Is FLARM helpful?
Old November 24th 15, 12:26 PM posted to rec.aviation.soaring
Ramy[_2_]
Default Is FLARM helpful?
I think the reason that gliders for sale are not Flarm equipped is that their owners rather keep the Flarm and move it to their new ships, since once you fly with one you will never want to fly without it.
Ramy (With handful of Flarm saves in over 1000 hours with Flarm)
Old November 24th 15, 04:47 PM posted to rec.aviation.soaring
Renny[_2_]
Agree 100% with Ramy. I had a portable PF in my Discus 2b, and when I sold it in early 2012, I kept the PF for my new LAK....As far as close calls, many of the folks that fly at Moriarty have had PowerFlarms since 2011 and I do believe it has been a major enhancement to safety. It has personally alerted me on several occasions over the past 5 seasons to gliders coming head on at high speed especially under cloudstreets. These alerts allowed me to alter my course and avoid any potential conflict. This past season we had an incident where two gliders came within 20-30 feet from each other and they never saw each other until the very last second. One glider had a PF and one did not....The pilot who did not have a PF went out and bought a PF immediately...
Finally, I do fly with a transponder and a PF as do many other folks at Moriarty. The use of transponders is also extremely important in our area as there is a fair amount of jet traffic passing over the area as they descend into Albuquerque. Albuquerque approach is very aware of gliders at Moriarty using 1202 on their transponders. When they "see" us they do try to route the airlines away from us and/or try to keep them above 18K as they pass west bound over the Moriarty area. Once past Moriarty they then allow them to descend into Albuquerque....This does really help minimize potential conflicts. Now, be safe out there! Thx - Renny
Old November 24th 15, 05:44 PM posted to rec.aviation.soaring
James Metcalfe
At 12:26 24 November 2015, Ramy wrote:
... (With handful of Flarm saves in over 1000 hours with Flarm)
Interestingly, my experience is just the opposite: in 1593 hours in
the French Alps since 2007 (only 208 hours of which were without
Flarm), I have had no relevant alert from Flarm but hundreds of
false alarms. However I have experienced several dangerous or
very dangerous events (and many more daft ones) which can only
reasonably be ascribed to Flarm - or rather the false expectations
that some pilots seem to have of it.
The most stupid of these was two gliders simultaneously overtaking
me at speed from directly behind on a ridge, one each side, at
exactly my height, and with a horizontal separation of about a
wingspan. Fortunately, I had insisted that my pupil did *not* take
evasive action from the Flarm-announced threat, pointing out that
we might just turn into the path of the (imagined) single overtaker.
(I presume that the 2 overtakers thought "they know we're coming,
so they won't do anything stupid"!)
In the 2000+ hours in the Alps before Flarm I saw no such
dangerous behaviour; nor in the 208 hours 'gap' without Flarm in
2008.
Of course, nothing can be proved. But enthusiasts for Flarm should
be aware it has its down-sides.
Old November 24th 15, 06:03 PM posted to rec.aviation.soaring
Richard[_9_]
2008.
Really James, I suspect something is very wrong with your Flarm.
I have approximately 1000 hours with PowerFlarm and have not experienced any issues with false alarms. 6 camps and contests with as many as 65 gliders.
Richard
www.craggyaero.com
Old November 24th 15, 07:12 PM posted to rec.aviation.soaring
James Metcalfe
At 18:03 24 November 2015, Richard wrote:
... Really James, I suspect something is very wrong with your
Flarm. ...
Interesting thought. That would mean a fault in the Flarm
algorithms, or (highly improbable) a bad but operable installation of
the Flarm firmware. And, BTW, more than one Flarm unit was used
over those years.
J.
Old November 24th 15, 09:44 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Flarm. ...
over those years.
J.
Since you've owned several I guess it's safe to say there's more benefit than downside.
I'd be hard pressed to say I've ever had a false alarm - I guess it depends on how you define such a thing. If you mean an alarm when there were no other gliders in the air I would definitely look at whether you need to replace the hardware or firmware. If you mean you got an alarm for a glider in the area that you didn't think was an immediate threat you might consider 'competition mode' which sets the collision parameters tighter before issuing an alarm. We all have our comfort zone, but I'd be dubious about reports of alarms where that projected flight paths of the gliders involved weren't crossing within the radius of error that the algorithm assumes. As you may recall, Flarm projects curving flight paths, so you don't need to be on a straight-line converging path to generate an alarm. In a busy thermal you'll get lots of alarms, but the flying is so dynamic that the threats can come and go with regularity. It's not so much a false alarm in that case, but a transient conflict and probably not super-helpful, but technology has its limits in the analog world.
If the OP is considering whether to equip with Flarm I'd say if you intend to fly with other gliders, get one and if the other gliders don't all have them already, organize a group purchase.
I've had lots of useful alarms. I'd wager at least one prevented me from taking the silk elevator home.
9B
Old November 24th 15, 10:59 PM posted to rec.aviation.soaring
Ramy[_2_]
One thing to point out is that James is likely referring to the European Flarm while most of us referring to Powerflarm which I understand is superior especially in the user interface side (butterfly display etc) and as such I believe better visually distinguishing between alerts and collision alarm..
Ramy
Old November 25th 15, 08:46 AM posted to rec.aviation.soaring
Tango Whisky
Am Dienstag, 24. November 2015 23:59:45 UTC+1 schrieb Ramy:
Ramy
I have about 1600 hours flying with the European Flarm in the French and Swiss Alps, and I have had more than one occasion where the Flarm warning solved a very hairy situation. I also have had many false alarms, but I can live with that - I'd always take a false positive over a false negative.
On the technical side, I take good care that my antenna coverage is acceptable in any direction (which requires more than one antenna on a carbon fuselage).
Bert
Ventus cM TW
  #29
Old November 25th 15, 02:34 PM posted to rec.aviation.soaring
Stephen Damon
It is amazing what we pay for gas, insurance, tow fees and hanger fees, and also life insurance. What is a parachute, the real life insurance not life insurance that pays your heirs. So what Flarm, another form of real life insurance, that will keep you from using your parachute incase you have too. Not to mention if you have had a collision with a sailplane or larger ship you will most likely be in bad shape. Yes I know chutes may need to be used with a collision. So to me, Flarm is just another form of real life saving insurance, that is pretty inexpensive for what it had and can do.
  #30
Old November 25th 15, 03:38 PM posted to rec.aviation.soaring
Mark628CA
I consider PowerFlarm to be a great asset in the cockpit. I have had a couple of warnings that may have made a difference. In one, I was thermalling with another glider when the warning went off. I was tempted to ignore it because I had "eyes on target" and I am sure the other pilot was watching me. A quick glance at the Flarm display indicated that the alarm was for someone in my low five o'clock position. Sure enough, a glance over my shoulder showed that another glider had joined us at speed and with a pullup into the circle. I was startled, but not freaked out- because I had the warning. If he hadn't had Flarm, it would have been much more disconcerting. I wish everybody had 'em, but I am not going to make a big deal out of it. I consider it one more source of insurance, just like my transponder, and yes, my glasses.
FAA Actually being helpful! Steve Leonard[_2_] Soaring 3 September 15th 12 02:57 PM
Helpful controller Ridge Piloting 3 July 12th 07 11:57 PM
Ode to the Helpful Homebuilder [email protected] Home Built 13 November 10th 06 08:37 AM
Helpful Aviation DVD's Kobra Piloting 0 October 27th 05 02:10 AM
Which rating would be more helpful? Jeffrey LLoyd Piloting 2 July 17th 03 07:02 PM
