Accident report on the midair at Tenino
Old June 9th 04, 07:59 AM
C J Campbell
Default Accident report on the midair at Tenino
Both pilots are well known and respected in the Puget Sound area. Amazing
that the pilot of the 170 was able to fly his plane at all:
NTSB Identification: SEA04FA083B
14 CFR Part 91: General Aviation
Accident occurred Sunday, May 16, 2004 in Tenino, WA
Aircraft: Cessna 210J, registration: N3329S
Injuries: 1 Fatal, 1 Minor.
This is preliminary information, subject to change, and may contain errors.
Any errors in this report will be corrected when the final report has been
completed.
On May 16, 2004, approximately 2040 Pacific daylight time, a Cessna 170B,
N3510D, and a Cessna 210J, N3329S, collided in flight approximately five
nautical miles southeast of Tenino, Washington. The Cessna 170B had departed
Roseburg, Oregon, and was en route to the Wax Orchards Airport, Vashon
Island, Washington. The Cessna 210J had departed Camas, Washington, and was
en route to Paine Field, Everett, Washington. There was one occupant onboard
each aircraft. The pilot of the Cessna 210J, a certificated commercial
pilot, sustained fatal injuries while the certificated private pilot of the
Cessna 170B sustained minor injuries. Visual meteorological conditions
prevailed and both aircraft were operated under 14 CFR Part 91 regulations.
According to the Federal Aviation Administration (FAA), both pilots received
weather briefings but neither pilot filed a flight plan, and neither
aircraft had requested or were receiving air route traffic control radar
services at the time of the collision.
The pilot of the Cessna 170B reported that he was level at 3,500 feet mean
sea level and had just changed his heading from 350 degrees to 318 degrees.
The pilot stated, "I was looking down at my map as part of this 'normal
scan' that I do when the collision occurred." The pilot stated, "I never saw
the other airplane." The pilot further stated that the aircraft pitched down
and went into an uncommanded left turn, requiring him to stabilize the angle
of bank by holding full right aileron. The pilot reported that he then
realized that the engine had come off the airplane, but he was still able to
maintain the nose down attitude and keep his speed up. The pilot further
reported that he then attempted to move the elevator and rudder enough to
see if they were responsive, which they were. The pilot stated that as the
airplane continued in the left turn through a southerly heading to an
easterly heading he saw what appeared to be parts of "something" falling out
of the sky below him. The pilot said, "...that's when I thought I'd been hit
by another airplane." The pilot reported that as he proceeded turning and
losing altitude rapidly, he picked out a field where he thought he could
land. The pilot said, "I moved the flap handle a little to see how much they
moved, and when I saw they worked I decided to add some flap to reduce my
speed as I approached the field." The pilot stated that he then applied
right rudder to raise the left wing before "clipping" the tops of some trees
and going through one power line wire which bordered the field on the south.
The pilot stated that after the airplane impacted the ground and came to
rest, he immediately exited the airplane and sought help at a nearby house.
The aircraft had come to rest in an inverted position on a magnetic heading
of 120 degrees. There was no post impact fire.
A witness, who is also a private pilot and the owner of the property where
the Cessna 210J came to rest, reported that while in his house he heard an
airplane flying around, prompting him to go outside to see what it was. The
witness stated that he looked up and thought he heard airplanes overhead,
then saw the two accident aircraft coming together. The witness further
stated, "[i] saw them about 5 to 8 seconds before they hit. Both were
straight and level. Neither took evasive action in any way." The witness
stated that one was heading north and the other one was heading northeast
when he saw them hit and parts started coming at him. The witness further
stated that after the parts hit the ground he looked up again and saw "the
silver aircraft" gliding north without an engine before it went out of sight
over some trees.
The Cessna 170B's engine was located approximately one-half mile southwest
of where the aircraft came to rest. The airplane's right cabin door and left
lower cowling were found approximately three-quarters of a mile south of
this location.
The Cessna 210J's engine, propeller, and main cabin area were located
approximately one-quarter of a mile south of where the Cessna 170B came to
rest. The wing was located approximately 400 feet south of the main cabin
area, and the airplane's tail section was discovered in a thick brush area
one-half mile south of the main cabin.
At 2031, a special aviation surface weather observation taken at the Olympia
Airport, Olympia, Washington, located 11 nautical miles northwest of the
collision reported wind 220 degrees at 5 knots, visibility 10 statute miles,
broken clouds at 2,600 feet, overcast clouds at 4,900 feet, temperature 12
degrees C, dew point 7 degrees C, and an altimeter of 30.03 inches of
Mercury.
