the similar thread discussed few days ago https://groups.google.com/forum/?hl=...ng/oaFM5FCLNMc Robert |
| Thread Tools | |
| Display Modes | |
| Becker AR 4201 Radio For Sale | Helmut Bauer | Soaring | 2 | October 2nd 12 08:55 AM |
| FS: Becker AR 4201 | Don[_4_] | Soaring | 0 | September 19th 12 06:16 PM |
| Wiring diagram for GA radio/mic? | Gary G | General Aviation | 15 | November 23rd 05 04:33 PM |
| Becker 4201 multiple failures | Jean | Soaring | 0 | August 9th 04 09:43 AM |
| Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 07:32 PM |
