Accurate plane performace?
Old December 18th 03, 02:08 AM
Dashi
"David CL Francis" wrote in message
On Mon, 15 Dec 2003 at 17:52:06 in message
, Peter Duniho
No, I'm talking weight. Mass is not a force. The acceleration toward
Earth
is caused by a force. What force? Weight.
A large amount of quote is not necessary here. The object in orbit or in
any trajectory around a massive object is in free fall. The path of the
object caused by gravitational attraction means that there is no force
measurable on the object (If you happened to be part of it.) If we want
to be very precise then you might detect the gravitational gradient
across the object if it had significant dimensions. Otherwise, except by
external observations, you would be unable to detect acceleration to
provide 'weight'.
No one denies the force of gravity except in the sense that other
theories claim that the effect of a large mass is to distort space.
I see now at last what you are talking about, but to call the force of
gravity 'weight' seems curious to me. Weight cannot be detected except
when a body is not in free fall. So in orbit an object has no weight.
Gravity enables 'weight' on objects that are on the surface of a body to
be measured. Astronauts cannot weigh things in orbit.
But can they lay things in orbit?
David CL Francis
Old December 18th 03, 05:40 AM
Peter Duniho
What else would you call it? And perhaps more interestingly, what is
"weight" if not the force of gravity? I'm curious: if "weight" is not the
force of gravity, what is it? How would you describe "weight" without
noting that it's a force resulting from gravity?
Of course it can. Simply note your acceleration, multiply by your mass, and
you get your weight. The acceleration itself is proof of the force called
"weight". Without a force, there is no acceleration. In free fall, the
*only* force acting on the object is weight.
Again, yes it does.
Of course they can. As I described above, all they need to do is note their
acceleration, multiply by their mass, and they get their weight.
Just because you do not have a handy fixed object against which to measure a
force, that does not mean that the force does not exist. It simply means
that you need something other than a spring attached to a fixed object to
measure the force.
By your definition, if I were to jump from the roof of a two-story building,
for the period of time before I struck the ground, I would be "weightless".
Yet, by any reasonable definition of "weight", a "weightless" object would
not fall to the ground at all.
Pete
Old December 18th 03, 08:23 AM
R
On Wed, 17 Dec 2003 21:40:51 -0800, "Peter Duniho"
Again, yes it does.
However, the spacecraft is moving in a straight line along the
geodisc. There is no way to distinguish a "weightless" (freefall)
object moving in a straight line along the geodisc of a gravitational
field from a "weightless" (non-accelerating) object that is nowhere
near a gravitational field. Both travel in straight lines along the
geodisc. What you're saying is dead-on in the Newtonian sense, but
as far as relativity is concerned, an object in freefall is synonymous
with an object not affected by a gravitational field. An object not
affected by a gravitational field by definition has no weight.
The Earth is "accelerating" towards the sun in the Newtonian sense
every day, just as the Sun is "accelerating" towards the center of the
galaxy, but I'm guessing all but the most insufferable graduate
student is willing to leave these non-negligable forces out when they
report their weight on their driver's licence.
-R
Old December 18th 03, 12:16 PM
Gene Nygaard
"Peter Duniho" wrote in message ...
Again, yes it does.
measure the force.
Pete
Weight is an ambiguous word--it has several different meanings.
Francis Weston Sears and Mark W. Zemansky, University Physics,
Addison-Wesley, 4th ed., 1970 used your definition, Pete, but said:
There is no general agreement among physicists as
to the precise definition of "weight." Some prefer to
use this term for a quantity we shall define later and
call the "apparent weight" or "relative weight." In
the absence of a generally accepted definition we shall
continue to use the term as defined above.
Most physicists today use David's definition, however.
Note that in Pete's definition the term "weightless" would never have
entered our language. Sure, there are many places where you would be
weightless in Pete's definition, some closer to the Earth than the
moon is, but we don't go there except in science fiction.
Of course, that only scratches the surface of the ambiguity in the
word weight. Consider all those labels at the supermarket and the
hardware sto "net weight" is not a physics term, and weight in
this context doesn't have either of the definitions you two are using.
That weight does not vary with the strength of the local
gravitational field--and it should not.
