Hi folks, I'm in the process of installing new connecting rods in my Ventus B would like to know what everyone is using if any for the slide lube where those connecting rods like to ride. The material that the slide is made out of seems to be impervious to wear so that's good but the rods are wearing is there any thing you have found that will not collect dust and still give good wear resistance?
CH |
Believe those push-rod guides should be kept completely dry. I have seen ware at the guides caused by the push-rod banging around in the trailer. I know the LS-3a has this problem and it is best to tape the push-rod to the aft lift fitting before trailering (use the wing tape you just pulled off). Don't believe this applies to automatic control hook ups, unless you have an A model which have manual hook-ups on the ailerons.
Go Patriots!!!! JJ |
Search "ventus aileron stiff" and find Dick Jonson's thoughts on the subject, he used 2 drops of WD-40 yearly in a hole he drilled to access the problem area. He also talked about sanding the aileron gap between wing skin and aileron...............all good stuff!
RIP Dick, JJ |
At 23:52 02 February 2015, HGXC wrote:
On Monday, February 2, 2015 at 3:00:05 PM UTC-5, Don Johnstone wrote: At 15:26 01 February 2015, wrote: Hi folks, I'm in the process of installing new connecting rods in my Ventus=3D B would like to know what everyone is using if any for the slide lube wher=3D e those connecting rods like to ride. The material that the slide is mad= e o=3D ut of seems to be impervious to wear so that's good but the rods are wearin=3D g is there any thing you have found that will not collect dust and still gi=3D ve good wear resistance? CH =20 If Schempp Hirth thought that the rods needed a lubricate I am sure they would have mentioned it in the service manual or instructions for replaci= ng the rods. I do not believe that they forgot and it is perfectly clear tha= t they intended that the rods should be as they originally assembled them, lubricant free. Does that give you a clue at all on what should be used? I own a Ventus and I have mine lubed at the annual, I have the openings in = the wing like Dick Johnson suggested. If Schempp Hirth didn't want this to = be lubed then they would have used a different bushing when they made the g= lider. All gliders have short comings. The glider has been flown over 30 ye= ars and like all popular gliders over time, pilots find ways of addressing = imperfections and every glider has some. Dennis Why is it that some glider pilots feel they know better that the qualified engineers and designers who design and build the machines they fly. Maybe using an unapproved lubricant on material that you do not know the composition of, which might be damaged is unwise but drilling a hole in the structure to do it, that is stupidity of the highest order, such is life I suppose. I doubt that the "opening" made was properly sealed to unsure that moisture could not damage the GRP structure which is hygroscopic, my advice. Do NOT purchase a glider owned by these people. It is true pilots have a long history of finding incorrect ways of addressing imperfections, proves the old maxim I suppose, if flying was difficult engineers would do it. |
At 12:31 03 February 2015, Don Johnstone wrote:
At 23:52 02 February 2015, HGXC wrote: On Monday, February 2, 2015 at 3:00:05 PM UTC-5, Don Johnstone wrote: At 15:26 01 February 2015, wrote: Hi folks, I'm in the process of installing new connecting rods in my Ventus=3D B would like to know what everyone is using if any for the slide lube wher=3D e those connecting rods like to ride. The material that the slide is mad= e o=3D ut of seems to be impervious to wear so that's good but the rods are wearin=3D g is there any thing you have found that will not collect dust an still gi=3D ve good wear resistance? CH =20 If Schempp Hirth thought that the rods needed a lubricate I am sur they would have mentioned it in the service manual or instructions for replaci= ng the rods. I do not believe that they forgot and it is perfectly clear tha= t they intended that the rods should be as they originally assemble them, lubricant free. Does that give you a clue at all on what should b used? I own a Ventus and I have mine lubed at the annual, I have the opening in = the wing like Dick Johnson suggested. If Schempp Hirth didn't want thi to = be lubed then they would have used a different bushing when they made the g= lider. All gliders have short comings. The glider has been flown over 30 ye= ars and like all popular gliders over time, pilots find ways o addressing = imperfections and every glider has some. Dennis Why is it that some glider pilots feel they know better that the qualifie engineers and designers who design and build the machines they fly. Mayb using an unapproved lubricant on material that you do not know th composition of, which might be damaged is unwise but drilling a hole in th structure to do it, that is stupidity of the highest order, such is life suppose. I doubt that the "opening" made was properly sealed to unsure tha moisture could not damage the GRP structure which is hygroscopic, m advice. Do NOT purchase a glider owned by these people. It is true pilots have a long history of finding incorrect ways o addressing imperfections, proves the old maxim I suppose, if flying wa difficult engineers would do it. I recall corresponding with a pilot who wanted to move forward the C of G of his GRP glider and found that there was some lead attached to the leading edge of the rudder. He didn't know why it was there so he removed it. Next he planned to cut holes in the rudder and cover them with fabric. I told him that it was the mass balance and warned him about flutter but he replied that it was OK as the glider was "Experimental". John Galloway |
