Not trying to be alarmist, just thinking that all of us GA folks can
keep an eye out for something odd- http://www.eaa.org/communications/eaanews/advisory.pdf Len PP-SEL |
"Len" wrote in message ... Not trying to be alarmist, just thinking that all of us GA folks can keep an eye out for something odd- http://www.eaa.org/communications/eaanews/advisory.pdf Len PP-SEL Install hidden security switches to prevent unauthorized startup of aircraft???? how could you hide a switch on an airplane wouldn't you need a 337 and a description on the switch ware it's going to be placed? |
sure.. I think you would... but that would be buried in the aircraft maint
logs.. I don't think the thief pilot would know where to look... also remember this is TSA... they do not know anything about aircraft.. maint requirements or paper work... look at the fiasco they just unleashed with 49CFR1552 They are still writing waivers and interpretations on what they really meant to cover. BT "NW_PILOT" wrote in message ... "Len" wrote in message ... Not trying to be alarmist, just thinking that all of us GA folks can keep an eye out for something odd- http://www.eaa.org/communications/eaanews/advisory.pdf Len PP-SEL Install hidden security switches to prevent unauthorized startup of aircraft???? how could you hide a switch on an airplane wouldn't you need a 337 and a description on the switch ware it's going to be placed? |
BTIZ wrote: sure.. I think you would... but that would be buried in the aircraft maint logs.. I don't think the thief pilot would know where to look... Of course they would, 'cause the FAA would require that you install a large red placard telling you to turn it on before flight. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
BTIZ wrote:
also remember this is TSA... they do not know anything about aircraft.. maint requirements or paper work... look at the fiasco they just unleashed with 49CFR1552 I guess they don't know anything about cutting the P-leads and hand propping, either. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
Jay Masino wrote: I guess they don't know anything about cutting the P-leads and hand propping, either. I really doubt that that's an issue on the Pawnee. Or most of the other aircraft with which the TSA is concerned. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
G.R. Patterson III wrote:
I really doubt that that's an issue on the Pawnee. Or most of the other aircraft with which the TSA is concerned. Yea. Of course, it's sometimes hard to tell which are the "aircraft with which the TSA is concerned" ![]() -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
"Len" wrote in message ... Not trying to be alarmist, just thinking that all of us GA folks can keep an eye out for something odd- http://www.eaa.org/communications/eaanews/advisory.pdf Len PP-SEL Install hidden security switches to prevent unauthorized startup of aircraft???? how could you hide a switch on an airplane wouldn't you need a 337 and a description on the switch ware it's going to be placed? and immediately falls apart when some-one does a conversion onto that machine. Remember the ground switch on the PA22 ?????? |
"Len" wrote in message ... Not trying to be alarmist, just thinking that all of us GA folks can keep an eye out for something odd- http://www.eaa.org/communications/eaanews/advisory.pdf Len PP-SEL Install hidden security switches to prevent unauthorized startup of aircraft???? how could you hide a switch on an airplane wouldn't you need a 337 and a description on the switch ware it's going to be placed? Yes a 337 is required but only the local FAA office has the info as to the location. Most aerial application aircraft don't require a key to either get into, or to start. Hidden master switches are quite common now and especially for the expensive turbine aircraft. Pretty easy to get in for a million dollars on the newer turbine spray planes. For the most part security on spray aircraft is pretty tight in that they are normally on a private strip and strangers stick out like a sore thumb. A spray plane is not attractive to smugglers because of its low speed and limited fuel. Most of them get stolen for the component parts like engine, GPS, SATLOC,or perhaps particular parts like wings, etc. In nearly 40 years of crop dusting/spraying worldwide I don't recall hearing of more than a couple spray planes ever being stolen. Helicopters are a different story.... Ol Shy & Bashful |
Len wrote: Not trying to be alarmist, just thinking that all of us GA folks can keep an eye out for something odd- http://www.eaa.org/communications/eaanews/advisory.pdf The aircraft in the picture doesn't quite look like a Pawnee to me. Is the picture flattened out a bit perhaps or is it really some other model ? CV |
| Thread Tools | |
| Display Modes | |
| Presidewnt reagan's Missing Man Formation | tony | Piloting | 45 | June 16th 04 12:00 PM |
| missing man formation for Reagan | Paul Hirose | Military Aviation | 1 | June 14th 04 01:50 AM |
| Is it time to arm crop duster pilots as well as airline pilots? | Larry Dighera | Piloting | 12 | April 6th 04 09:47 PM |
| Search for missing plane | C J Campbell | Piloting | 2 | March 4th 04 02:42 AM |
| Ellery Queen and the Case of the Missing Magneto Gear Teeth | MikeremlaP | Owning | 3 | July 26th 03 04:01 AM |