Same goes for "atomic weight" and "molecular weight" and "dry weight"
and "carat weight" and "troy weight" and "thrust-to-weight ratios" and
lots of other applications.
Gene Nygaard
http://ourworld.compuserve.com/homepages/Gene_Nygaard/
"It's not the things you don't know
what gets you into trouble.
"It's the things you do know
that just ain't so."
Will Rogers
Old December 18th 03, 03:30 PM
Gene Nygaard
Again, yes it does.
-R
Bad example. All forces, of whatever kind, are totally irrelevant to
the weight on that driver's license.
http://physics.nist.gov/Pubs/SP811/sec08.html
Thus the SI unit of the quantity weight used in this
sense is the kilogram (kg) and the verb "to weigh" means
"to determine the mass of" or "to have a mass of".
Examples: the child's weight is 23 kg
American Society for Testing and Materials, Standard for Metric
Practice, E 380-79, ASTM 1979.
3.4.1.2 Considerable confusion exists in the use
of the term weight as a quantity to mean either force
or mass. In commercial and everyday use, the term
weight nearly always means mass; thus, when one
speaks of a person's weight, the quantity referred to
is mass.
Gene Nygaard
Old December 18th 03, 07:41 PM
R
On Thu, 18 Dec 2003 15:30:26 GMT, Gene Nygaard
This is definately the case with most of the women that I know.
is mass.
Oh, I don't know. Maybe it's because I live in a country using
english-based units; when someone says they weigh 170 pounds, they
mean weight, as their weight was determined by a device created to
measure weight, not mass. But that's moot anyhow; while you are
correct in that we are entangled in a difference in semantics, the
real difference is not the one that you are referring to. Peter, for
example, is referring to weight in the Newtonian sense. In this
context, weight is a force, and acceleration is proof of that force.
Peter is correct within the framework that he's talking about. I am
referring to weight in the Relativistic sense. In this context,
weight is not a force, it is part of the geometry of spacetime.
Philosophically, Relativity probably holds more weight in this
argument. The whole problem with the Newtonian perspective in this
case is "what perspective do you approach this from"; i.e., what
gravitational fields do you reference when calculating "weight". Do
you leave out the sun? Do you leave out the galaxy? Heck, the galaxy
itself is accelerating. Relativity is not bothered by these
questions. Your own point of view is the only one that matters; if
you are in freefall, if you are moving along the geodisc, you are
"weightless". If you're not, you're not.
Under this definition, the Earth itself has no weight.
-R
Old December 18th 03, 11:22 PM
Gene Nygaard
is mass.
mean weight,
How can that make any difference, when those pounds are legally
defined as 0.45359237 kg, all around the world where pounds were used?
It wouldn't make any difference if the NIST example had used
pounds--the only reason it used kilograms is because SP811 is the
official NIST "Guide for the Use of the International System of Units
(SI)."
What is this country which uses the "licence" spelling and has pounds
on the driver's licence? Does Canada, or some of its provinces, have
pounds on the licence? Anyway, if it matters to you, you shouldn't be
the mystery woman without a name and without an email address, or you
should put that country info into a signature or something.
Sure, there are also pounds force, a recent *******ization, something
never well defined before the 20th century. There are also kilograms
force too--they used to be quite acceptable units. The only
difference is that the metric system is still fully supported and
updated, and those kilograms force are not a part of the modern
version of the metric system, the International System of Units.
Nonetheless, we still see many vestiges of their use--but not in the
use of kilograms for body weight. They are units of mass just as the
pounds are, when used for this purpose in medicine or in sports.
Nonsense. Sure, we often accept the measurements of a cheap spring
scale as a substitute for what we want to measure. Those scales
aren't very accurate for the measuring either force or mass--if your
mother's scale shows you to be 5 lb more than your scale home showed
an hour earlier, you don't congratulate yourself on a successful
weight loss program, do you?
But what about when you get serious about your weight, and weigh
yourself on one of those platform type beam balances at the doctor's
office or the gym? Those are mass-measuring devices, as are the ones
which promise
HONEST WEIGHT
NO SPRINGS
No. As I had already pointed out in my earlier reply to Peter,
quoting from Sears and Zemansky, your differences are at a more
fundamental level than differences in how you would define it in
Newtonian physics or using relativity. As S&Z said, "There is no
general agreement among physicists as to the precise definition of
"weight."
