Too much fun.. almost..
Old October 27th 04, 08:18 AM
Steve R.
Default Too much fun.. almost..
Wow, sounds like such a great day! Congrats Kevin! :-)
Isn't it wonderful when everything comes together? Ok, so you had a sloppy
one. The important part is that you reacted properly and didn't bend the
bird. It's all part of the learning experience.
Question: Maybe I'm reading you too literally but, are you going to have to
get through your 10 hrs of solo time "before" you start the x-country time?
I would think that you could do a lot of that concurrently.
Take care & Fly Safe,
Steve R.
"The OTHER Kevin in San Diego" skiddz *AT* adelphia *DOT* net wrote in
message ...
Got in another hop today, with some solo time tossed in for good
measure.. Was supposed to fly yesterday, but the aux fuel gauge went
batty on the flight before mine. It was nice to get a call from the
school letting me know before I took the drive down. Unfortunately, I
was informed this morning the ship was ready to go by the time I was
supposed to fly. Minor procedural goof with the school. No big deal
as far as I'm concerned - I got some things done around the house and
actually got some work done.
Weather here in the Golden State has been crappy of late and I woke up
to a bit of rain. I wasn't too concerned because the outlook showed
it would be cool and cloudy today, with rain beginning tonight.
Looking outside right now you wouldn't expect rain but I digress..
Got to the field and worked out my W&B for both dual and solo flight.
I wasn't aware I'd be going solo today, but I knew that paperwork
would be required if I did. I knew the CG would be different without
150lbs of human next to me, but wow! What a difference both laterally
and longitudinally..
Preflight went ok, but I thought the lower swashplate was a bit
"jiggly". I hadn't flown this particular ship in about a month so had
Q check it out before we launched. He said it was ok so I strapped in
and got it started up. Slight issue with the left mag check - the
right mag showed the expected drop but when I went to both and then
back to left, the RPM took a good 10 seconds to drop and then it
didn't drop half what I was expecting. Back to both and back to left
and it did what it was supposed to. Guess I didn't get it "in the
groove" the 1st time. I got an 'attaboy" from the left seat for
catching that one.
Everything was in the green so I picked us up (I'm getting pretty good
at those with two of in the ship) and headed for the taxiway as I made
my initial call. We were cleared for takeoff so I taxied to the
runway centerline, made a right pedal turn, checked the gauges and we
were off. Nice cool day with DA about 150' below actual field
elevation so there was power a plenty and it didn't take but 21inches
to get us outta there..
1st approach was a little ugly, but I hadn't flown this particular
pattern more than once or twice before so didn't know how I had to be
set up for each leg. 2nd time around was pretty good and didn't
require much fiddling on final. Q asked me to set down and pick up a
couple times then asked the tower to head back to the parking area. I
wasn't sure if I'd done something wrong or if Q had noticed anything
with the helo..
We got back to the ramp and he set the ship down and asked "You want
both doors or just the left one?" I opted for the left one only and
he trotted to the hangar to pick up my logbook and the door. I sat
there on the ramp, throttle at idle and watched one of the new
students going over a preflight with an instructor. I couldn't help
but puff out my chest a bit whenever he'd glance over at me. Pilots
ego already? At 24 hours?? What a dork I am.. Good thing there was
a helicopter to deflate my head a bit...
Q got back with the door and my log book and in a couple minutes he
was leaning in the helo and telling me what I could and could not do.
Basically, I couldn't do jack. What I could do was hover, fly
patterns and approaches and have fun. Ok, not much leeway but what
the hell? I get to fly a helicopter all by myself again.
Remember the pilot ego? Detonated like a nuclear bomb on the 1st
pickup. I was all over the place for a few seconds until I figured
out the balance point. Perfect situation for one of those "wanna get
away" Southwest Airlines commercials.. heheh
Once I was settled down, I pointed the nose towards the runway and
called the tower for clearance. I had to hover at the hold short line
for a min or so and then was cleared to take off so I taxied out,
pointed the nose down the long direction of the runway, made my checks
and I was off. Before I knew it, I was climbing out at 1000 FPM and
doing 65 knots.. Before I'd even made my crosswind turning point, I
had to decrease the power about 4" and add some forward cyclic to
stick the altitude at 800'.
