Kobo with Cambridge 302
Old August 16th 15, 03:56 AM posted to rec.aviation.soaring
Default Kobo with Cambridge 302
Is anybody running xc soar on a kobo connected to a Cambridge 302? If so, what type of cable did you use to connect, and which port on the kobo did you tell xc soar to use? I'm running it on a pocket pc now, using a custom serial cable. But the kobo is much easier to see. I made up a homemade usb to db9 cable. the problem might be the cable, which I'll check. But I also might be using the wrong port on the kobo, and I didn't find any help in the manual. If somebody else has this setup working I'd like to know how you did it.
John
Running Top Hat on Kobo mini Ben S Soaring 11 July 21st 15 05:00 PM
Kobo Aura refresh rate? Martin Gregorie[_5_] Soaring 19 June 29th 15 10:03 PM
Color Kobo Dan Marotta Soaring 3 October 26th 14 12:10 AM
Cambridge 302 & PDA -- Value of adding Cambridge 303? V1 Soaring 5 July 31st 07 04:51 AM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 6th 04 12:22 AM