Old June 9th 04, 01:25 PM
Karl Treier
OK on that heading shouldn't you be at Even + 500' for VFR? Amazing that
the CG was not shifted aft so far as to make it impossible to pitch down.
Old June 9th 04, 03:55 PM
Peter R.
This would depend on the terrain elevation. VFR cruise altitudes are
required above 3,000 feet AGL (above ground level).
Peter
Old June 9th 04, 03:56 PM
Peter R.
Whoops, I should add that this is valid for VFR flight in the US, where
the accident occurred. I have no idea about the regulations in other
countries.
Peter
Old June 9th 04, 04:27 PM
Steven P. McNicoll
"Karl Treier" wrote in message
Not required if you're within 3000 feet of the surface. The report doesn't
give a precise location, but there is terrain southeast of Tenino of
sufficient elevation.
Old June 9th 04, 04:58 PM
C J Campbell
It appears that both planes were below 3000' AGL. Although Tenino is at
about 300' the surrounding terrain pokes up over 1000.' It is a favorite
area for instructors to demonstrate to students how rising terrain can meet
lowering clouds, since such conditions can be found there very frequently.
In fact, that is where my instructor taught me about CFIT when I was a
student. Reading the accident report it appears that both planes may have
had their altitude restricted by low clouds, which is pretty much a normal
state of affairs around here. The report notes that neither pilot was using
flight following. It does not say that flight following might well have not
been available in that area and that altitude. Radio reception out there is
spotty at best. I almost always lose both radio and radar contact somewhere
in the area south of SCOOT, even though I am flying a published IFR approach
and on an IFR flight plan.
The other thing is that from that area north there is a lot of flight
training going on, with airplanes constantly maneuvering, climbing,
descending, and practicing IFR maneuvers with one pilot under the hood. It
is just inside the 15 DME arc for the VOR/DME approach into Olympia and near
the final approach course and not all that far from the published holding
pattern for the missed approaches into Olympia. There are likely to be two
or three planes flying these approaches at any one time. Consequently there
are so many airplanes flying at odd altitudes and odd directions that for
all practical purposes the VFR altitude rules might as well not exist. For
that matter, these have to be the most widely ignored regulations in the
country, especially in the West.
You have to keep a sharp eye out. Sometimes even that is not enough.
I have always been told that it is impossible to pitch down if your engine
comes off. You will pitch up, stall, and die. That is what I have always
been told. I guess in a 170, at least, that is not true. I would guess that
the engine weighs about 270 lbs. with accessories and sits about 20 inches
forward of the datum. He also lost the prop and part of the cowl. The 170 is
a tailwheel airplane, so landing gear would be unaffected. (Now there is an
interesting argument in favor of tailwheel airplanes -- if your engine falls
off, you don't lose your nose gear!) At the same time, losing all that
weight might improve your glide significantly.
He probably would not even have nosed over if he hadn't hit the trees and
power line.
Old June 9th 04, 06:04 PM
Bela P. Havasreti
On Wed, 9 Jun 2004 07:58:32 -0700, "C J Campbell"
The raw radar returns (tapes) had them both at approx. 3500 msl.
As I recall, the weather was fairly decent that day (I was up/
flying in the general vicinity that day).
Bela P. Havasreti
power line.
Old June 9th 04, 07:05 PM
kage
The accident site is JUST at the border of where one would get a traffic
alert from the new Garmin TIS system.
Karl
N185KG
"Bela P. Havasreti" wrote in message
Bela P. Havasreti
that
down.
meet
frequently.
normal
using
not
is
somewhere
approach
It
near
two
there
For
engine
that
inches
is
an
falls
power line.
Old June 9th 04, 07:09 PM
Steven P. McNicoll
"kage" wrote in message
Eh? Why does the location make a difference?
Old June 9th 04, 11:21 PM
CV
No, less weight does not significantly improve glide
performance, it just shifts your best glide to a lower
speed range. (It will improve your glide downwind
though, and make it worse into wind)
More important however would be the aerodynamic shape of
whatever was left of the nose after having prop, engine and
part of the cowling fall off. It is not too bold a bet to
say the aerodynamic characteristics will have been clearly
worse after the damage than before, thus more drag and
worse glide.
CV
Who's At Fault in UAV/Part91 MAC? Larry Dighera Piloting 72 May 1st 04 12:28 AM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 13th 03 12:01 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 02:27 PM