On 2/3/2015 5:31 AM, Don Johnstone wrote:
At 23:52 02 February 2015, HGXC wrote: On Monday, February 2, 2015 at 3:00:05 PM UTC-5, Don Johnstone wrote: At 15:26 01 February 2015, wrote: Some judicious snippage... I own a Ventus and I have mine lubed at the annual, I have the openings in = the wing like Dick Johnson suggested. If Schempp Hirth didn't want this to = be lubed then they would have used a different bushing when they made the g= lider. All gliders have short comings. The glider has been flown over 30 ye= ars and like all popular gliders over time, pilots find ways of addressing = imperfections and every glider has some. Dennis Why is it that some glider pilots feel they know better that the qualified engineers and designers who design and build the machines they fly. Maybe using an unapproved lubricant on material that you do not know the composition of, which might be damaged is unwise but drilling a hole in the structure to do it, that is stupidity of the highest order, such is life I suppose. I doubt that the "opening" made was properly sealed to unsure that moisture could not damage the GRP structure which is hygroscopic, my advice. Do NOT purchase a glider owned by these people. It is true pilots have a long history of finding incorrect ways of addressing imperfections, proves the old maxim I suppose, if flying was difficult engineers would do it. Evidently, the original question touched upon "a topic of religion." One church believes that gliders as-received from manufacturers cannot possibly be improved by mere humanity unassociated with the original design process (and to attempt improvement places one in the category of the devil's spawn). The other church believes that use-/age-related issues will inevitably appear, and might (if not should) be reasonably addressed by subsequent owners. True - at least in the U.S. - for sailplanes licensed with (see below) an Approved Type Certificate or licensed Experimentally. In my view, there's sound reasons for both views, and in an ideal world, both can peacefully co-exist. Full disclosu I'm a(n aerospace) degreed (U.S.-based) engineer, but one who's convinced original designers were NOT (all apply): all-knowing; incompetent. In other words, designers and the design team are humans like the rest of us, though with (perhaps) some specialized training, and (definitely) some specialized interests...again normal human conditions. The U.S. is fortunate to have a healthy, vibrant, amateur-built aircraft licensing category, from which - perhaps - some cogent conclusions about this particular religious topic may be drawn. As I type, approximately 20% of the U.S. power, single-engine, 4-or-less seats general aviation fleet is licensed "Experimental Amateur Built" (a presently increasing proportion), the rest having Approved Type Certificates. Taken as a whole, the EAB category accident frequency is (statistically and) significantly higher than the ATC category as measured against fleet/licensing numbers. Unsurprisingly (in my view) the percentages have a significant first-/early-flight bias (for engine/fuel and loss of control reasons, mostly); thoughtful readers can probably make accurate guesses why (an exercise and validation beyond the point I'm trying to make with this post). Once beyond that bubble, EAB and ATC accident rates are (arguably) identical. I expect (but am not certain) accident *causes* are similar as well (when comparing similar classes of pilots/flight, e.g. Visual Flight Rules piloting). My conclusions: 1) "Sound airplane design practices" are not limited solely to factories and their design teams. 2) The weakest link is generally the nut at the top of the stick. Stated another way, pretty much every form of human design screwup/oversight possible in general aviation flying machines (e.g. sailplanes) has been made long, long ago, and "best practices" are pretty much available (and arguably well known) to anyone inclined to learn from others' experiences. We're well beyond the "secret guild stage" of aircraft structural design knowledge, and the "smoke and mirrors" of ignorance-based myths. That knowledge availability, along with the tendency of those geekily inclined (most engineers, and many non-degreed people as well) is why I'm OK with belonging to the Church of Future Improvement is Possible. On the other hand, the World Wide Web has made it easier for everyone (e.g. via YouTube) to easily see that Darwinism remains a potent human genealogical force. Ignorance is potent, often more quickly than knowledge. Hence I'd never try to convince members of the Church of Don't Mess With Factory Stuff to change their beliefs. Clint Eastwood was right: A man's got to know his limitations. Further, who hasn't heard the truism: All generalizations are false...including this one. In my view, there's at least one truism that is NOT false: Perfection is never an option. True in glider design, too. The trick is to know - or at lest to remain within - one's limitations. YMWV Bob W. P.S. I believe Dick Johnson was a degreed aeronautical engineer. His entire working life was spent in the engineering field, and his extracurricular soaring-and-sailplane-design-and-testing-related body of work was prodigious. He likely passed on from heart failure in his mid-eighties while flying the Ventus he owned for decades - the one in which he drilled lube access holes. Make of all that what works for yourself! |
Imagine: Dick Johnson and "stupid" in the same sentence. That's not
