ARC RT-359A connections
Old January 8th 14, 11:04 AM posted to rec.aviation.homebuilt
Lars
Default ARC RT-359A connections
Hi guys!
We have an old ARC RT-359A transponder in our Jodel D119. It has been acting up lately and I am thinking about replacing the antenna cable. Question is, what is the connector on the transponder side? The antenna is a regular BNC and the cable is RG58/U so that is pretty standard, but I am too ignorant to identify the connector at the other side. The transponder sits in a tray with a slide-in connector that looks like maybe a C-type male connector without the outer bayonet ring.
Anyone with a clue?
Thanks!
/Lars
Old January 8th 14, 01:58 PM posted to rec.aviation.homebuilt
Richard[_8_]
On 1/8/2014 4:04 AM, Lars wrote:
Hi guys!
Anyone with a clue?
Thanks!
/Lars
Don't rightly know.
But you might try:
http://www.aeroelectric.com/Installa..._459A_859A.pdf
Old January 8th 14, 09:49 PM posted to rec.aviation.homebuilt
Lars
Thanks for the tip, but no luck there. More luck in my closet, where I found a disused King KX175B, sporting no less than two similar connections. Seems this is (was?) the standard HF connector for bracket-mounted avionics. Better still, I still had the old bracket, containing two patch-cables with the mysterious connector in the bracket end and female BNC in the other. So what I am going to do now is to get a standard BNC cable with finished male connectors and use one of the patch-cables as a go-between.
I still would like to broaden my knowledge, so anyone with info on the correct designation of the connector is welcome to a hop in the Jodel, if you can make a trip to ESSL (Linkoping Sweden).
Thanks!
/Lars
On Wednesday, January 8, 2014 11:04:33 AM UTC+1, Lars wrote:
Hi guys!
Anyone with a clue?
Thanks!
/Lars
Old July 8th 14, 10:01 PM posted to rec.aviation.homebuilt
On Wednesday, January 8, 2014 4:04:33 AM UTC-6, Lars wrote:
Hi guys!
Anyone with a clue?
Thanks!
/Lars
I know this is really old news that I found while searching something else, but I sell the connectors/cables with this blind mate connector on ebay--look for seller ID dtmedin. It is a specialized connector made by TED in Kansas City, Missouri, USA. They are a bear to install, and I recommend RG-400 cable, not RG58. Just had a retired gentleman from Linkoping visiting our area!
Colibri V3 connections Steve Soaring 3 February 13th 12 01:38 PM
Narco Com IIA Wiring connections? Rod Home Built 4 October 12th 11 08:08 AM
LX4000 GPS Connections Brian[_1_] Soaring 4 April 28th 08 05:38 AM
RT-359A transponder question Lars Home Built 6 December 2nd 06 05:48 PM
Hotellier connections Mike Soaring 38 September 28th 04 05:30 PM
