Cycling Views in Downloaded aircraft
Old August 16th 03, 10:22 PM
Timmy Ferrell
Default Cycling Views in Downloaded aircraft
Hi All,
I'm slowly learning the basics of downloading aircraft but I have
several questions. One of which is occasionaly I will get an aircraft and
install it with no problem; it shows up in the list of available aircraft
and loads properly. The cockpit view shows the panel and guages correctly
but when I cycle through the views nothing else appears except the outside
terrain- no cabin in the rear view or wings in the side views. The virtual
cockpit does not exist, either.
Am I not configuring something correctly, or is this more likely the way
the aircraft were designed? Is the a way I can tell if the aircraft will
have all views 'before' I download it, and if so how?
I realise the views probably will not affect the flyability of the
aircraft but it does detract from the immersion factor and the overall
completeness of the aircraft.
Timmy
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 11:33 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 08:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