unlike hearing Derek Piggot and "lousy instructor" in the same sentence. Nice post, Bob. Dan On 2/3/2015 7:15 AM, Bob Whelan wrote: On 2/3/2015 5:31 AM, Don Johnstone wrote: At 23:52 02 February 2015, HGXC wrote: On Monday, February 2, 2015 at 3:00:05 PM UTC-5, Don Johnstone wrote: At 15:26 01 February 2015, wrote: Some judicious snippage... I own a Ventus and I have mine lubed at the annual, I have the openings in = the wing like Dick Johnson suggested. If Schempp Hirth didn't want this to = be lubed then they would have used a different bushing when they made the g= lider. All gliders have short comings. The glider has been flown over 30 ye= ars and like all popular gliders over time, pilots find ways of addressing = imperfections and every glider has some. Dennis Why is it that some glider pilots feel they know better that the qualified engineers and designers who design and build the machines they fly. Maybe using an unapproved lubricant on material that you do not know the composition of, which might be damaged is unwise but drilling a hole in the structure to do it, that is stupidity of the highest order, such is life I suppose. I doubt that the "opening" made was properly sealed to unsure that moisture could not damage the GRP structure which is hygroscopic, my advice. Do NOT purchase a glider owned by these people. It is true pilots have a long history of finding incorrect ways of addressing imperfections, proves the old maxim I suppose, if flying was difficult engineers would do it. Evidently, the original question touched upon "a topic of religion." One church believes that gliders as-received from manufacturers cannot possibly be improved by mere humanity unassociated with the original design process (and to attempt improvement places one in the category of the devil's spawn). The other church believes that use-/age-related issues will inevitably appear, and might (if not should) be reasonably addressed by subsequent owners. True - at least in the U.S. - for sailplanes licensed with (see below) an Approved Type Certificate or licensed Experimentally. In my view, there's sound reasons for both views, and in an ideal world, both can peacefully co-exist. Full disclosu I'm a(n aerospace) degreed (U.S.-based) engineer, but one who's convinced original designers were NOT (all apply): all-knowing; incompetent. In other words, designers and the design team are humans like the rest of us, though with (perhaps) some specialized training, and (definitely) some specialized interests...again normal human conditions. The U.S. is fortunate to have a healthy, vibrant, amateur-built aircraft licensing category, from which - perhaps - some cogent conclusions about this particular religious topic may be drawn. As I type, approximately 20% of the U.S. power, single-engine, 4-or-less seats general aviation fleet is licensed "Experimental Amateur Built" (a presently increasing proportion), the rest having Approved Type Certificates. Taken as a whole, the EAB category accident frequency is (statistically and) significantly higher than the ATC category as measured against fleet/licensing numbers. Unsurprisingly (in my view) the percentages have a significant first-/early-flight bias (for engine/fuel and loss of control reasons, mostly); thoughtful readers can probably make accurate guesses why (an exercise and validation beyond the point I'm trying to make with this post). Once beyond that bubble, EAB and ATC accident rates are (arguably) identical. I expect (but am not certain) accident *causes* are similar as well (when comparing similar classes of pilots/flight, e.g. Visual Flight Rules piloting). My conclusions: 1) "Sound airplane design practices" are not limited solely to factories and their design teams. 2) The weakest link is generally the nut at the top of the stick. Stated another way, pretty much every form of human design screwup/oversight possible in general aviation flying machines (e.g. sailplanes) has been made long, long ago, and "best practices" are pretty much available (and arguably well known) to anyone inclined to learn from others' experiences. We're well beyond the "secret guild stage" of aircraft structural design knowledge, and the "smoke and mirrors" of ignorance-based myths. That knowledge availability, along with the tendency of those geekily inclined (most engineers, and many non-degreed people as well) is why I'm OK with belonging to the Church of Future Improvement is Possible. On the other hand, the World Wide Web has made it easier for everyone (e.g. via YouTube) to easily see that Darwinism remains a potent human genealogical force. Ignorance is potent, often more quickly than knowledge. Hence I'd never try to convince members of the Church of Don't Mess With Factory Stuff to change their beliefs. Clint Eastwood was right: A man's got to know his limitations. Further, who hasn't heard the truism: All generalizations are false...including this one. In my view, there's at least one truism that is NOT false: Perfection is never an option. True in glider design, too. The trick is to know - or at lest to remain within - one's limitations. YMWV Bob W. P.S. I believe Dick Johnson was a degreed aeronautical engineer. His entire working life was spent in the engineering field, and his extracurricular soaring-and-sailplane-design-and-testing-related body of work was prodigious. He likely passed on from heart failure in his mid-eighties while flying the Ventus he owned for decades - the one in which he drilled lube access holes. Make of all that what works for yourself! -- Dan Marotta |
| Thread Tools | |
| Display Modes | |
| Discus Aileron Seals | Peter F[_2_] | Soaring | 8 | August 20th 13 06:07 PM |
| left aileron for Discus CS wanted | [email protected] | Soaring | 0 | September 28th 12 02:31 AM |
| New Ventus 2 and Discus Winglets - M&H | Alpha Eight | Soaring | 11 | February 21st 12 05:41 PM |
| Looking for Left Outer Aileron for Ventus C | Bob Gibbons[_2_] | Soaring | 0 | June 30th 09 03:12 AM |
| Ventus 1 - anyone have experience w/o aileron centering spring? | Gary Emerson | Soaring | 0 | November 1st 08 03:36 PM |