Turned downwind and made my downwind checks.. Abeam my landing spot I
set up my descent and got slowed down before turning base. Slowed
down a bit more and was at about 45 kts and 300' AGL as I turned
final. Got the angle set up and was bit high so I lowered the
collective a bit more and stole a glance at the panel. Wow.. 10
whopping inches of MAP and I'm comin' downhill at a steady 300fpm.
The ship started to rumble a bit about halfway down so I started
adding power slowly and adding a smidge of forward cyclic.. I came up
a bit short, but otherwise I felt the approach was a good one. Very
little to do on the way down but ride it down. Just have to adjust my
final turn numbers a bit.
Went around again and this time it was much better. I turned final a
little higher and faster and once I'd got the pitch angle established,
it was a matter of collective and pedal until about 50' when I had to
start adding forward cyclic as power was pulled.. About 10' the nose
suddenly swung to the right and it took a healthy measure of left
pedal to get it squared away. I thought I was just late adding left
pedal as I pulled power, but found out on the next approach it was
actually the wind coming from between two hangars.
The third one was pretty. I hit my numbers all the way around the
pattern and don't think I made a single adjustment to the cyclic on
final. I ended up in a 3' hover right over the spot I was aiming for
and went ahead and set it down. I called the tower and told 'em I
wanted to hang out at the numbers and do some hover work. I was
cleared and proceeded to work on pickups and set downs. I'm still not
used to the tail down attitude these little dragonflies get when
flying solo so the first few pickups were ugly to say the least.
Set downs, on the other hand, are pretty much cake and I started
making up games for myself to test my hovering skills. I'd hover taxi
away from the numbers, turn around and pick one small spot to set down
on and see how accurate I could be. Even in that last foot or so
where I'd had so much trouble in the past was smooth. It got to the
point where I was putting the wheel attachment point within just a few
inches of where I wanted it and I was able to put the tip of the right
skid right on the tip of the arrows leading to the displaced threshold
several times.
I tried some sideways hovering and managed to get it moving left
pretty good, but right was a little erratic.. I had a hard time
keeping the centerline right under my butt going that way.. Still, it
was good practice.
I noticed the CHT creeping up a bit so called the tower and asked to
enter the pattern again. I was cleared after a few moments and off I
went. Damn near busted the 800' pattern altitude 'cuz I was a bit
slow in reducing power and got to my downwind checks. Everything was
cool so I checked the clock to see how I was doing on time. 20
minutes before I had to head back to the ramp. I thought I'd get
about 3 more patterns in after this one so got set up to make my base
turn and flew a pretty good steep approach. Got a little too shallow
right at the end, but that was fixed with a touch more collective..
Went around again and again, made a decent approach - not great, but
not too bad.. The wind that caught me by surprise at 10' was still
there, but I anticipated it and as soon as I felt the nose start to
move, that left pedal got jammed in and the nose hardly budged.. Once
into the hover I set it down and did some quick mental calcs. Ok,
about 4 minutes per circuit, I've got a little over 10 minutes before
I need to head back and it look like I've got about 7 or 8 gallons of
fuel left in the main and a couple gallons in the aux. I'll do one
more then call it a day.
I call the tower to get cleared and I'm off again.. Crosswind and
downwind legs are good, but I'm a bit too fast as I turn base and too
high as I turn final. I get my angle set up good and have to lower
the collective a bit more to get my descent rate up as I'm too high..
As I get it back on track, the rumble starts and I decide I'm going to
make it a steep approach. I start to pull power and take a peek at
the VSI.. Yikes.. 400fpm and I'm getting a bit slow. I figure I'm
going to have to overshoot my spot even if I add power at this point
I add some power and forward cyclic.. The rate of descent doesn't
seem to be slowing and I really looks like I'm dropping rapidly and
the airspeed is slowly creeping up.. At about 20' up the "oh ****s!"
start and the ground is coming up pretty damned fast..
I add a handful of forward cyclic and drop the collective ever so
slightly and as soon as the ship stops vibrating, I pull power and
just get it stopped about 2' off the ground. I set down, collect my
thoughts and pick it up. At least I've figured out how to pick up the
ship solo without it wandering all over the place. I'm still
uncomfortable with the "wheelie" liftoff.. I'd kinda like someone to
take a video of me picking up solo so I can see how close to the
ground the tail rotor is actually coming.
