Near Vertical Takeoff
Old June 15th 15, 11:38 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Near Vertical Takeoff
On Sun, 14 Jun 2015 20:01:05 -0600, Dan Marotta wrote:
Wow!!! I'd love to try that!
On 6/14/2015 7:36 PM, GM wrote:
I can do that in my glider, though not for quite as long...
Yes you can! Do a winch launch on one of those specially modified
European winches that use over 11,000ft of line, hold that climb for 2
minutes and end up at over 4,500ft. I bet the jet cannot do that!
Uli
Here's a video: https://www.youtube.com/watch?v=-VlRd9-wxQI
Note that the instruments are metric: climb rate in m/s, height in m,
airspeed in kph.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old June 15th 15, 06:20 PM posted to rec.aviation.soaring
Mike the Strike
Released at 1390 meters, 4560 feet!
Old June 15th 15, 07:10 PM posted to rec.aviation.soaring
John Carlyle
I like the outside loop!
Old June 16th 15, 03:44 PM posted to rec.aviation.soaring
Graeme Cant[_2_]
2 minutes and end up at over 4,500ft. I bet the jet cannot do that!
Uli
What - 2250fpm? Most modern twinjets do that easily. A full thrust
takeoff in an empty 747SP cracks 4000fpm. Even if you allow 30 seconds
for the takeoff roll - about right at light weights - 4500 feet two
minutes after brake release would be easy.
OTOH, I'm stunned at the lack of scepticism about the video. The climb
will be nowhere near vertical. 150kts indicated is 15000fpm if
vertical. It's nowhere near that. The climb is likely about 5000fpm -
50kts in glider-speak. That's about 30 deg climb angle. Perspective
foreshortening due to long focal length lenses is a wonderful thing.
That's how all those aeroplanes survive 60 deg drift landings in HKG on
those Youtube videos.
GC
vertical 1_0.jpg troy24 Aviation Photos 13 January 18th 11 01:54 PM
Vertical stabilizers Dallas Piloting 20 March 2nd 10 03:43 AM
Head wind takeoff into rising hills, or crosswind takeoff to open space ?? P S Piloting 7 September 20th 07 07:29 PM
Vertical and Short Takeoff / Landing Fighters Aviation Naval Aviation 7 January 5th 04 08:49 PM
Vertical and Short Takeoff / Landing Fighters Aviation Military Aviation 6 January 5th 04 01:18 PM
