Engine designator question
Old August 18th 04, 06:18 PM
jharper aaatttt cisco dddooottt com
Default Engine designator question
I know what *most* of the letters that show up in engine designators
mean (e.g. TSIO-540, AEIO-540), but there are two I can't figure
out and can't find any information about, viz S and E. They seem to show
up with T (turbo) and A (aerobatic/inverted) respectively, but that
do they actually mean?
John
Old August 18th 04, 06:42 PM
Jim Weir
The "S" associated with T (i.e. TSIO-540) means supercharged. Turbo is not the
only method of supercharging. There have been engines built with the
supercharge compressor being engine-driven, electric motor driven, and
wind-driven. Turbo (driving the supercharger off the exhaust gas stream) is
just the currently popular way of doing it.
"E", so far as I know, is just an archaic way of designating "Engine" before we
had the current "O" for opposed and other minor variants. However, I am not
absolutely sure on this one.
"jharper aaatttt cisco dddooottt com" "jharper aaatttt cisco dddooottt com"
-I know what *most* of the letters that show up in engine designators
-mean (e.g. TSIO-540, AEIO-540), but there are two I can't figure
-out and can't find any information about, viz S and E. They seem to show
-up with T (turbo) and A (aerobatic/inverted) respectively, but that
-do they actually mean?
-Thanks,
- John
http://www.rst-engr.com
Old August 18th 04, 07:03 PM
Peter Duniho
com" wrote in message news:1092845688.169721@sj-nntpcache-5...
The "S" is actually part of "TS", which stands for "TurboSupercharged". I
believe, but am not certain, that the "E" is similarly part of "AE", as in
"AErobatic".
Pete
Old August 18th 04, 08:09 PM
Bob Moore
show
Nomenclatura
Lycoming's specific convention for post-WWII aircraft piston engine
designation is as follows. Note that this convention is fairly standard
and applicable to many other manufacturers.
C-D-M
Whe
C Letters indicating the engine's configuration:
I Fuel injected
O Opposed type (pancake-style)
X X-type engine
R Radial type engine
G Engine is geared
T[S] Engine is turbocharged
S Engine is supercharged, EXCEPT for
most Continental TURBOcharged engines. These
are designated "TS". See below.
L Engine is liquid-cooled or left-turning (ugh!)
A Engine is designed for aerobatics (DRY SUMP)
AE Engine is designed for aerobatics (WET SUMP)
M Engine is designed for unmanned drone
H Engine is designed for helicopter installation
V Engine is designed to have the crankshaft in
the vertical, not horizontal, plane.
D The engine's displacement in cubic inches.
M The manufacturer's "data" - often indicating
what types of accessories or engine revisions.
Bob Moore
ROP masking of engine problems Roger Long Owning 4 September 27th 04 08:36 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 07:42 PM
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 04:03 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 05:09 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