I call tower and request a taxi back to the ramp and just as I turn
around, I see Q standing near the fuel shack. Not sure if he'd just
visited the soda machine or he was coming to see where I was. I was
hoping he hadn't seen that last approach. If he did, there was no
indication of it because as soon as I started down the runway towards
the ramp, he turned and walked to the hangar.
I taxied back and made a nice set down right in the center of the pad.
throttled down, flicked the governor off and set the cool down timer
and thought about that last few seconds of the last approach.. I'm
not sure I actually got into settling with power and am thinking that
I probably was just too slow adding power on final as the 1st part
looked and felt pretty good.
Either way, it was a really crappy way to get a helicopter back to
Mother Earth and it definitely got my attention in a big way. Other
than that approach, I thought I flew pretty good and looking back, I'm
pleased I was able to execute a recovery for whatever the hell it was
I'd got myself in to and not bend up a helicopter. Can't say the same
for my ego though. Probably a damned good lesson in any case.
Got the ship shut down and secured and can't help giving the ship a
pat on the canopy and uttering "good girl". As I round the nose and
start my walk back to the hangar, I see Q walking out towards me and I
meet him halfway.
"How'd it go?"
"Did you see that last approach?"
"I wasn't watching you.."
"Good. I scared the crap out of myself."
I went on to explain what happened and he kinda grinned and asked "Got
into a little settling with power didja?"
I had to admit that I probably had and told him what I'd done to get
out of it. Q just smiled and walked away. Ok, I guess I did the
right thing. I hit the "pilots lounge" and made two entries in my log
book. 0.3 dual and 0.9 solo.. Q came up and asked how much time I
logged and then told me he wanted be to blow through my next ten hours
of solo so we could work on cross countries and asked me where I
wanted to go. What a baited question.. I'd really like to fly over
my mom's house and drop water balloons but I don't think the FAA would
like that too much.
I told Q I'd like to fly out over the desert and buzz the lizards and
he said "Yeah, I'd like to do that too. Plan it out.." Cool. I'll
give you one guess what I'm going to be doing later tonight.. Not
sure we'll go any time soon with another storm coming through, but
even if I end up flying dual in the pattern tomorrow, it'll be cool.
Anytime I can get in the helicopter is great. I love this stuff!
Old October 27th 04, 06:22 PM
Steve R.
message ...
to
time?
I don't think so. It'd take me a couple weeks to knock out those 10
solo hours. Since I was tasked to create a flight plan to head to the
desert, I'd imagine we're actually going to make that flight in the
near future. Looking at the schedule for this morning, I see I'm
scheduled for dual today. Not sure if it's going ot happen as we got
some Noah's Ark style rain at 3 this morning and it's still coming
down steady.. Not sure what visibility is going to be at the field,
but at the least, I can hit the cafe and get some breakfast and get
some informal one on one ground..
That sounds about right to me too. What I remember from my fixed wing
training is that we did a duel x-country first. I'd imagine that's what
your flight plan assignment is about. I was then signed off for 2 or 3
short solo x-countries with remedial training in between. I then did my
long x-country. Back then, that one had to be 3 legs, each at least 100
nm's long. The regs have changed since then, from what I understand so it's
a little different these days for the student plank fliers. I'm not up on
what the regs require of rotorcraft students. The end result was that I
finished my required x-country time with only an hour or so of solo time to
wrap up and it all came together very close to the 40 hour minimum for a
private pilot ticket. I hope the timing in your training works out as well!
Looking forward to reading about your first x-country adventure. How do you
fly a helicopter and manipulate a sectional at the same time anyway? ;-)
Fly Safe,
Steve R.
Old October 28th 04, 06:37 AM
el gran cantinflas
A great work of story telling there, Kevin. I really enjoy reading
these. Maybe that could be your second hobby/love(?)
You must have one great memory for detail. I couldn't describe the
happenings of the Gravitron at the state fair with the detail you show
in these posts.
Keep up the good work!
ref
catching that one.
with the helo..
several times.
was good practice.
meet him halfway.
"How'd it go?"
like that too much.
