Cambridge 302 - switch from Netto in cruise to TE in climb?
Old November 30th 14, 08:57 AM posted to rec.aviation.soaring
Bernie[_4_]
Default Cambridge 302 - switch from Netto in cruise to TE in climb?
I have a CAI 302 vario and currently run it in Super Netto mode. However I would like to have it run as a Netto vario in cruise, and a normal TE vario in climb.
The manual says that a cruise/climb switch may be connected between Pin 9 and Pin 10 however I don't know if that will switch to TE in climb, or stay as Netto? Obviously I need to use the CAI utility to set the vario to Netto as a first step.
Old November 30th 14, 12:46 PM posted to rec.aviation.soaring
Muttley
you can also configure the 302 that it will switch from climb to cruise at a certain speed. No external switch required in this case.
Old November 30th 14, 03:11 PM posted to rec.aviation.soaring
Tim Taylor
The 302 will always be in TE for climb, the cruise mode is what you can configure. You can use a switch to manually (or flaps) go between modes or set a speed values for it to automatically change.
Old November 30th 14, 08:27 PM posted to rec.aviation.soaring
Bernie[_4_]
Thanks guys. The manual says the 302 switches from cruise mode to climb mode 7 seconds after a turn is initiated based on GPS track rather than airspeed . However as long as it is always a TE vario when in climb mode that should work fine for me. I will set it to Netto for cruise and try it.
Netto bis bish Soaring 4 August 14th 11 06:56 AM
Netto bish Soaring 12 August 4th 11 04:09 AM
cruise vs. climb article location SAM AND LEIGH ZIMMERMAN Soaring 5 March 19th 07 04:15 PM
Flap handle activated Climb/Cruise switching Andy Smielkiewicz Soaring 5 March 14th 05 04:54 AM
Cambridge 302 and Super netto Ross Biggar Soaring 13 September 13th 03 08:57 PM
