Anyone know how?
On Sunday, April 26, 2015 at 1:54:35 PM UTC-7, wrote:
Anyone know how? Add this to your config.txt file $PFLAC,S,CLEARLOGS Richard wwww.craggyaero.com |
Hi,
The easiest way is to use the latest PowerFLARM Configuration File generator - which is available he http://flarm.com/support/tools-softw...guration-tool/ There is a checkbox for clearing the memory. Best Regards, Paul Remde Cumulus Soaring, Inc. ______________________________ wrote in message ... Anyone know how? |
Fantastic, thank you for sharing!
Robert On Sunday, April 26, 2015 at 4:35:29 PM UTC-5, Richard wrote: On Sunday, April 26, 2015 at 1:54:35 PM UTC-7, wrote: Anyone know how? Add this to your config.txt file $PFLAC,S,CLEARLOGS Richard wwww.craggyaero.com |
Paul, thank you for sharing this! the configuration tool on the Air page doesn't seem to have this checkbox. I'll need to get my serial number so I can try out you link.
Robert On Sunday, April 26, 2015 at 5:52:23 PM UTC-5, Paul Remde wrote: Hi, The easiest way is to use the latest PowerFLARM Configuration File generator - which is available he http://flarm.com/support/tools-softw...guration-tool/ There is a checkbox for clearing the memory. Best Regards, Paul Remde Cumulus Soaring, Inc. ______________________________ wrote in message ... Anyone know how? |
On Sunday, 26 April 2015 21:24:28 UTC-6, wrote:
Paul, thank you for sharing this! the configuration tool on the Air page doesn't seem to have this checkbox. I'll need to get my serial number so I can try out you link. Robert On Sunday, April 26, 2015 at 5:52:23 PM UTC-5, Paul Remde wrote: Hi, The easiest way is to use the latest PowerFLARM Configuration File generator - which is available he http://flarm.com/support/tools-softw...guration-tool/ There is a checkbox for clearing the memory. Best Regards, Paul Remde Cumulus Soaring, Inc. ______________________________ wrote in message ... Anyone know how? Robert, you can get the serial number for your PF from a IGC file that has been downloaded from the PF. Might save you a trip to your glider. If you use SeeYou open the flight, under EDIT select FLIGHT PROPERTIES and then choose the MISC tab. This will display the IGC file. Scroll down and look for the LFLA record (first 4 characters in the records) that contains the character string FLAPFC10A. Here is the line from my IGC file LFLA17572807DEVNO FLAPFC10A-000351 Serial number 000351 in my case. If you do not have SeeYou then open the IGC file with an application such as NotePad, Word or other and search for FLAPFC10A. Good luck Ron Gleason |
| Thread Tools | |
| Display Modes | |
| Mangling of U.S. Contest Flight Logs? | [email protected] | Soaring | 10 | April 10th 12 05:17 PM |
| Cambridge GPS-NAV Flight Logs | Dan Marotta | Soaring | 5 | May 6th 11 02:44 AM |
| [US] Seniors Flight Logs | PMSC Member | Soaring | 0 | April 5th 09 05:35 PM |
| looking for flight logs from Cordele, '07 | John Bojack[_2_] | Soaring | 1 | February 27th 08 04:27 PM |
| Need GPS flight logs in NMEA format... | [email protected] | Soaring | 6 | February 15th 08 09:05 AM |