The differences they are talking about hinge on things like whether or
not "centrifugal force" is accounted for in your definition of weight.
In this context,
That applies whether you are using Newtonian physics or relativity.
Heck, the galaxy
-R
Yet Cavendish was successful in "Weighing the Earth" (the title of his
paper, IIRC)--in the same meaning used in commerce and for body
weight, not the different force definitions you and Peter have been
arguing about.
Gene Nygaard
Old December 19th 03, 04:54 AM
R
On Thu, 18 Dec 2003 23:22:10 GMT, Gene Nygaard
is mass.
mean weight,
(SI)."
Point noted; you are correct that legally pounds are measuring lbm,
or pounds of mass.
On the assumption that you're not trying to open a trolling front,
I'll say that it doesn't really matter who I am or where I am from.
That information is not difficult to divine, anyway, if you know how
to trace header information.
Bitching about spelling is bad form, as well.
which promise
HONEST WEIGHT
NO SPRINGS
They don't measure mass in the absence of a gravitational field,
though I agree that they will give consistent readings any time that
they are oriented against any field of any strength. That is, a scale
the likes that you are talking about (no springs involved) that
returns a value of "100 pounds" on the earth will return a value of
"100 pounds" on the moon as well. As such, you're right -- those
scales measures mass, they just fail to work in a zero-g environment.
But they still measure mass.
"weight."
Yes, but, again, centrifugal force is not a force in relativistic
physics, it is only a property of the geometry of spacetime. In the
debate between Peter and David (which I have unceremoniously butted
into), this is important. It demonstrates that both of them may be
correct, depending on which variant of physics you use to view the
problem, and explains a bit why the two of them are so far from
agreeing. In Newtonian physics, what you are saying is important, but
in relativistic physics, "centrifugal force", "gravitational force",
"acceleration" -- these are all the same thing.
In this context,
No, really, it doesn't, given the problem at hand. The Newtonian
approach states that one must measure the effects of gravitational
fields to determine weight, even if one is in freefall (orbit). This
can be difficult, as one must take into account forces which one may
not even be aware of or able to measure. Relativity assumes that
anything in freefall is moving in a straight, non-accelerated line
along the geodisc, and thus has no weight. If something is not being
accelerated, it has no weight, as there is no "force" acting on it.
How does Newtonian physics in this instance account for the fact
that we are *accelerating* away from distant galaxies at near the
speed of light? Why not factor in this "repulsive" force to find
one's weight? Certainly the force pushing us away is as valid as the
force that draws us towards massive objects. But then where do you
begin to measure the force? The force is huge if you measure out to
the edge of the observable universe, but virtually nonexistent if you
measure across the solar system. Relativity doesn't have this
problem. I tend to like Relativity to answer this question of weight
because with Newtonian physics the answer to this "weight" question is
arbitrary to the frame of reference that you choose to include at
possible the exclusion of other frames of reference; be it earth, sun,
galaxy, or universe. Relativity assumes that all frames of reference
are equally valid; or, more specifically, the only frame of reference
that is of any matter to you is your own.
Heck, the galaxy
-R
arguing about.
Henry "weighed the earth" using Newtonian laws and did so long
before the discovery of Relativity. He was correct within the
Newtonian framework; however, often, when dealing with matters of
stellar physics, relativistic physics is the often only way to fly. I
don't really care what commerce and those who divine national
standards think about how "weight" should be described; they have no
use for Relativity (let alone Quantum gravity), as Newtonian physics
is almost completely accurate in measuring their widgets. I'm
interested in the philosophical question of which approach is
"correct" (so far as we can tell) and most useful in describing
reality. Given that relativistic physics is correct in every instance
that Newtonian physics is correct and is also correct in instances
where Newtonian physics breaks down, I suspect that relativistic
physics is the right course to take in answering this "weight"
question. Relativity doesn't ask one to believe in an imaginary
"weight" that can't be directly measured by someone in a closed room
with no windows or external sensors.
-R
I need some advice on buying my own plane BEFORE training... Anthony L Piloting 6 April 22nd 04 11:13 PM
Navy sues man for plane he recovered in swamp marc Owning 6 March 29th 04 12:06 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
