Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
Aviation Consumer and Collision Avoidance
Old March 21st 04, 08:59 AM
Thomas Borchert
BHelman,
Yes, as I have posted here many times, we do sell the Monroy.
My experience with both companies differs from yours considerably, too.
Thomas Borchert (EDDH)
Old March 21st 04, 09:43 AM
Thomas Borchert
BHelman,
people should really read for themselves. Here are some quotes I saw:
You said "inconsistent explanations coming from Surecheck with
regard to the issue."
from AvCon:
"As noted, this allows the SureCheck to make relative altitude determinations
when the host aircraft Mode-C isn’t available, which appears to be the case
about 20 percent of the time for reasons that aren’t clear. "
and
" For some reason, this doesn’t seem to be a problem with the signal
received from other aircraft."
The only edge they even mention for the Monroy is price and display,
but not functionality. Performance wise they clearly state the Monroy
did not perform as well, but is cheaper too.
Well, this quote at the end clearly says the opposite:
"We give a razor-thin edge to the Monroy ATD-300. It’s $400 cheaper than the
SureCheck, has a lower profile on the panel and a simpler, easier-to-read
display. Our impression is that the ATD-300 more often saw traffic that
the SureCheck missed but, to be fair, the performance of both units is
strongly influenced by antenna position."
Only then does it go on to say what you quoted:
Their LAST and ENDING consclusion states clearly. And, yes this is
word for word.
"If that capability is important to
you or you can't run on ship's
power alone,
Old March 21st 04, 09:55 PM
BHelman
Regarding a collision avoidance unit, it obviously makes sense to have
a more capable device like the Trafficscope, vs. a cheaper, less
capable like the monroy. Of course it is smaller, since it doesn't
have anywhere near the capabilities that the Trafficscope has,
including the most important, the on board altimeter. They do mention
that 20% of the time you can probably expect problems with the Monroy
altitude, and that is confirmed by postings from pilots who have used
it all accross the web. With all these considered I can see their
"view" obviously by their own final words of..
power alone, the SureCheck
TrafficScope is the better choice, in
our view."
I don't think this statement from Aviation Consumer could be any more
obvious or self explanatory.
By the way, the new software upgrade I got for my Trafficscope also
includes now an altitude alert program, intruder altitude trend
(climbing / descending) and will display the 3 closest threats with
altitude, not just one. These are more features the Monroy obviously
can't perform or handle with that type of a display.
As for the altitude issues, I think SureCheck did a nice job of
showing what these problems are, and how the Trafficscope solves the
problem. http://www.surecheck.net/avionics/altimeter.html
Yes I agree, people should read the article entirely, then compare the
two product websites.
Thomas Borchert wrote in message ...
BHelman,
from AvCon:
when the host aircraft Mode-C isn?t available, which appears to be the case
about 20 percent of the time for reasons that aren?t clear. "
and
" For some reason, this doesn?t seem to be a problem with the signal
"We give a razor-thin edge to the Monroy ATD-300. It?s $400 cheaper than the
word for word.
power alone,
Old March 22nd 04, 12:00 PM
Thomas Borchert
BHelman,
To you. Not to Aviation Consumer. In fact, they ask if all those
"capabilities" are really useful in practice.
Old March 22nd 04, 02:37 PM
James M. Knox
I realize you are both talking about the newest generation of these
devices. But I just had a really interesting thing happen with the
Monroy ATD-200 yesterday.
I've gotten used to it giving false alarms. With practice, I can
sometimes tell in advance if they are false. And I pretty much know a
lot of the places around my part of Texas that will ALWAYS cause a false
alarm. But yesterday was "new."
I was flying along and one bar (range light) came on, then another. No
visible traffic. I'm at 3000 AGL, however, and that's a typical
altitude for "local" traffic in that area. Another light comes on, and
I look some more. This does not "look" like the typical false alarm
pattern. As an added test, I turn my transponder to STBY. [Every now
and then, not often, it will start seeing my own xpndr if I am in an
area of poor radar coverage.]
The XPNDR light on the ATD keeps blinking, just exactly like it is
seeing local replies!!! Now remember, I still only have three lights
on the ATD, so it's not like another aircraft is resting its landing
gear on my wings. G] It finally faded out, without any aircraft
getting within visible range of mine, and probably none within 15 miles.
Phantom aircraft on the ATD is something I am used to. Phantom
transponders on my own aircraft... that's a new one.
James M. Knox
TriSoft ph 512-385-0316
1109-A Shady Lane fax 512-366-4331
Austin, Tx 78721
Old March 22nd 04, 05:06 PM
Thomas Borchert
James,
Was your DME on? It will make the light go off, too.
Old March 22nd 04, 05:43 PM
BHelman
No, in Aviation consumer's own words.
They clearly indicate that the main capability of having an on board
altimeter is a major step above the monroy. Which I agree with
completely after having flown with both the Monroy and the
Trafficscope. The monroy had many instances where it either did not
get the correct altitude, or didn't know what altitude to use if any.
Having someone hit IDENT in a busy ATC enviorment is absolutely nuts,
as Aviation Consumer points out as well.
The answer to the altitude issues with the monroy unit is; watch for
the display, mess with the transponder, pester ATC with a spurious
IDENT, and hope it fixes the problem (which it didn't for Aviation
Consumer)
The Trafficscope solution to this problem is; Don't worry about it,
the on board altimeter solves it for you.
But I understand your myopia in your desire to market the monroy. But
what you are trying to portray is that a Cessna 150 is a better
aircraft because it is smaller, and cheaper than a C-421.
"If that capability is important to you......."
A C-150 costs less because it doesn't have the "capabilities" that a
Twin Cessna 421 has.
BHelman,
Old March 23rd 04, 11:26 AM
Thomas Borchert
BHelman,
You don't seem to understand at all. All I'm trying to aim for here is
a fair representation of the AvCon article. That, in my humble opinion,
was not given by your original post. In fact, the post directly
contradicted the "Monroy has the egde" summary that AvCon gives both in
the article and the lead-in.
Note that I have nowhere in my postings said that I think the Monroy is
better or anything like it. This is solely about the Avcon article.
Let's agree to disagree...
Old March 23rd 04, 02:25 PM
BHelman
I do not agree that is for sure. The headlines to these articles are
not even written by the examining editor. Did you know that? The
issue editor skims through it and randomly picks something to add to a
title.
A final conclusion which rest their pick on a product being capable
seems to me to be their last conclusion. The only thing they gave
credit to the monroy for was it being cheap and the display, not
because it performed better. (Which was backwards in the article. In
direct sunlight you can't see the monroy display whatsoever, but the
Trafficscope is the most readable in direct sunlight. I think they
meant dim light.)
Clearly they state that the Trafficscope is a better choice for being
capable of detecting traffic range / altitude more accurately.
I think you should try flying with both. You'll see why the
Trafficscope is better in performance, just as Aviation Consumer did.
BHelman,
Old March 23rd 04, 02:49 PM
James M. Knox
Pulled the DME out of the plane years ago. Shouldn't have been any
intentional radiators in the plane (at least, not on). Now was there any
known high-power ground radiators in the area (nothing more than the
occasional phone tower). This is pretty much just open farmland. And it
doesn't normally happen here. [As opposed to plenty of other areas around
central Texas where the ATD will always get a false alarm.]
James M. Knox
Austin, Tx 78721
