Hello to the group !
Does anybody use the VertexStandard Pilot VXA-210? My question: The manual says that the led on top of the unit will glow green if it is receiving a carrier and the color will change to red when transmitting. With my handheld the led is only glowing green when receiving; the led goes out when transmitting. Is this like your unit behaves ? Thanks Frank |
Don't have my vxa-700 manual here. But, I seem to remember this is
programmable. Jerry Frank Ivo Streckebein wrote: Hello to the group ! Does anybody use the VertexStandard Pilot VXA-210? My question: The manual says that the led on top of the unit will glow green if it is receiving a carrier and the color will change to red when transmitting. With my handheld the led is only glowing green when receiving; the led goes out when transmitting. Is this like your unit behaves ? Thanks Frank |
Hello to the group ! Does anybody use the VertexStandard Pilot VXA-210? My question: The manual says that the led on top of the unit will glow green if it is receiving a carrier and the color will change to red when transmitting. With my handheld the led is only glowing green when receiving; the led goes out when transmitting. Is this like your unit behaves ? Download the manual from the manufacturer's online website. |
Jay Smith schrieb:
Frank Ivo Streckebein wrote: Hello to the group ! Does anybody use the VertexStandard Pilot VXA-210? My question: The manual says that the led on top of the unit will glow green if it is receiving a carrier and the color will change to red when transmitting. With my handheld the led is only glowing green when receiving; the led goes out when transmitting. Is this like your unit behaves ? Download the manual from the manufacturer's online website. I have done that, additionally i have the original manufacturer`s manual here in front of me - there is nowhere mentioned anything about a programmable feature concerning the tx-led for the vxa-210. Otoh the manual of the vxa-700 states exactly how to programm the rx/tx led, but again: I´m talking about the vxa-210. Frank |
On Tue, 17 Feb 2004 23:23:50 +0100, Frank Ivo Streckebein
wrote: Hello to the group ! Does anybody use the VertexStandard Pilot VXA-210? My question: The manual says that the led on top of the unit will glow green if it is receiving a carrier and the color will change to red when transmitting. With my handheld the led is only glowing green when receiving; the led goes out when transmitting. Is this like your unit Two separate leds inside the lens, so could be a problem with one. Does the unit actually transmit? If so, may be simply in the led circuitry for the red led. While I don't have a VXA-210, I do have VX-5R (amateur radio ht) and there is indeed a method of enabling or disabling the led to save power, but that action, which is #17 BUSY/TX LED on my unit, affects both colors so probably isn't your problem. Even though different radios, Yaesu follows somewhat closely the menu system on their radios, so you probably have this setting also. You might cycle this setting to see if that affects the problem. ....Edwin ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~ Edwin Johnson ....... ~ ~ http://www.shreve.net/~elj ~ ~ ~ ~ "Once you have flown, you will walk the ~ ~ earth with your eyes turned skyward, ~ ~ for there you have been, there you long ~ ~ to return." -- da Vinci ~ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
Edwin Johnson schrieb:
Two separate leds inside the lens, so could be a problem with one. Does the unit actually transmit? If so, may be simply in the led circuitry for the red led. Yes, the unit transmits correct. While I don't have a VXA-210, I do have VX-5R (amateur radio ht) and there is indeed a method of enabling or disabling the led to save power, but that action, which is #17 BUSY/TX LED on my unit, affects both colors so probably isn't your problem. Even though different radios, Yaesu follows somewhat closely the menu system on their radios, so you probably have this setting also. You might cycle this setting to see if that affects the problem. Sorry, but there is no such item in the setup menu for the vxa-210. Frank |
Nope, my VXA-210 LED glows red during transmit and green during receive.
Since you're able to transmit ok, perhaps it's an LED or circuit problem of some sort. -- Jack Allison PP-ASEL "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
Jack Allison schrieb:
Nope, my VXA-210 LED glows red during transmit and green during receive. Since you're able to transmit ok, perhaps it's an LED or circuit problem of some sort. Yes, yesterday the same statement came from Yaesu USA, i have contacted them last week. They were very helpfull and provided me an adress of a repair facility in Europe, today i have shipped my unit. Hope the repair will be done as fast as the tech support reacts. Thanks for your answers. Frank |
Great! I've heard good things about thier support but have no firsthand
experience. Glad to know that they were so helpful. I love my VXA-210 and use it a lot. IMHO, one of the best investments in my flight bag. -- Jack Allison PP-ASEL "When once you have tasted flight, you will forever walk the Earth with your eyes turned skyward, for there you have been, and there you will always long to return" - Leonardo Da Vinci (Remove the obvious from address to reply via e-mail) |
| Thread Tools | |
| Display Modes | |
| GPS Handheld | Kai Glaesner | Instrument Flight Rules | 2 | November 16th 04 05:01 PM |
| Terrain-Aware Handheld vs. IFR GPS? | C Kingsbury | Instrument Flight Rules | 7 | November 14th 04 06:33 AM |
| Upgrade handheld GPS, or save for panel mount? | [email protected] | Owning | 7 | March 8th 04 04:33 PM |
| Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 02:10 PM |
| FS: GPS - Handheld II Morrow - Apollo 920 Moving Map | robert | Aviation Marketplace | 1 | February 6th 04 03:21 AM |