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 100,000 Newsgroups
---= East/West-Coast Server Farms - Total Privacy via Encryption =---
Old October 28th 04, 02:08 PM
B4RT
message We did some pilotage today and I can tell you this; it's a bitch
to
fly and mess with a sectional at the same time.
I do a lot of 1000nm + cross countries in a chopper, and what I've found
most useful is to prefold the sectionals in such a way that the route is
readily unfolded. I used to even buy two copies of them so that wouldn't
have to play the flip and refold game when I crossed the north-south
boundary. I don't do that anymore because it gets expensive, but it was
useful on my first few trips.
IMO water features and railroad tracks are the most trustworthy things to
use as reference points. Flying at a higher than normal altitude will help a
lot to show you where you are on the sectional. I usually use about 2000 agl
for medium cross-countries and 45-55 hundred for long ones. (My turbine
works really good here + I get a free TAS increase from the altitude) The
other reason to fly higher on cross countries is that you'll have less worry
about towers & wires.
Wires & towers are the biggest enemy of a helicopter pilot, especially when
you're in unfamiliar territory. Your workload will be much lower if youre
flying higher than anywhere a wire could be. BTW: In hilly terrain never fly
lower than than the tops of the hills on each side, you'd be amazed how many
wires there are acoss two mile wide valleys. You cant see the wires, so
always look for structures and assume that theres a wire between them.
Bart
Old October 29th 04, 03:56 PM
Steve R.
"B4RT" wrote in message
I usually use about 2000 agl for medium cross-countries and 45-55 hundred
for long ones. (My turbine works really good here + I get a free TAS
increase from the altitude) The other reason to fly higher on cross
countries is that you'll have less worry about towers & wires.
Bart
Ok, I'm a bit confused here. So Bart, or Kevin, or anyone who cares to put
in their 2 cents worth, have at it. :-)
My issue is with Bart's statement that there's a free TAS increase in his
helicopter with altitude. I'm sitting here, thinking about how I want to
word all of this and I'm starting to think that I'm about to answer my own
question so I'll put it to you kind folks and see what comes back!
I understand that fixed wing aircraft gain efficiency with altitude. The
simplified explanation is that as the aircraft climbs to greater altitudes
(ie: thinner air), there's less frictional drag on the airframe and the
aircraft achieves a higher TAS (true airspeed for those who may not know) as
long as you're not flying so high that you're no longer able to pull
standard cruise power from the engine. Assuming the same power settings
from the engine/engines, you'll achieve a higher cruising airspeed (TAS) at
altitude than you will at sea level. All of this happens automatically.
As for helicopters (any rotorcraft), the airspeed of the "wings" (ie: the
rotor blades) is limited to the maximum rpm that the rotor system can
sustain. Because of this, as the helicopter climbs to altitude, the rotor
blades can't see the kind of TAS increase that a fixed wing aircraft enjoys
because the speed of the rotor blades is tied to the max rpm of the rotor
system. Consequently, as the air thins with increased altitude, the
helicopter has to fly with ever increasing collective settings to maintain
the same lift/thrust levels. When you can't increase airspeed (rotor rpm),
you have to increase AOA (collective) to maintain a given lift/thrust
level!? One negative side effect of this is that the helicopters Vne speeds
lower as the altitude rises. What I've always been told is that because of
this, it doesn't generally pay for a helicopter to go to altitude on a
x-country flights unless there are sufficient favorable winds (ie: tail
winds!) to make up the difference. (?)
Now to the part where I might be answering my own question. Just as the
fixed wing aircraft sees in increase in TAS at altitude as long as it can
still maintain cruise power (generally 65 to 75% power), I'm starting to
think (I hadn't really considered it this way before!) that as long as the
helicopter isn't pushing it's Vne limits at altitude (due to higher
collective settings), the fuselage will see an increase in TAS also, even if
the rotor blades themselves are not, because of rpm limitations on the main
rotor system. Of course, if the fuse is seeing a higher TAS, then the rotor
blades will also see in increase, at least on the advancing
side..........but I don't think I want to get into that too deeply! ;-)
Am I getting this anywhere near right? I hope this makes sense. Thanks for
any replies! :-)
Fly Safe,
Steve R.
Old October 29th 04, 09:32 PM
hellothere.adelphia.net
Remember, TAS is your airspeed (ignoring the winds) in relation to the
ground. IAS is to the air around you. The higher you go, the less drag
on the fuselage and same as a fixed wing, less drag on lift prducing
surfaces mean more efficiency, which means a little better airspeed.
That IAS maybe lower due to less power, but for that amount of power
you are more efficient. That all adds up to higher TAS and lower fuel
burns. In the turbine I fly, I see up to a 5-6 gallon an hour less
burn at 5,000'.
On Fri, 29 Oct 2004 13:56:01 GMT, "Steve R."
Bart
any replies! :-)
Fly Safe,
Steve R.
Old October 30th 04, 12:10 AM
Steve R.
Hi!
I had a long drawn out reply to your first sentence (about TAS, CAS, and
IAS) until I re-read it and paid more attention to the "ignoring the winds"
part! ;-) I agree, assuming absolutely NO wind, TAS should equal ground
speed if we're doing the calculations correctly. Since that's never the
case (the part about absolutely NO wind that is), for all intents and
purposes, I try to never equate airspeed and ground speed as the same thing
although the first will obviously have an impact on the second.
The only reason I mentioned tail winds in my original question was to
clarify that if you've got a good enough tail wind, your ground speed will
be up enough to compensate for any airspeed losses that occur due to the
increased altitude.
I hear what you're saying about less drag on the lift producing surfaces
(wings!) but aren't you also having to fly at greater collective settings in
the "relatively" thin air? From what I think I'm getting out of all this,
that minor change isn't hurting you enough to offset the gains of climbing
up to 5000 feet and the improved fuel burn (5-6 gallons/hr isn't chump
change these days!) doesn't hurt a bit either. In the turbine helicopter
you fly, where is the point of diminishing returns? In other words, how
high can you go before any improvement in TAS or fuel consumption quits
netting you any gain?
Thanks for the reply.
Fly Safe,
Steve R.
hellothere.adelphia.net wrote in message
burn at 5,000'.
hundred
Bart
put
as
at
enjoys
rpm),
speeds
of
if
main
rotor
for
any replies! :-)
Fly Safe,
Steve R.
Old October 30th 04, 01:30 AM
Toad-Man
"Steve R." wrote in
Hi!
Thanks for
any replies! :-)
Fly Safe,
Steve R.
Sorry to wade into this discussion without a bit more prep but having read
your reply to the post something occurred to me that might help.
The way turbine engines work mean that as the air gets colder (perhaps due
to low surface temp or climbing to higher alt for example) they become more
efficient and generate more power for a given power setting. The 'laymans'
(i.e. my!) logic for this is that since turbines work by heating air, the
cooler the air at the intake, the more the air can be heated by the engine
thus producing greater thrust.
I suspect that the reason for the lower fuel burn is due to this effect,
rather than the lower drag.
toad.
Old October 30th 04, 04:38 AM
Jim Carriere
This is part of it, the other part is the flame temperature in the
engine is much hotter, because the air is less dense while you use
approximately the same amount of fuel to generate as much power (or
thrust in a jet engine). So you not only have cooler intake air, you
also have much hotter turbine inlet air.
Old October 30th 04, 05:14 PM
B4RT
Steve,
Indicated airspeed is just a measure of how many little molecules are
banging against the
pressure transducer. The higher you go, the fewer of these little guys there
are per unit
volume of air. Since the chopper has to bang the same number of molecules
to produce
lift and thrust up high as it does down low, the only thing that really
changes is volume
of air that is being traversed (read TAS increase). If you think about it,
you'll find that
most of the things that hold true in airplanes also hold true in helicopters
with regard to the
lift and thrust vector math that go into the TAS.
Even if I didnt know the junk that went into this, I can see the effect
directly by watching
my GS increase on my EFIS/GPS. The chopper maintains about 110kts indicated,
but the TAS
is around 120. Meanwhile my burn goes from about 26.5GPH down to about 24.5.
Of course the increased winds aloft can kick the snot out of this benefit if
theyre not beneficial.
But one day I got the biggest kick out of doing 165-170 knots on my way down
florida keys. Approach actually called me and asked what kind of helicopter
I was in.
Bart
"Steve R." wrote in message
put in their 2 cents worth, have at it. :-)
